#1 | |||||
My B18C Si Hatch Project http://www.honda-tech.com/showthread.php?t=2651768, |
#2 |
Nice project, I have the exact same tranny. Rywire makes motor swaps sooooo easy.
88' CRX Si-B18CR 92' Mustang- Stroked and blown Track whore, Auto-X/Drag 00' Lightning- Daily driver |
#3 |
good luck with your build.sounds like its gonna be a beast.does your gsr tranny say ys1 on the bar code?i got a ys1 and was wondering wat it was.
#4 |
good start
You <3 My Honda |
#5 |
Yes, mine says YS1 on the barcode. But both the GSR and LS tranny is a YS1. I know mine is, since he had a DA GSR that it came out of...
#6 |
Definitely, thank God for rywire...
#7 |
1996 Honda CivicJoin Date: Sep 2009
thats clean, too bad this deuchebag travis couldnt do that with all the 4 ef's he had, keep up the good work...
#8 |
oh okay. thanks man.
#9 |
I took a few more pics of the hatch today before starting to get some things done.
![]() ![]() ![]() ![]() And the B18C that will be going in... ![]() But I did run into a little bump in the road. How in the hell do you get the rear bolt out of the rear trans mount. There is no possible want to get a wrench or socket back there. ![]()
My B18C Si Hatch Project http://www.honda-tech.com/showthread.php?t=2651768, Last edited by WhiteSTi; 09-26-2009 at 05:26 PM. |
#10 |
Will a GearWrench fit in there?
90 STD hatchback, not-stock... Gotta Love [[-]] (()) [[]] [[)) //-\\ |
#11 |
I wish I could find an Si that clean in Alaska..
Nice build.
90 Sedan. |
#12 |
i was able to get that rear mount off but i cant for the life of me remember exactly what i did to accomplish the task lol. i wanna say either i somehow got to it with a 3/8" ratchet with an extension, or maybe i used a ratch wrench. i'm not really sure, but i know its possible lol.
91 Civic Si hatch, b18b1, i/h/e 6000k HID kit, 94 teg cluster 96 Civic Ex 2dr, found a z6! |
#13 |
i was lucky enough to have a wobble socket like not a socket with a wobble extension but a socket witha full wobble capability..
i cant explain it..im sure a short socket with a short wobble extension will work fine tho with a longer extension off of that so yu dont have to bend down as far.. it was easy peasy tho..
boobs. 92 4dr dx boobs. |
#14 |
Dang what a downgrade!
#15 |
ratcheting box wrenches are your friends
good luck with the build! I'm jealous of your hatch man. wish i could find an si for cheap
#16 |
nice project good luck
#17 |
i dont think a gear wrench will fit i had some at the time..and i know i didnt use them.....but maybe..
#18 |
1990 Honda Civic |
dude that is so clean. nice start!
#19 |
Gear wrenches won't work either. It's impossible to get it on the bolt at that angle and even if that was possible there wouldn't be enough room to go back and forth to loosen the bolt. I was hoping there was an alternative to dropping the cross member, which apparently i'm going to have to do. :-(
#20 | |
#21 |
i got it off and if memory serves, i just stuck a wrench on the back side and busted it.
but for some reason remember using a swivel and extension from the top
クリストファー |
#22 |
Today was a semi productive day. I did end up getting that damn bolt our on the rear trans mount. I had to drop the subframe down then I was able to get in behind it wilth a deep well socket, short extension, and a swivel. It was a PITA...
![]() I also got the old suspension out... ![]() And these all ready to go in, Koni Yellows and Progress B Springs... ![]() ![]() I also got around to replacing both front upper control arms, just in case. ![]() ![]() I also removed the charcoal canister and fire wall mounted map sensor. Although I'm not sure If I should cut off the part of the harness for the old map sensor or what to do with the vent tube from the fire wall that went to the charcoal canister. I also need to know what to do with the harness plug for the resistor box... ![]() Also removed the front subframe, waiting to be replaced by a traction bar. ![]() More to come this week, God willing if UPS delivers my helicoil kit that I've been waiting on for over a week...
#23 |
nice build im doin the same thing with my 89 standard should be a fun little car gl with your build
#24 |
Damn photobucket. Anyone know of a web hosting site that doesn't have a bandwidth restriction???
#25 |
flickr or shutterfly.. not sure if they do or not
クリストファー |
| Bookmarks |
| Tags |
| 90, 90si, b18, builds, civic, ef, hatch, ky, louisville, map, problem, project, rywire, sensor, si, tranny |
