| New! Use your Facebook to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendor Directory | My Recent Topics | My Notes | Used Cars |
#1 | |
Couple months ago I was asking here and on 8th Civic if anybody dyno'd their stock car with reflash or Flash Pro. I was told it's waste of money because you need at least intake or header or exhaust otherwise I would loose power!
I knew that's a crap, so here are my numbers: 08 bone stock SI with K&N drop in air filter all 3 runs were done on the same day at 80F and 600ft. The modified map had only less fuel around 13 and smoothed out timing maps and cam angles. ![]() I think it's definitely worth it, 5whp at top end and around 15whp at the Vtec from 6000rpm to 4300. |
#2 |
Cool, I was waiting to see if anyone FP'd a stock Si. if i remember correctly though hondata's website does say that for a reflash you will lose power if you reflash a bone stock Si.
#3 |
excellent, good to know. thanks for posting this.
#4 |
you do know that the reflash configuration and the map tune for a stock si are different right?
FG SQUAD #1 / GET OFF DEEZ NUTZZZZ
#5 |
The flash pro is different then the Reflash. The reflash was a base tune for ppl with the bolt on mods done. Flash pro is fully tunable and much better then the Reflash.
#6 |
Hey Gregster, than and not then
#7 | |
we're talking about the actual calibration itself, not comparing the 2 products.
#8 |
i dnot thnik it mattres as lnog as we get the pnoit.
#9 |
Interesting.... So On a Dyno Dynamics you put down stock with K&N and FlashPro 178Hp. This is good to know, I put down 174.2 with a K&N drop in and Buddy Club exhaust running E85 NOT tuned. Lets me know there is GREAT room for improvment on my car.
Thanks for the post up OP!! It really helped me a lot.
Travis Stikeleather 2006 Civic Si -Daily Driver-, 1999 Civic Si -Sold-, 1994 Acura Integra -Sold- 1983 Civic 1500 4 Door -Still have, K20 project car- |
#10 |
finally someone posted stock tuning with flashpro thanks
#11 | |
We are NOT a nation of immigrants, but a nation of Americans. |
#12 |
Tuned right it has great gains. More so for forced induction. I don't use e85 all the time. If I continue to use it, I will do the necessary mods to support it "Injectors, FlashPro, Fuel pump"
#13 |
I also feel like I should apologize to Hondata. I thought their supplied maps (especially ignition) was pretty messed up, based on my experience with S300, Crome, AEM etc.
I datalogged all runs and had no knock count. And my modified map (took some timing out in some areas and made it leaner from their average AF 12.3 to 13. As you can see it made almost no diference in the curves. Next I'd like to get a header and do the dyno again. But unfortunately with my finances I have to wait after winter. |
#14 |
I'm glad to see that. I only have an intake and muffler on my Si and have been thinking about getting the Flash Pro mainly to lower the engagement of the vtec. I'm not going to be doing many mods for a long time though and was worried I would lose power and it wouldn't be worth it to get. Thanks for the post.
#15 |
good job being the first to try it. dont know why people said you shouldnt but was probably those people that dont know what they are talking about
#16 | |
Did you actually tune with flash pro or did you just mess around with some maps?
The main benefits of using ethanol for fuel is lower emissions and and lower fuel prices. MPG are slightly lower using E85 because more fuel has to be used.
A sale is not something you pursue, but rather what happens to you while you are totally immersed in serving your customer. |
#17 |
Good thing someone finally did it. Thanks for the post. It seems really risky though...spending what is it like $800 for flashpro when Hondata claims it would lower power if you're stock. That was very ballsy move, sir.
#18 |
Not for me, I used to tune cars for living and worked for shop that was authorized Hondata dealer, so I actually had a good deal on it.
I'm one of these guys that rather first spend money on tunable EMS before starting modify a car just to get a full potential out of it. And yeah somebody was right before, Hondata said you'll loose power with Reflash only on stock Si , they didn't say it about Flash Pro. My bad. |
#19 |
How come your Max RPM is dropping off at 7,800 on your 1st 2 pulls? Si Redline is 8,200 stock.
My hobby: http://honda-tech.com/garage/2006-Ho...ChargedSI.html |
#20 | |
op: maybe i'm just blind, but i'm not seeing any numbers with the stock ecu for comparison. i'm not planning on modding my motor anytime soon but i'm sure some midrange power can be picked up with the flashpro so i'm curious about what results people have had. |
#21 |
those are pretty good number for just a drop in filter with flash pro wow
#22 |
I guess he let go off the throttle little sooner, also this dyno didn't have rpm pick up, only was set up by load. So the rpm may differ by as much as couple hundred rpms.
#23 |
FSAE
Any guess why torque decreases on the low cam as engine speed increases? I think with some VTC tuning on the low cam, you can boost midrange quite a bit.
That is, unless the cam profiles were designed to give an early peak low cam torque. Do you mind posting the ignition and VTC map?
1997 ITR #110 -- 228whp/158tq 2.0L 2010 Honda Insight EX - Best MPG 65.8mpg (56 mile RT commute) FS: JDM Skyline RS-X Turbo-C w/49,000 original miles |
#24 |
What is the stock whp for the SI to compare to?
<U>2001 CW ITR #438 </U> Kyle |
#25 |
7800 is peak hp. im guessing peak hp raises once u do mods. cuz i know mine was higher than 7800. but also, idk if any of you with fp have driven with the tach on the display. i noticed when i cruise at 3k, it showed different on the fp. it was a couple hundred rpm off. i think the gauge cluster is off and the fp is correct.
| Bookmarks |
| Tags |
| civic, drop, dyno, e85, filter, flash, flashpro, honda, kn, maps, pro, reflash, si, stock, tune, tuning, worth |
