> All Motor
Old 08-09-2009, 06:35 PM   #1
b20beast83
b20beast83's Avatar
Default rebuilding head with bent valve
Heres the deal guys
B16a Motor....
Rod broke, and bent #3 intake and Exhaust Valve.
Just 2 of them
So i replaced them both from a spare set.
Now, if i pour water in the Combustion Chamber, Water Leaks out the Exhaust and intake port.
Now the valve springs are not installed as yet...
I would like to hear some opinions.
Thanks
b20beast83 is offline Report Post   Reply With Quote
Old 08-09-2009, 06:50 PM   #2
mar778c
mar778c's Avatar
Default Re: rebuilding head with bent valve
Did you check to see if the seat was damaged? Also, did you lap the valves?
Good people:
Synapse Motorsports,JDogg,b18c1_powered _si,CHEETAH, 86si,NA_is_best, Astig, McNews Automotive, geardog, 4g hatch, Innovative Motorworks
mar778c is online now Report Post   Reply With Quote
Old 08-09-2009, 07:09 PM   #3
b20beast83
b20beast83's Avatar
what do you mean lap the valves?
no the seat seems perfect.
Old 08-09-2009, 07:17 PM   #4
mar778c
mar778c's Avatar
Check out this video.
http://videos.streetfire.net/video/T...w-to_80862.htm
Around time 3.20.
Lap in the valves then leak check with water again. If it still leaks then sometimes a heat cycle is enough to get the valve to seal up. If the leak test numbers aren't good then time for a valve job.
Good people:
Old 08-09-2009, 07:25 PM   #5
b20beast83
b20beast83's Avatar
Around time 3.20.
great video
i lapped the intake valve, BUT couldnt do the exhaust, there is too much carbon for the valve stick to 'stick' to the Exhaust valve.
Also spend 4 hours with purple blaster and a toothbrush trying to remove carbon out the ports.
Got any tips for me?
i still got some carbon in there
Old 08-09-2009, 08:21 PM   #6
Fkned
Fkned's Avatar
You are going to have to get the used valves reground as they are seated to the other head and get the seats retouched also if I were you.
Fkned is offline Report Post   Reply With Quote
Old 08-09-2009, 08:40 PM   #7
b20beast83
b20beast83's Avatar
what do you mean re ground?
like in the video?
is it okay to use a drill and wirebrush to clean carbon
Bookmarks
bent, check, checking, engine, head, honda, lapped, leaks, motor, odyssey, rebuilding, seal, test, valve, valves
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
