> Acura Integra Type-R
Old 08-06-2009, 11:22 PM   #1
Dc2IntegraType-R
Dc2IntegraType-R's Avatar
Default rattling noise from b18c5 head??
I have a rattling noise coming from the head on my b18c5. As soon as the car warms up, the noise is completely gone. Anybody ever have a similar problem like this, and why would the noise go away after the car warms up ?
Dc2IntegraType-R is offline Report Post   Reply With Quote
Old 08-06-2009, 11:25 PM   #2
PYITR01
Default Re: rattling noise from b18c5 head??
hopefully its not low on oil.
PYITR01 is offline Report Post   Reply With Quote
Old 08-06-2009, 11:40 PM   #3
Dc2IntegraType-R
na, oil changes are always done on schedule.
Old 08-06-2009, 11:41 PM   #4
Dave_B
Dave_B's Avatar
Built Bottom end?
Dave_B is offline Report Post   Reply With Quote
Old 08-06-2009, 11:44 PM   #5
Dc2IntegraType-R
recently installed spoon cams and valve springs. Adjusted valve lash to stock specs... rechecked it, and still the rattling is there.
Old 08-06-2009, 11:55 PM   #6
Dave_B
Dave_B's Avatar
I know, when I installed the Pro 1 cams in mine, the head noises became evidently louder. However, when I got to the dyno and spoke with my tuner (LHT Performance) he said this was normal. Not sure if that's your case... but in my case it was fine.
Reason I asked if the bottom end was built, possible piston slap at startup.
Old 08-06-2009, 11:55 PM   #7
Dc2IntegraType-R
stock bottom... any ideas ??
Old 08-06-2009, 11:58 PM   #8
Dc2IntegraType-R
yeah, but did the noise go away after the car warmed up, when you had the Pro 1 cams installed ?
Old 08-07-2009, 12:41 AM   #9
TOO MUCH TORQUE
TOO MUCH TORQUE's Avatar
i had the same problem with my LS, the valve clearance was good, it ended up being the bearing in the DIZZY. take off your cap, see if there is fine red powder in the cap.
avoid IMPORTWERK AUTOBODY AT ALL COST... why & his profile:
http://www.honda-tech.com/showthread.php?t=2357615
http://www.honda-tech.com/member.php?u=999517890
TOO MUCH TORQUE is offline Report Post   Reply With Quote
Old 08-07-2009, 10:04 AM   #10
Dc2IntegraType-R
ok thanks for the info, will check that out.
Old 08-07-2009, 08:57 PM   #11
Rey01ITR
2001 Acura Integra
Rey01ITR's Avatar
I have the same exact problem atm i im absolutely sure its coming from the distributer. Im going to replace as soon as possible so if ur not sure jus follow the noise with a tube.
I bet i eat more ramen then you!
Rey01ITR is offline Report Post   Reply With Quote
Old 08-07-2009, 09:45 PM   #12
mannydc2
mannydc2's Avatar
so do i....no good
mannydc2 is offline Report Post   Reply With Quote
Old 08-08-2009, 02:30 AM   #13
TOO MUCH TORQUE
Originally Posted by typerkiid209 View Post
you have a rod knock
dont post advice anymore
Old 08-08-2009, 02:57 AM   #14
civicsiboyboy
civicsiboyboy's Avatar
Send a message via AIM to civicsiboyboy
did you break in the cams? after you installed them
civicsiboyboy is offline Report Post   Reply With Quote
Old 08-08-2009, 04:55 AM   #15
migs
migs's Avatar
Lost Motion Assemblies are knock to be weak which causes a sound that you are describing.
migs is offline Report Post   Reply With Quote
Old 08-08-2009, 09:23 AM   #16
mRek9R
mRek9R's Avatar
Send a message via MSN to mRek9R
Subscribing....
I had this problem as well, but on a P72 Head. We replaced the dizzy with a brand-spank'n new one from Acura, didn't work. Purchased new LMAs...got those put in and yet still that noise during warm-up. The P72 was equipped with ITR Cams and an ITR valvetrain, lashes were stock.
Still to this date, i'm fuk'n clueless...if you find a cure...edu-ma-cate me! 8)
mRek9R is offline Report Post   Reply With Quote
Old 08-08-2009, 09:09 PM   #17
Dc2IntegraType-R
thanks for all the comments... going to take a look at the R on sunday.
Old 08-09-2009, 05:56 AM   #18
Tweakmeister
Tweakmeister's Avatar
Send a message via AIM to Tweakmeister
The injectors are pretty noisy on these cars - could be nothing.
Dizzy is also pretty noisy.
Hogen's [Import Parts] (closed)
'99 SSBP GS-R <--car page (offline)
Colossians 2:8
Tweakmeister is offline Report Post   Reply With Quote
Old 08-09-2009, 11:46 AM   #19
jdmeg6b18b
jdmeg6b18b's Avatar
Send a message via AIM to jdmeg6b18b
I have the same issue, I believe the noise is coming from my dizzy as well.
ITR #864
WTS: ACT 6 puck HD clutch kit/prolight flywheel $480
WTS: 2001 ITR dash harness
jdmeg6b18b is offline Report Post   Reply With Quote
Old 08-09-2009, 11:51 AM   #20
Dc2IntegraType-R
Did you change the dizzy, if so did this solve the problem ?
Old 08-09-2009, 12:07 PM   #21
jdmeg6b18b
jdmeg6b18b's Avatar
I have just been living with it, no money for new dizzy.
ITR #864
Old 08-09-2009, 07:25 PM   #22
IanBlake
IanBlake's Avatar
i have the same problem ... apparently is a common problem
IanBlake is offline Report Post   Reply With Quote
Old 11-05-2009, 07:30 PM   #23
Seto-Initial-B
Seto-Initial-B's Avatar
Send a message via AIM to Seto-Initial-B
So this is also happening to my head. Its coming from the same area near the dizzy.
It started when my p73 dizzy ignitor was going bad. I heard it befor replacing it with a P72 dizzy. Me and my buddy figured we check the valve hight and it checked out fine.
I took it to a common atx dyno tunner name OMAR. He also feels it may be the lost motion going out. Its like the oil and warming up makes it get alil better but doesnt exactly go away.
I am going to try to have the cams pulled and rocker arms to check the lost motion for any defects.
Now it is possible that the dizzy is making this crazzy noise but I just cant see that being the issue right now. It sounds like the noise is deep in the head near the fuel injectors.
Glad to have found this thread... makes me feel alil better that I am not alone on this search for an answer.
i will post back when i figure it out and broke as a joke becuase of it or a blown head whatever comes first.
Seto-Initial-B is offline Report Post   Reply With Quote
Old 11-07-2009, 12:30 PM   #24
Chicas
Chicas's Avatar
I thought mine was coming from the head, but as it turns out it was piston wall clearance issue. no biggie for me, as it dissappears quite quickly (i think half a minute after startup, once the rings quite expand). IDK if its the same with you though
Originally Posted by civichua View Post
ok so i've been talking to my friend (viet_tec) about making my b16 a V6..he suggested custom bolting 2 more cylinders on to it.. any suggestions or tips would help! Current Mods: Type-R platinum Short Shifter..... something different yo!!
Chicas is offline Report Post   Reply With Quote
Old 11-07-2009, 04:44 PM   #25
Seto-Initial-B
went to visit my friends at the acura mcdavid dealer ship shop in the back. Pulled the valve cover off and made the proper crank turns for TDC on each piston. We found that the mid rocker arm on the intake # 4 piston side was stiffer then the rest. Meaning that the LMA's is starting to seize and cuasing the noise discribe by this thread.
Its not gone ... we could push it down but with more force then we had to for the exhuast and 1,2,3 cylinder areas....
TIME TO RE AMP THE TYPE R HEAD... might aswell when its going to be tooken apart...
Bookmarks
08, accord, acura, b18c5, clearance, head, honda, integra, lash, lost, motion, noise, rattle, rattling, valve
