Oil Change Blows GS-R??
So, about two days ago i decided to change my car's oil, since it was about three and a half months since I had last changed it. I jack it up, drain the oil, change the filter, blah blah, Royal Purple goes in. this is the oil I have been using since I bought the car. (previous owner used it, too) I put in 10w30, and when I go for a drive, pressing the throttle I hear a little ticking noise while in first gear, second gear, as it fades away when my exhaust gets louder. It bothers me alot, just wondering what it is. It happened before I did the oil change, but it was more rapid ticking, now it is slower and louder, sounds like something is hitting on something else, but it cant be heard when the motor is idling, only when I press the gas, So yeah... Help.
btw its an 01 gsr with about 80k miles
Re: Oil Change Blows GS-R??
Ummm... did you seriously post this thread before actually checking if there was oil in the motor?
It's possible you double-gasketed the filter. I did this twice.. The o-ring was stuck on the block from the old filter and you put the new filter on. On the first crank all the oil was on the floor in the first 5 seconds.
or not. i spun a bearing since the place that changed my oil ****ed up and cracked the gasket on my oil filter. it can happen and it probably did to you also. time for a rebuild! that is what i am doing now.
Check the oil level and for leaks. If everything looks OK see if the ticking increases with RPM's. It's pretty easy to distinguish a ticking sound that's coming from the block vs. the head.
Yeah because a ticking sound that was present prior to the oil change and still after automatically means an 80k mile motor needs rebuilt. If that was the case then about 90% of hondas would need a rebuild.
X3 symptom of Spun Bearing, you will hear ticking scraping nose slowly as day go by it get louder and louder then a spike on open throttle car die. That what happen to me me when I spun my bearing
are you serious? if what he says is the case then the ticking getting incresingly louder over a small period of time IS NOT valve lash. the lash does not get out of whack in that short of a period of time. use your head buddy. im not saying either one of us is right or wrong but using your brain you can come to the conclusion if you had the mechanical experience. and its not always easy to tell where the ticking is coming from. thats why they make stethescopes for motors.
Regardless, check the oil level and for leaks. If you don't know what you're doing, take the car somewhere reputable to get it looked at.
My mechanical experience? you spun a bearing after letting some two bit shop change your oil. Nuff said. The sound could have changed because there's brand new oil in the motor. The OP hasn't given the type of detailed information needed to make a conclusive diagnosis.
what was that ball sack? lol dont get mad. you dont even know what happened or the situation so stop acting like you know. ****ing retard make yourself look like a dumbass. how embarrasing...
Just from a third party perspective.. VTEC PRODUCTION sounds like an angry teenager. Get a grip bro, know one here could possibly know from a few paragraphs if this guy has ruined his engine... not me, not you. Lets get some more information before we start drawing serious conclusions that require a lot of money and effort. And you honestly should not need a stethoscope to tell hear the difference in a head TICKING and the block KNOCKING. Generally heads don't knock and blocks don't tick, unless its spark knock.
huh? no dude, if I "double-gasketed" the filter that **** would squirt all over the motor and floor right when I started the motor, happened to a couple of people I know...
problem solved though,
your going to criticize someone else's mechanical ability when your that jack *** that;
1. let some one else change your oil
2. didnt notice oil leaking from your car
3. assumes you know what this guys problem is from one paragraph
just stop man
im willing to bet it was valve lash?
op what was it?
ODbuilt
13
10-15-2013 06:33 PM
peel17
09-17-2005 01:21 PM
