#1 | |||||
old cone killer
#2 |
so why does Eibach say its Sportline kit (1.5,1.8in drop) handles more agressive and stiffer then its Pro kit(1,1.5in drop)?
I understand the lower sportline kit should be stiffer, but from what you say, the higher ride height pro kit should be more agressive because once you pass 1 inch you kill your handling? |
#3 |
HT White Ops
Because it has more to do then just how low you go! Sportline kit has a stiffer spring rate then the Prokit! If the Prokit hand the same spring rate as the Sportline, the Prokit would make the car a million times better the the Sportline.
Its a big misconception to think that the lower you are the better it is. A lowered car does have a better center of gravity but even that has it's limits. When you lower a car you have to take into consideration suspension travel. If the suspension can't travel you creating a car that can't handle properly period. Anyways I don't want to steal the light from our own lil suspension GURU! Thanks Mustclime, if you want to add more please do and I will sticky it!
PSN: DaveSi677 2002 EP3 SiR Nighthawk Black 1993 EG Si Type-R Berlina Black RIP |
#4 |
Well, on the topic of lowering springs. Mcpherson strut suspensions work very well in their "sweat spot". If you lower the car out of its sweat spot, you are forced to run huge spring rates and swaybars to control body roll induced by coring load acting on poor suspension angles. With our suspension design, any front springs that are progessive are just plain dumb....remember, you do not want your ft lca's angling up from the center of the car going into a trun, a progressive spring will allow this to happen with its lower rate in the first inch of travel. So why you ask do these tuning compenys make them? Because people that do not know any better buy them.
Spring makers are also limited in what spring rates they can use. If you lower a car 2 inches that only has 5.0 inchs of upward suspension travel, you should increase the spring rates by close to 100% to keep the car off its bumpstops. If you do this to a spring that is going to have the stock damper try to control its rebound. Do not expect that damper to last long. If you do not beleive me, ask some people that have some junk2 coilover sleeves. Junk2 sold people their kit that had a 570lb rate spring for the front when the stock ep3 had stock progressive spring rates of around 250lb and the dc5 had 280lb ish....I know people than had their almost new dampers blown in less than a month. What can you learn from this.....stay away from lowering springs. If you really want to TUNE your suspension remember this..... 1) the grip of the tires set the spring rates. 2) the rates of the springs set the dampers 3) the balance of the car sets the swaybar size 4) bushing and braces have their place in all of this but it is less than you think. Braces are pretty much the last thing you should get.
old cone killer
#5 |
Stupid question: How come your car looks lower than 1"? lol
"So whats the deal with politics? I don't get it...Am I right people? ![]() ![]() "
#6 |
Pacific North Fresh
2003 Honda CivicJoin Date: Oct 2008
Beefy tires and 17" rims will help in wheel well gap...
#7 | |
old cone killer
#8 |
how bout this, how can someone take a not so great coilover set like a megan racing street kit and improve their suspension.
#9 |
Nice write up.Has a lot of important info that I found out
00 NGP TL-Sold 04 SSM EP3
#10 |
so say I lower my car 1.5 inches... When i go through a turn and pass the angle of no return as i go through my suspension travel, is it just going to understeer way more?
#11 | ||
old cone killer
#12 |
hmm well i have a progress adj in the back, and i have the em2 in the front which i think is 24.5mm ive been debating on trying to find something smaller to go up front.
#13 |
Next topic.....swaybars suck.
Have you ever though about how a swaybar( anti-roll bar) works? What are they good for? Have you ever thought "since the factory put a 25mm hollow bar on the front of my car, wouldn't my car handle better with a 27mm solid bar"? Well, for the longest time I thought of swaybars(SB) as spring helpers. I thought that when you went into a turn, the swaybar(SB) being attached to the lca and the body helped hold up the car through the turn....WRONG!!!! Think about what happens when you go through a turn...... 1) the driver turns the wheel, the tires turn and bite, the car starts tochange direction... 2) As the car starts to change direction, weight shifts to the outside tires, the outside springs are overloaded and start to compress. 3) as the springs compresm the lower control arm starts to angle up.....the (SB) being attached to both lca's and the body is forced up on the outside side...... this is the important part!!!! what happens on the inside suspension of the car??? 4) the (SB) being nothing more than a "U" shaped rod/tube pulls up the inside lca because it "wants" to be flat not twisted. think about that for a second. . . . . Now, if down force increases grip( like having huge wings on a F1 car), what does up force do to grip???? Well, It decreases grip..... ![]() This is why some people think of (SB)'s as grip reducers. Why would car makers ever put such a stupid thing on a car, why not control body roll with spring rates......simple, who wants to dd a car that can run over an ant and have the driver feel every bone in its body crush.....OK, what should you do with this knowage? IMO, understand that big sways on the drive wheels are really dumb, Understand that you should use the non drive wheels to control body roll because they are doing the least work in a turn. These are the reasons you wait till you have your tires, springs and dampers before you mess with the sways. (SB)s are for fine tuning the suspension not setting it up.
old cone killer
#14 |
Pacific North Fresh
Great info once again...
#15 |
So you're only really referring to front sway bars right?
#16 |
Sways make your cars suspension less independant. Independant suspension is good for grip. I have had people on this forum tell me that sways do ont effect a cars ride, that BS if you are using big sways. If you were biulding a prepared autoX car that would not be driven on the street much, your goal would be to pick springs that would allow you to run no sways at all....with high grip street tires, something like 450-550lb ft and 1100-1300lb rear would do it depending on how much weight you tear out of the car....you would be forced to get some custom rear shocks for that and you are right on the limit of the koni insets for the front....but if you are going to run your car as a dd, yea, you want to run sways. You still want to run as little front sway as you can get away with.
old cone killer
#17 |
last time we went to midohio we removed the front sways on both rsx's , ive been looking for somekinda front sway that i can use on a daily, thats fairly small, but because i have a buddy club header my luck has been shitty
#18 |
03 em2 coupe.....thats the 15mm hollow ft bar....the barand the bushings is 60 bucks
![]() or go to jdmland and get the edm ep3 type-r ft bar(25.4mm hollow)...its supose to be a very tunnel hugging bar.
old cone killer
#19 |
yeah i just looked that up 15.9 in the parts cat, now i just kinda wonder if that would cause too much over steer, i can deal with it with track tires on and open space to spin the car but on the daily road with no where to go and conti extreme dws's on idk.
#20 |
If you are worried about the car being to tail happy, add a little toe out in the rear.
old cone killer
#21 |
ok jst a question bout my suspension..... after i lowered my car i have a loud ticking noise coming from the driver side strut when i turn the wheel at low speeds to no speed..... i have a 02 civic si wit skunk 2 pro s coilovers...... thanks
#22 |
sounds like the binding strut top bearing....hard to tell with out seeing the car. How did that little blue plastic ring look when you swapped it over? If I remember correctly, junk2 coilover just give you a upper purch on the front that is supose to sit on the stock strut top bearing / upper strut top.
old cone killer
#23 | |
wow.... this changes my plans for sure.... i was just planning on slamming it on BC N+'s
could i get suggestions on what route to take for my 03 DC5 please? this is my DD... alright, i got some sticky bridgestones on my stock 16's 1 what spring set up should i be looking at for a DD? [i don't mind bad street manners very much but there is always a limit....] 2. if you recommend just changing springs.... would koni yellows hold up to the spring rates recommended in in #1? 3. I am gonna get an EM2 sway in front to clear header and a Progress adjustable in the rear [24mm] 4 ebay for the braces cause a piece of metal is a piece of metal. and bushings if i get serious will probly be the Energy kit. [already got camber kits lined up] look forward to hearing from you mustclime! |
#24 | |
old cone killer
#25 |
I just bought my 04 type S and it is also my DD. I live in iowa and see some mean winters, i think im going to go with a set of s drives for new tires on the factory rims. I would like to do some suspension work but the budget is tight. Are there other options to the koni yellows on factory struts that might be more budget friendly. any help would be great and im a new member, so this is kinda a first for doin this. lol poppin my cherry
| Bookmarks |
| Tags |
| arm, bushing, con, control, dc5, energy, ep3, good, honda, lower, lowered, mugen, rod, sport, suspencion, suspension, tie, type |
