> Honda Prelude
Old 11-03-2009, 04:03 PM   #101
megomaniac
megomaniac's Avatar
Default Re: My SFWD prelude
I bought the explicit speed kit but had to modify it cause my alt was hitting the turbo, just used some scrap metal and a 3rib belt, if you do a custom mount make sure you have a belt for mocking up, I had to redo it cause there wasn't a belt that would fit.
So far it's been reliable, just done a few drives down the road street tuning, no abnormal things(yet..). I used a alt from a 88-91 crx I think.
megomaniac is offline Report Post   Reply With Quote
Old 11-03-2009, 04:15 PM   #102
jnv255
jnv255's Avatar
Take a couple more pics if you can, I think we have it figured out, might relocate it.
Thanks
643hp on wastegate
Another broke 11B (Infantry)
jnv255 is offline Report Post   Reply With Quote
Old 11-03-2009, 04:28 PM   #103
megomaniac
megomaniac's Avatar
I don't have any more close up shots, about 13h drive away, for alignment I left the upper explicit mount stock and just modded the lower mount, eye balled it. Using a single belt euro crank pulley.(same as stock one but meant for one 6or5 rib belt). the 3 rib I'm using for the smaller alt hasn't wondered on the pulley either.
edit: haven't taken this over about 6000rpm yet, not home enough to tune it.
Old 11-03-2009, 06:43 PM   #104
jnv255
jnv255's Avatar
Originally Posted by H24Turbo View Post
i have the innovative alternator mount... check that one out. good numbers btw! i should have a dyno video of mine somewhat soon. im shooting for about 650whp on e85.
every mount I have seen is way to low, it hits my intake for the velocity stack. I think we have it figured out finally, to bad the tracks last night if Friday.. Looks like ill be going to the 1/8 mile track, when its open.
643hp on wastegate
Old 11-04-2009, 12:43 AM   #105
ekcoupeh22
that is one badass setup man i like that alot. im bout to build my h for boost and i was wandering what compression ur running that motor at? and i was always told that eagle rods dont hold that kind of power?
ekcoupeh22 is offline Report Post   Reply With Quote
Old 11-04-2009, 08:01 AM   #106
jnv255
jnv255's Avatar
I know someone with 1000hp using these rods and many other 800hp, they'll be fine. 9:1 compression.
Thanks
643hp on wastegate
Old 11-04-2009, 02:07 PM   #107
Apex1972
Thanks
is that Bush giving the middle finger salute?
Apex1972 is offline Report Post   Reply With Quote
Old 11-04-2009, 03:40 PM   #108
jnv255
jnv255's Avatar
Yeah, lol. You gonna go out to Twiggs with me?
643hp on wastegate
Old 11-05-2009, 08:29 AM   #109
117
117's Avatar
In another thread, you mentioned that you had removed the door bars. Do you mind sharing how you went about doing that? I need to remove mine, and I'm trying to figure out a way to do it without damaging the door skin.
117 is offline Report Post   Reply With Quote
Old 11-05-2009, 10:22 AM   #110
jnv255
jnv255's Avatar
Drill out the spot welds,(or whatever u call em) then get a torch to cut thru the bars.. Have water spraying on the paint side to help from messing up the paint. It takes a few hours, but it's still weight that's not needed. You can deff tell when u take them out, the doors are alot easier to shut, lol. I think it was around 30lbs for both.
643hp on wastegate
Old 11-05-2009, 11:02 AM   #111
117
117's Avatar
Thanks! Maybe we talked about this before? My memory sucks! Thanks again.
Old 11-05-2009, 11:41 AM   #112
jnv255
jnv255's Avatar
We have but it's cool, I don't mind helping. Just take it slow and have one other person help.
643hp on wastegate
Bookmarks
billet, box, bullheadgears, dog, ifo, motor, mounts, prelude, transmission, turbo
