> Honda Civic (2001- 2005)
Old 10-12-2009, 08:36 PM   #1
norcalem2
Default 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
5 Lug and Brake Swap EM2, ES1 01-05
This lug swap and brake conversion is for people still have D17 motor.
But if you want to put in a K series motor this works as well.
Parts:
-RSX Base knuckles, front
-RSX Type S Knuckes, front (use this only if you have a K swap)
-RSX Base or Type S / SI hatchback 04-05 “EP3” knuckles, rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” Brake Caliper Rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” E-Brake Cable
-RSX Base or Type S Brake Lines for each Brake Caliper (by new lines)
-RSX Base or Type S Brake Caliper (check seals)
-RSX Type S Front Brake Caliper brackets.
-"I also would suggest to swap out your brake booster for RSX Type S, Brake Master Cylinder, Brake Portioning Valve. This is also going to require a little rewiring of your brake lines to the master cylinder."
-By new Brake pads and rotors. (You can buy brand new OEM Brakes from ACURA which will cost you the most money, or go after market which are better for harsh driving I went with EBC pad and rotors).
EBC Model numbers:
Brake Pad Part Numbers: RSX Type S
Part # Description
DP41193R EBC High Friction Upgrade And Race; Disc Pads; Rear;
DP41254R EBC High Friction Upgrade And Race; Disc Pads; Front;
DP31193C EBC Redstuff Low Dust Superstreet; Disc Pads; Rear;
DP31254C EBC Redstuff Low Dust Superstreet; Disc Pads; Front;
UD537 EBC Ultimax Pad Set; Disc Pads; Rear;
UD829 EBC Ultimax Pad Set; Disc Pads; Front;
Brake Rotor Part Numbers: RSX Type S
Part # Description
USR7127 USR EBC Sport Rotor Kit; Front; 11.8 in. Dia.; Set of Two;
USR7128 USR EBC Sport Rotor Kit; Rear; 10.2 in. Dia.; Set of Two;
-5 lug wheels 5X114.3 pattern. Stock offset of our cars are +45mm Rims must bet at least 16” and larger to fit around the RSX Type S calipers.
FAQ:
Can I use parts from new SI Coupe or Sedan 2006-2010?
-New SI coupe and sedan 06+ parts do not bolt up with out modifying your car a lot. I would not suggest buying any of these parts. Except for the rims will work.
If you have an 01-02 you must change out your lower control arms!
-rsx front lower control arms(stocks can be modified to work by using tapered washers and taking up the slack)
if you have an 03-05 you dont need to modify the front struts
if you have an 01-02 you can either get the later style struts and knuckle bolts, or you can drill out the strut holes and use larger bolts
ABS System?
-If you have ABS I would suggest taking it out. It is a headache to make it work. If you want to keep ABS you are going to need the ABS system from RSX Type S with all the sensor and cables.
Why does the 01-05 Civic w/d17 need the RSX Base Front Knuckles?
-Well the RSX type s front knuckles/hubs, and cv joints do NOT spline to the civic axles, but the civic axles do spline into the base RSX Base Knuckles/hubs. If you want to use RSX Type S brake calipers and rotors you must gab the RSX Type S brake caliper brackets off the RSX type S knuckles. (Note: if you are going to use RSX Type S Brakes you must use 16” rim or larger)
AFTER YOU DO THIS LUG SWAP AND BRAKE CONVERSION TAKE IT TO A SHOP AND GET YOUR CAR ALIGMENT!
FIRESTONE TIRE SHOPS HAVE LIFETIME ALIGMENT AS LONG AS YOU OWN THE CAR. IT IS WORTH PAYING FOR THE LIFETIME ALIGMENT!
THIS IS ALSO POSTED ON SOCALCIVIC.COM
norcalem2 is offline Report Post   Reply With Quote
Old 10-12-2009, 09:03 PM   #2
integraa972
integraa972's Avatar
Default Re: 5 LUG AND BRAKE SWAP INFORMATION: EM2, ES1 01-05
Please sticky this!
Portioning valve, brake booster not needed but would be nice.
94 gsr - sold
91 crx - sold
91 da - sold
integraa972 is offline Report Post   Reply With Quote
Old 10-12-2009, 10:23 PM   #3
katzenjammer84
2004 Honda Civic
katzenjammer84's Avatar
Send a message via AIM to katzenjammer84
Nice writeup.
04 Civic EX Coupe
92 Accord EX Sedan
katzenjammer84 is offline Report Post   Reply With Quote
Old 10-13-2009, 12:28 AM   #4
It Wasn't Me
It Wasn't Me's Avatar
Added to FAQs
It Wasn't Me is offline Report Post   Reply With Quote
Old 10-13-2009, 12:38 PM   #5
usnpr21
usnpr21's Avatar
Send a message via AIM to usnpr21
-5 lug wheels 5X114.3 pattern. Stock offset of our cars are +45mm Rims must bet at least 16” and larger to fit around the calipers.
Wrong. 15" wheels can be used on base setup. Type S setup requires 16" wheels.
usnpr21 is offline Report Post   Reply With Quote
Old 10-13-2009, 04:44 PM   #6
eghatch4sale
eghatch4sale's Avatar
Send a message via AIM to eghatch4sale
I've been throwing this around back and fourth if I want to do this or not hmmmmm......
eghatch4sale is offline Report Post   Reply With Quote
Old 10-13-2009, 05:24 PM   #7
Harlowe
Function>Fashion
Harlowe's Avatar
Send a message via AIM to Harlowe
I'm running base rsx front knuckles with type S calipers & rotors. I didn't have to modify anything to get the calipers to fit, they bolt right up to the base hubs.
You don't NEED the RSX Type S Brake Portioning Valve either.
Nice write up though
2001 Honda Civic LX - meow
1991 Honda Civic Si OBD1 D16z6T (unfinished project) - Sold
Harlowe is online now Report Post   Reply With Quote
Old 10-16-2009, 04:50 PM   #8
CivcaIh
Nice work
CivcaIh is offline Report Post   Reply With Quote
Old 10-17-2009, 03:33 PM   #9
jdm em2
jdm em2's Avatar
Send a message via AIM to jdm em2
I want a 5 lug conversion anyone that is trying to sell one let me know pm me!!
LowNSlowEm2
jdm em2 is offline Report Post   Reply With Quote
Old 10-18-2009, 03:09 PM   #10
tonykdee
tonykdee's Avatar
Are there going to be any advantages coming from our stock brake setup to the rsx type s in terms of performance?
tonykdee is offline Report Post   Reply With Quote
Old 10-18-2009, 07:33 PM   #11
norcalem2
There is a huge difference in stopping power as long as you go with the RSX Type S setup. If you go with the RSX base setup not that much.
Old 10-18-2009, 07:44 PM   #12
Harlowe
Function>Fashion
Harlowe's Avatar
The base/ ep3 front rotors are the same size as stock em2 ones. Type s ones are 1.5" bigger
Bookmarks
acura, base, brake, calipers, civic, disk, em2, es1, lug, parts, rear, rotor, rsx, swap, tl, type
