#1 | |||||
#2 |
I used the cheapo autozone rotors, the valucraft ones, with hp+'s and valvoline synpower fluid on my old old DB8 and I had zero problems with them. I did track days every month, auto-x's once in a while, and fun runs up and down the local mountain once or twice a month.
So yeah, as far as the rotors go, I would replace the rotors once per year and they wouldn't show any cracking or heat discoloration much less any warping.
1993 Miata: Spec Miata Bilsteins with 700 #/in front and 450 #/in springs rear, Eibach front sway bar, 94+ front brake swap, Torsen diff with 99 axles, custom 6-point cage, and turbo'd at 10 psi on a 15g. |
#3 |
no runout and vibrations? what pads?
Ikuo Kajitani The Revolution he made <U>Da squad member#166</U> http://images.honda-tech.com/set1/smile/emsmilep.gif DonF http://images.honda-tech.com/set1/smile/emthup.gif |
#4 |
nope, no vibes. I was running hawk hp+ pads. I was sure to keep up the maintenance on the braking system (clean and lube the pins, clean off misc. dust, flush the system etc) every year when the rotors were replaced, after every pad change, and when the racing season started/ended.
#5 |
I use cheap chinese rotors $14 have not failed me yet.
TBA 1988 Honda CRX - HC H4 Real Estate Solutions CA Inc Need Cash Fast? We Buy and Sell Homes FAST We also provide Foreclosure Help and more. |
#6 |
Joe Sim broke both of his slotted rotors that came with the FastBrakes.com kit at Nationals (see Migs HC Coverage thread for pics)
Not sure of the miles on those rotors, but they were cracked all the way through on both sides and into the rotor hat. He picked up some cheap-o rotors from a local parts store. Worked just fine for the rest of Nationals. Now, I'm no saying that at some point the cheap-o rotors will fail, but you can't always rely on expensive products to get the job done. Sometimes the simple solutions work better. |
#7 |
Suspetise...
Autozone rotors (or any other generic auto parts store) are totally hit or miss. If the rotor was manufactured properly, you'll have no issues whatsoever. But there have been plenty of people who have bought the same exact product and had different wear life because of a difference ONLY in manufacturing somewhere across the ocean.
If you investigate more, there are very few rotors that have really consistent manufacturing quality, and they are not cheap. Overall, I say go for the cheaper ones. The Duralast that are twice as much money do not have twice the guarantee or twice the quality of the other ones, and you don't sound like the kind of guy who really NEEDS the best. Not that I condone canyon driving, but you should be more concerned with your pads not fading than your rotors cracking, especially if you're talking about glowing rotors. |
#8 |
Remember, you get what you pay for. Spend 14 bucks on a rotor- that's what you get.
http://www.tirerack.com/brakes/brake...ar=&perfCode=S I've used every brand under the sun in 7 years of w-2-w racing, these are by far and away the best. Period. End of story. Becareful on the streets, dude.
#88 Exedy SCCA STU/ NASA PTA Integra Type-R Exedy Racing Clutch- Hoosier Racing Tire -Carbotech Brakes - Hondaworks -DBA rotors http://www.cardomain.com/ride/2566650 |
#9 |
o_O 600 bucks for rotors? That's nutty =\ What Carbotech brake pads are you using? I used Hawk Blues on Brembo rotors on my Miata and I had to replace both the rotors and pads after just a few races and about 1000 street miles ... that was about 2 months of use. I definitely don't think I got my money's or performance worth out of that setup even though it was more expensive than my previous autozone/hp+ combo.
Anyways, what I'm trying to get at is that the OP isn't going to be using a super aggressive pad like the Hawk Blues or Carbotech xp10/12/16, so he won't be needing a rotor that can put up with that kind of abuse and heat that the pads under racing conditions put on rotors.
#10 |
Suspetise...
Legitimately, the OP is the one who was talking about glowing rotors. Normal street use, I agree completely.
#11 | |
soooo... do those outlast 5 sets of $20 rotors?
2000 civic hatchback hypermiler 1991 CRX Si track toy 95 Ford Ranger 3.0 mule |
#12 | |
I agree with you, The DBA rotors are really good. They make 4x100 sets too. I've driven a car with those exact same rotors. IMO best bang for the buck. I personally am running Duralast rotors in the front and rear, but i do plan on upgrading to DBA's next season.
#13 |
Okay, I think I will try to cheap-o rotors then but plan to check their thickness and wear often. Hell, they have a 2 year warranty on them, maybe I can get two full sets for 40$.
Thanks for the help guys! Last edited by Hemix; 10-12-2009 at 09:20 AM. |
#14 |
Suspetise...
A budget is understandable, but you won't ever be able to legitimately justify canyon driving. There is ALWAYS a possibility of something happening beyond your control. If you can't afford a track day, you most likely can't afford damaging or totalling your car or someone else's either. I don't really feel like preaching right now, so I'll just leave it at that.
#15 |
Can you preach me to sleep ?
#16 | |
#17 | |
2008 Race Engineering Rookie of the Year. www.raceengineering.orgwww.ctbrakes.com See me on trackdaze's August VIR 2008 section. Teal hatch |
#18 |
Dunno, I gave up those sub $20 rotors long ago. Back in the day, I'd warp a set of cheapcrap in only a few sessions... that problem is now long gone. Buy cheap parts you should expect a equal outcome.
#19 |
Roger that.
I asked Danny @ Carbotech a few years back about DBA rotors and his quote was... "these are the best rotors you'll ever use". Call and ask him: 1-877-899-5024 BTW- Again, like others have said- glowing rotors on the street REALLY isn't a good idea. Keep that stuff on the track before you kill someones family. thanx.
#20 |
I use the cheapest rotors I can find and they last at least a full season of racing.
#21 | |
Suspetise...
Anytime, buddy!
![]() Quote:
Note: Spencer is a braking wizard. I still don't know how the hell he pulls this off. |
#22 |
Posts edited so everyone can sleep better...
My real worry was more of sudden catastrophic on the track. In my head I just imagine the rotor getting hot and shattering or getting a massive crack that causes loss in the ability to brake as well as damage to the braking system and that was my worry with cheap rotors. But, it seems like people's concerns with cheap rotors are their life-span. So I think I will try them out. If they are dead in a few months, then I will have wasted $40 and learned a good lesson. If they work for 2 years then I will have saves $40+ and learned a good lesson. |
#23 |
NAPA rotor user here. 1.5 years, maybe 6-7 track days and still going. Outlasted the Hawk HPS pads.
Rollin in the DB2 from UCLA |
#24 |
Suspetise...
The Autozone/etc. rotors should have some kind of warranty. If you start getting heat cracks after 2 months or whatever, you should be able to exchange them for new ones.
#25 | |
Buy cheap rotors, push them really hard with hard core race pads and high power engines, and they will crack. But they are cheap, so just check them and replace them. Dime a dozen. Wish I could get real race pads cheap, but no such thing, Race pads cost so much more than rotors.
'Common sense is the most fairly distributed thing in the world, for each one thinks he is so well-endowed with it that even those who are hardest to satisfy in all other matters are not in the habit of desiring more of it than they already have.' Rene Descartes |
| Bookmarks |
| Tags |
| auto, autozone, brake, cheap, good, honda, life, odyssey, parts, rear, replace, reviews, rotor, rotors, solo, span, valucraft |
