HELP! installing my DEPO fog lights
bought a set of 99-00 civic depo fog lights, just cant figure out how to install or plug it up. My car is 97 civic. not sure if the harness is different?
First picture shows
2 of the white Male plugs, plugs right into the fog lights.
Blue is most likely the ground, and the Yellow with brown plug is a FEMALE
2nd Picture Shows
Green Plug connects to the Fog Light Switch
MALE Brown plug with red wire has a Fuse Box
Blue wire with Brown plug is a FEMALE
MALE brown plug with black wire
Red wire with ARM
Relay
FUSE BOX PANEL HAS 4 OPTIONAL PLUGS
5 2 3 SPACE 1
Is this the right way of installing it?
female brown plug with yellow wire, connects to the male brown plug with black wire?
red male plug with fuse box connects to WHICH? number of the "optional plugs"? 5? 2? 3? or 1?
and the brown female plug with blue wire connects "TO THE FACTORY FOG LIGHT MALE PLUG BEHIND THE FUSE BOX? is this right?
and the blue wire and red with arms connects to grounds
just wondering if anyone can help me wire this up. thanks!
First picture shows
2nd Picture Shows
Red wire with ARM
Relay
5 2 3 SPACE 1
Re: HELP! installing my DEPO fog lights
Here is the link from H and A accessories on how to install oem 99-00 fog lights. Hope that this helps.
http://www.handa-accessories.com/civ...cfoglights.pdf
can someone post a picture of where the factory oem fog light harness under the dash? i cant seem to find it, the car is 96-98, not sure if that harness is in the same location as 99-00
looks like your missing the wire that connects the under dash harness to the harness sub harness attatched to your fog lights
Here are links for the 96-98 OEM fogs installation instructions hope this helps
1996 2/3/4 door
http://www.hondaautomotiveparts.com/.../17350_01.html
1997 2/3/4 door
http://www.hondaautomotiveparts.com/.../17977_01.html
1998 2/3/4 door
http://www.hondaautomotiveparts.com/.../18767_01.html
1996 2/3/4 door
1997 2/3/4 door
1998 2/3/4 door
here you go, there's a couple of picture in there
http://www.hondacivicforum.com/forum...ad.php?t=61880
its a sneaky little bastard and sometimes you may have to un bolt your fuse box to find it.
i highly doubt your missing it.
that wire is behind the fuse block, I just look for it today myself, installing fog light too. Get in a good position(your back on floor mat), and look behind the fuse block, look for a blue tape/brown plug like the link i send.
BbOi0420
12-12-2014 04:40 PM
OEM_ASSASSIN
09-25-2005 01:23 AM
ShakesTheKlown
03-29-2004 09:19 AM
