BLOX is dedicated to the development of high quality and affordable performance products for today's import and sport compact enthusiast. Each product is designed and manufactured using cutting-edge technologies and materials and tested using rigorous standards, offering durable products and reliable performance. Each BLOX product is designed to work with one another, giving enthusiasts the proper foundation and building blocks for developing the right performance combination.
***Limited Time Sale on Killer N/A Build Up***
Killer B-Series Combo of the Century!!!
Package includes:
Cam Shafts
Blox Dual Valve Springs Set
Titanium retainers
Retail at over 980!!!
Cam Package is on Sale for 665$ Shipped
Special Price 665 Shipped
Shipping Valid within 48 states usa only
Blox Performance Cam Shafts
BLOX high performance camshafts offer the enthusiast increased horsepower and torque over the entire RPM range, through various designs and custom profiles.
All camshafts start off as raw castings sourced from OEM materials. Each is then manufactured using the latest design software and chill-casting technologies. All camshafts are CNC-ground to precise and exacting tolerances and specifications.
Below is a chart of valvetrain recommendation with each camshaft series.
Tuner Series - Uses OEM camshaft lobe designs, with BLOX profile specifications.
- Type A: Okay to use with factory valvetrain components.
- Type B: Must use with Blox dual valve springs and Ti retainers.
- Turbo: Must use with Blox dual valve springs and Ti retainers.
- Type C: Must use with Blox dual valve springs and Ti retainers.
D Series
BXCM-20103 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 1
BXCM-20100 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 2
BXCM-20101 BLOX Tuner Series, Cam Shaft, SOHC VTEC D16Y8 1996-2000 Civic EX Stage 3
Some Specs for you guys:
Type A:
http://www.bloxracing.com/products/c...bxcm-10101.pdf
Type B:
http://www.bloxracing.com/products/c...bxcm-10102.pdf
Dual Valve Spring Set
Blox Racing dual valve springs are an excellent OEM replacement. Designed to work with both OEM and aftermarket cams. Recommended for mild to moderate street motors with a maximum of 9500 rpm’s. This valve spring combination was manufactured to produce less seat pressure than most aftermarket valve springs thus reducing wear on cam lobes. We recommend that you use Blox Racing Titanium Retainers with this set up.
BXTP-10300 B-Series DOHC Dual Valve Spring Kit, B16A - B18C1/5 1.6/1.8
BXTP-20301 D-Series SOHC Dual Valve Spring Kit, D16Y/Z 1.6L
Titanium Retainer Kit
Blox Racing retainers are made out of forged Titanium providing incredible strength and a reduction in weight. When thier retainers are used with thier valve springs they feature a snap fit design which keeps the spring and retainer rotating together thus greatly reducing wear
BXPT-10400 B-Series DOHC VTEC Titanium Retainer Kit, B16A - B18C1/5 1.6/1.8
BXPT-10401 D-Series SOHC VTEC Titanium Retainer Kit, D16Y/Z 1.6L
How to order:
Payment Options:
Paypal---Money Order/Check/Cashiers Check.
California residence must add 9.75% Sales Tax
Paypal ID: Racerswholesale@gmail.com
Paypal orders--- IN THE NOTES PLEASE FILL OUT THE FOLLOWING FORM
Full Name
Forum name/ User ID
Tel Number
Item ordered/ Options/Color
call 408.515.4296 for Visa/Mastercard
Local Pick up:
Spoolin/Redzone Performance
43257 Osgood Rd
Fremont, CA 94539
