643hp @ 22psi, h22, S372 (dyno video)
made it back to the dyno today, i could only run off wastegate, for some reason my water pump wasent working right, so having to change it and go back for a 40psi pull..
643hp 400tq with some wheel spin @ 22psi, 9500 rev limit
heres the set-up, dyno video and chart..
dyno video
http://www.youtube.com/watch?v=Q6x1kXr8LE4
Year:1997
Make:Honda
Model: Prelude
Transmission type: PPG Dog Box, 4.4 FD with Quaife LSD and Strain gauge (For clutchless shifting)
Engine:Blueprinted and balanced H22
Displacement: 132 c.i.
Engine Modifications/Body/Chassis Modifications:
-Golden eagle sleeves
-Golden Eagle manifold
-Bullseye Power S372
-70mm STR Throttle body
-Arias Pistons 20 over
-Eagle rods with ARP rod bolts and head studs
-Brian Crower Stage 3 turbo cams, dual valve springs & titanium retainers
-Ferrea SS valves
-3 angle valve job, port and polished head
-MSD digital 6 ingnition and external coil
-Hondata S300 with boost by gear
-Spinwerkes fronts and rears with Mickey Thompson 26" slicks
-Custom billet solid motor/transmission mounts
-Tial 60mm wastegate
-Custom Dumptube/wastegate tube
-Custom Front Battery Mount
-NHRA Legal 6point Chromoly Cage - will be 10 point
-Kirkey drag seat, G force 5 point harness
-Sparco Extreme 2 wheel, Greddy boost/egt/oil pressure guages
-Aeromotive Eliminator Fuel Pump, Aeromotive FPR, JJSPEC fuel sump, SS fuel lines, 1680cc injectors
-Carbon Fiber hood and sunroof plug
im sure i forgot something
Weight figures w/o driver:
Total weight: 2372lbs
LF 810 34.1% RF 762 32.1%
LR 412 17.3% RR 387 16.3%
Front/Rear Bias 66.2/33.7%
Left/Right Bias 51.5/48.5%
Im sure I can get another 50lbs out of it, still got a few things that can go, Sway bar, windshield wiper motor, CF trunk, etc..
dyno video
Year:1997
Make:Honda
Model: Prelude
-Ferrea SS valves
Re: 643hp @ 22psi, h22, S372 (dyno video)
i was/am an 11bravo. I broke my back and got out..
ill stop at around 850hp, im sure i could make more, but thats a nice round number in my head...
wasent cooling at all. we pulled the thermostat to see if it was sticking, it wasent, we narrowed it down to the water pump. If i haft to put an electric one on it, ill do it.
this is an older pic of the engine before i had the catch can and AN fittings welded in.
thanks,I will keep you updated.
Going to fix the cooling problem and go back to track so we can get the car dialed in.
Thanks everybody.
I don't think I have a dyno sheet with the RPM, it was making power to 9500rpm, maybe more, but that's all the RPMs I need. I wish I had it so you could see where it was spinning, my tuner showed it to me.
lol.....yeah i just love how the Army dicks everyone over...anyway is this a straight track car? or would there be highway vids later on??
Its a track car, to many idiots driving around here.. I have been down the road in it, but its not something i go far in. I have a Sheriff next door to me and 3 others all within a 1/4 mile. They love when i hit boost on my street, they dont say anything but theyre looking..
It's not in in pic, it mounts the same place but up higher. I'm having trouble with the belt popping off, so I'm having to fix the bracket or get another
Sick car, love the work you put into it, not many ludes around with that kinda monster under the hood. Good luck on the 9's. Sick power and sounds like a beast
98vtec
04-09-2006 09:54 AM
