Anonymous 90 si Turbo
I recently traded my 92 gsr eg hatch for a 90si turbo single cam.. and let the build commence
traded the shell for an xbox 360 and $200 lol then i traded the 360 and a ps3($300 on craigs) My buddy and i went on a badass roadtrip to get the ps3 then go trade for...
75.5mm vitaras, eagle rods, acl bearings
z6 head with skunk2 springs and s2 retainers.. still need an aftermarket cam and possibly some valves just to be thorough
The new project car 90 si
ebay parts soon to be virtually non existent update** i need to get new pics of my engine bay a number of things have changed..and soon the motor will change to the built one
Parts that are going into build:
Tuning:
omnipower 3 bar map
neptune ecu
AEM wideband uego
obd0->obd1 conversion harness
speedfactory for dynotune
750cc rc injectors
Head parts
skunk2 retainers and springs
Hondata intake thermo gasket
Vision adjustable cam gear
Zex/comp 59300 cam
some p&p by me
edelbrock intake manifold
power enterprise 68mm tb
Engine block:
Vitara 75.5mm pistons
eagle rods
cometic headgasket
Acl bearings
Turbo setup:
CXracing .60 .63ar t3/t4 turbo
Tial wastegate
Greddy type R blow off valve
ebay intercooler kit
Spoolin performance ramhorn
3 inch downpipe
oil lines from Go-autoworks!
Aluminum Half radiator and slim fan
Suspension:
KYB AGXs on 2 inch drop neuspeed springs
Etd traction bar
Etd radiator mounts to install half rad.
some ebay rear lower control arms
Revo front and rear camber kit
Want strut bars, st sway bars and complete poly bushing kit
Gauges
Autometer Boost gauge
Autometer oil pressure short sweep electrical gauge
AEM wideband uego
Vision fuel pressure gauge
[U]
Drivetrain:[/U]
Stage 3 ACT clutch
Mfactory lsd
Stock axles
Gearspeed 4.43 finaldrive
plenty of new pics coming soon when i get time to get the swap ready to go in and have time to install all my ****...
let me know what you think
Tuning:
omnipower 3 bar map
neptune ecu
AEM wideband uego
750cc rc injectors
Head parts
Zex/comp 59300 cam
some p&p by me
Engine block:
eagle rods
cometic headgasket
Acl bearings
Turbo setup:
Tial wastegate
3 inch downpipe
Suspension:
Etd traction bar
Gauges
AEM wideband uego
[U]
Drivetrain:[/U]
Stage 3 ACT clutch
Mfactory lsd
Stock axles
Re: Anonymous 90 si Turbo
agxs with neuspeed springs
revo front and rear camber kit
rlca ebay special i bought them for my 88 dx cuz i needed them to put different suspension (89-91) might as well use them bushing upgrade coming soon
hopefully going to be able to get front and rear sway bars... leaning toward st. but open for suggestions also looking for good f+r upper and lower strut bars
update: Got the rear suspension done
and installed my etd radiator mounts
front suspension to be done wednesday! now for some pics...
the old setup was megan coilovers on sensatrac struts the struts are still good just couldnt do there job with how low the coilovers..
revo rear camber kit, agx neuspeed spring and lca installed!
and how it looks from the back.. the sway bar had to come out cuz it didnt line up with the bolt holes on the new lca so it came out.. weight reduction
the little bit of bad the rear trailing arm bushing on the passanger side is completely ripped.. gonna order new rear trailing arm bushings friday.. should help out the ride and handling immensely!
and how my engine bay looks as of now
more to come!
more to come!
you can see a bit of the port work just barely
zex 59300 cam
Update
cracked open the si tranny i picked up dec25 08'.. getting ready to install diff
before pic hopefully i will have it nice and purty the the after pic
Pulled off housing to find this
yummy mfactory!
very clean and the magnet had very little debri plus the synchros and gears all look very good! This tranny was taken good car of from what i can tell..Hopefully i will have the mFactory diff installed soon just waiting on my final drive gear
yep yep i heart my d-series
Update.. Ordering neptune rtp this weekend from j-k-tuning.. and will be converting obd1 and will do a street tune next week.. obd0 with vtec on a switch is far to ghetto
4.43 gearspeed final drive will be here tomorrow... then i just need to order my new seals and a couple new bearings for my tranny
got my full ramhorn manifold installed and dumptube fabed up and wideband installed.. gotta go get a couple hangers added to my exhaust tomorrow cuz as of now its about an inch away from the ground.. pictures tomorrow
Wideband installed just stuck it to the steering column with double sided type for now.
Ramhorn installed, wastegate no longer dumps on the valve cover! i actually have a dumptube on it!
another angle
and the part that was a pain in the *** re running the chargepiping.. i have it setup a bit ghetto now but it works.. picked up a 2inch plastic plumbing elbow from home depot and am making it work for now..
though it has popped out twice now but i will make the coupler hold somehow... and i think i have a boost leak somewhere cause i have 0-1psi till 4k-4.5k then i hit full boost unless its just cuz the turbo and manifold setup
another angle
all my clearances seem to be good downpipe is tucked close to the oil pan and the wastegate has a couple inches till it hits the intercooler.. You have to run a half rad for this manifold(not saying you didnt already know this)
A shot of my port work still gotta finish it up.. but i think it looks pretty good for my real go at it, gasket matched perfectly.. just gotta go buy some real high grit sandpaper and smooth it all out by hand it will clean it up real nice
update: neptune rtp ordered!
should have transmission back together the end of next week.. just gotta find a how to so i don't screw anything up.. more to come as always
and
Well i walked out of work today to find a hole in my radiator so i went to work on fixing it things used to fix;
1x kwik set jb weld
1x bottle of rubbing alcohol
1x chop stick
1x paper towel
1x old butter lid to mix in.
i lost the picture of the damage already some how...
Cleaned the surface with alcohol and paper towel and mixed jb weld and bam
hopefully it holds up
and
1x kwik set jb weld
1x chop stick
1x paper towel
