01 prelude timing belt install
Old 06-19-2009, 07:56 AM
blackccoupe's Avatar
Default 01 prelude timing belt install
any got a link to how to do a timing belt on a 01 preude h22 i searched forever and couldnt find what i'm looking for please let me know thanks guys
Old 06-19-2009, 10:20 AM
95greenlude's Avatar
Default Re: 01 prelude timing belt install
HELMS
Old 06-19-2009, 10:58 AM
meanshyguy's Avatar
^^ If he had a helms he wouldn't be asking here, why are you always asking people to search instead of helping out? Do something productive with your time.
Old 06-19-2009, 11:03 AM
^because there are free helms manuals available on the internet....that he can search for and do it on his own time....not my time.
Old 06-19-2009, 11:35 AM
meanshyguy's Avatar
He's asking for the link, which would have wasted your time just as much is it did writing your reply.
Here it is man, I hope this is what you're looking for:
http://www.preludepower.com/forums/s...g+belt+install
Old 06-19-2009, 12:01 PM
gstrudler's Avatar
Point being, this is best done with the assistance of the Helm's manual. OP, you can buy it at www.helminc.com, it's the best purchase you can make for your car.
Old 06-19-2009, 05:06 PM
thanks for the link man looks like bitch to do any idea how much the dealer charges lol
Old 06-19-2009, 05:22 PM
gstrudler's Avatar
Most will be around $800-$1k; about 70% of that is labor. If you don't mind putting the work into it, it's surprisingly not that bad.
Old 06-19-2009, 08:29 PM
Lil. Cease's Avatar
Its not that bad bro. The most annoying part will be getting the crank pulley bolt off. Other than that its not that bad (I'm actually doing mine right now). Try to save yourself some money and go for it. Here is another write-up that helps:
http://www.preludepower.com/forums/s...d.php?t=288086
And if you want to do the auto ---> manual tensioner conversion:
http://www.collectiveracing.net/crfo...ff073067eee5fe
Old 06-20-2009, 05:18 AM
ok what if i ruse the auto tensoiner or is this not a good idea?
Originally Posted by blackccoupe
ok what if i reuse the auto tensoiner or is this not a good idea?
Old 06-20-2009, 05:30 AM
2ed6sbandzc's Avatar
Icon5 Re: 01 prelude timing belt install
where you from ill do it for $300 plus parts.
Old 06-20-2009, 12:27 PM
Inextricabledrvr's Avatar
At my local Honda dealer they were charging me 325 for timing belt change. This is just for the timing belt. + any other parts that need changing. I was surprised on the quote he gave me, but thats what he gave me.
Old 06-20-2009, 11:39 PM
meanshyguy's Avatar
You should go through the link over and over until it sticks to your head, then go get that parts, that's what I do if I decide to do something on my own, good luck!
Old 06-21-2009, 08:40 PM
TheJGB3's Avatar
Here is the timing belt procedure for the 5th gen
Valve cover install and torque sequence
Old 06-22-2009, 02:28 PM
thansk alot guys gonna do it this weekend dont look to bad a lil different from my bseries though lol
Old 07-11-2009, 02:51 PM
k i ordered the parts, except the dam washer that goes behind the bolt that holds both pulleys lol its says the size is 40mm x 1.5mm, but noone has thatsize, anyone know what other size washer will work. honda was out of them go figure please help me out thanks
Old 07-11-2009, 03:57 PM
Kronn 98SH's Avatar
What was the total price for parts? If you spent more than ~$200, you got raped.
Old 07-11-2009, 04:05 PM
what ? i'm asking what size the washer is lol
Old 08-30-2010, 09:58 AM
JDMkidGSR's Avatar
What the diagram doesnt say is to put the timing belt on first, align the timing, and then compress the auto tensioner and slide it in. BTW I did this on a sunday and dealer was closed for me to get a compressed holder tool...so I made my own custom one, and it worked perfect.
Old 01-17-2011, 07:07 PM
dre2day's Avatar
I will be attempting my first timing belt change this weekend. Majestic Honda was the cheapest, even with my discount at my local Honda they wanted $650 just for parts. You guys think my parts are over kill lol? Well I have a small oil leak coming from the timing part of my engine, i hear the belt flopping around at times, and its about time my lude gets the tender love and care she deserves!
Let me know if I am forgetting any parts!
Majestic Honda
14520-P13-013 ADJUSTER, AUTOMATIC $72.19 $72.19
91233-PT0-003 OIL SEAL (27X40X8) (NOK) $5.02 $5.02
15114-PT0-003 GASKET B, OIL PUMP (ARAI) $3.30 $3.30
91212-PAA-A01 OIL SEAL (40X52X7) (NOK) $6.03 $6.03
91213-PR3-004 OIL SEAL (29X43X8) (ARAI) $4.98 $4.98
56992-PDE-E01 BELT, POWER STEERING PUMP (MITSUBOSHI) $13.11 $13.11
38920-P0F-J01 BELT, COMPRESSOR (BANDO) $18.95 $18.95
13405-PT0-004 BELT, BALANCER TIMING (UNITTA) $32.11 $32.11
19200-P13-003 WATER PUMP (YAMADA) $63.70 $63.70
19223-P13-300 RUBBER, WATER PUMP SEAL $2.00 $2.00
19222-P13-300 GASKET, WATER PUMP $2.70 $2.70
14400-P13-014 BELT, TIMING (155YU24 A-555) $49.82 $49.82
13407-P13-000 SPRING B, BELT ADJUSTER $2.18 $2.18
13415-P0A-000 BRACKET, BALANCER BELT ADJUSTER $6.06 $6.06
14510-P13-003 ADJUSTER, TIMING BELT $109.48 $109.48
13404-P13-003 ADJUSTER, BALANCER BELT $51.45 $51.45
11811-P13-A00 SEAL, TIMING BELT RUBBER (LOWER) $30.26 $30.26 - Additional Part possible needed (refrence 06111-P5P-020)
14517-P13-003 gasket $1.32 $1.32 - Additional Part
90051-PT0-000 sub belt adjuster bolt $3.56 $3.56 - Additional Part
06111-P5P-020 Gaskets for side engine $34.51 $34.51 - addon (says discontinued, if avialble remove other related gaskets, majestic says its on backorder no arrival date)
15113-P13-003 Oil gasket a $2.72 $2.72 - Additional Part
Shipping Information
Shipping Method:Fedex Normal
Subtotal $515.05
*Sales Tax: $0.00
**Shipping Charge $34.88
Handling Charge $4.95
Total $554.88
File Type: txt
Old 01-18-2011, 04:31 AM
nus_dogg's Avatar
Price is a little over kill but you'll be happy in the long run cause everything's Geniune OEM parts.
At this point, I would definitely recommend you to do an H23 manual tensioner conversion and get rid of the Auto Tensioner as it tends to fail over time and cost you around 80-120 depending where you get it from. After the conversion, you will never have to worry about the Auto Tensioner when you replace the t-belt in the future. If you search, there's thread on what you need to complete the conversion and to go about the installation.
Good Luck!
Old 01-18-2011, 09:47 PM
dre2day's Avatar
Yea I guess I need to do the conversion. I found the kit for $89, but I am not sure if the belts will still fit or if I have to get h23 belts.
IRP list the parts as all genuine, anyone have experience with their kit?
joanie
05-27-2014 06:20 AM
JF76
06-25-2011 10:34 AM
Steve40th
Honda CR-V & Element
10
10-13-2010 08:03 PM
rayscar
10-21-2004 01:36 PM
Quick Reply: 01 prelude timing belt install
