#1 | |||||
#2 |
If you are still new to autocross I would just stick with 0 toe front and back. Get the car around -2.0 front camber and -1.5 rear.
Also you can get the car close to 50/50 cross weight without corner weighing equipment. Just put your weight in the driver's seat. Find a garage or flat surface and get all the corners (floor to fender or fender to center of wheel hub) within about 1-2mm. I've done this to my cars and was only off for cross-weights about .3-.5%. Which is like 5-10lbs.
Sponsors: KAM Racing Sports, Falken, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO! Autocross Help Page Buy my Civic parts! |
#3 |
Just make sure you have a good alignment and have fun.
Personally I would start with a stock car and make upgrades as needed. Just out of curiosity what are your spring rates? |
#4 |
how do you measure how tall the corners are if the bottom of the car is all dented and scratched, and the fenders/quarter panals are all beat with a baseball bat?
92 db1-205/135 99 ej8-daily grindin!AIM: ohsnapzafingcu Vouches: h22-hatch,Boostd92 16x7 te37's for sale! ---> http://www.hondamarketplace.com/show....php?t=2540920 |
#5 |
Suspetise...
Uh...what?
#6 | |
all 4 jack points are messed up and folded over from bad hydro jacks, so how would i figure my right height in mm's all around?
#7 |
Suspetise...
Ah. Well, you can find some kind of unmarred part on the underbody to measure for yourself, but it'll be difficult to compare to others under the circumstances.
#8 | |
soooo sell his car to buy a stock car?? lol. anyways. i agree with the specs that civicsiracer gave. |
#9 |
hey op, if this was for the erscc event at pbir i think i might have a couple pictures of you car(red, says P2R on the side). its not my best work but i can pm or put them here if you like
#10 |
I started with those alignment settings running Hoosiers on 13x8.5 Panasports. Not enough camber front or rear. I ended up at -2.5F, -2.1R, 1/8 total toe out F, 0 toe R. (I am running stock SI front sway, ASR 26mm rear).
95 Honda Civic CX Autocross/Solosprint |
#11 | |
i'm new to auto-x and having trouble finding the technical reasoning behind toe/camber setups. so would the above camber setup provide better turn in response and improved stability in cornering? any other benefits? thanks.
| Bookmarks |
| Tags |
| alignment, auto, autocross, autox, civic, ek, good, hawaii, honda, nsxr, s2000, set, settings, specification |
