89 CRX Si Instrument Lights not working(dash board)
Old 06-18-2009, 01:09 PM
hellraiser7492's Avatar
Default 89 CRX Si Instrument Lights not working(dash board)
I checked all the fuses to it and everything works except the lights that are supposed to come on when the headlights are turned on.
(i checked the dimmer)
Old 06-18-2009, 01:11 PM
BSeriesRescueteam's Avatar
Default Re: 89 CRX Si Instrument Lights not working(dash board)
Turn the **** on the left side of the instrument cluster by the steering wheel clockwise? Not trying to sound like an *** but that might help if you havent checked that.
Old 06-18-2009, 01:14 PM
I did i guess i should of wrote that in here huh? i edited it.
Old 06-18-2009, 01:33 PM
My old title sucked.
LudeEFv2.4's Avatar
are your tail lights out as well?
Old 06-18-2009, 01:41 PM
TeamRedline89Hatch's Avatar
Replace the dimmer switch, might have gone bad.
Old 06-18-2009, 02:23 PM
i checked that already wasn't it
no they are not.
Old 06-18-2009, 03:48 PM
T.Rex's Avatar
you check the bulbs
Old 06-18-2009, 06:15 PM
Originally Posted by T.Rex
you check the bulbs
The thing is, theres like four bulbs that light up the ash when it's on so i dont see how all the bulbs could of gone out at once
Old 06-18-2009, 08:57 PM
blue5thgenbb's Avatar
Almost the same thing just happened to me in my 2001 Prelude. However, my taillights and parking lights also stopped working. Dimmer is fine, fuses appear to be fine, possibly one burnt taillight(just happened tonight so no time to replace). Would love some insight to this. Kind of a pain..
Old 06-19-2009, 06:31 AM
GLI
GLI's Avatar
Pull out the voltmeter and start checking the connections behind the cluster. You probably might have a bad connection if everything else was ok...
Old 06-19-2009, 02:02 PM
Creator's Avatar
If your lights for the cluster/interior lights and tail lights go out it is a fuse. You need to check again. Honda has been doing these together for years, solved this problem in my 89 hatch twice and a 2001 accord about two weeks ago. I think that it was fuse #8 under the steering wheel on an EF anyways.
Old 06-19-2009, 08:18 PM
phuckphate's Avatar
there is alittle box on right side of steering wheel under dash with about 9 or 11 wires going to it some kind of lighting control module replaced mine solved problem on 90 dx just a thought
Old 06-19-2009, 08:19 PM
phuckphate's Avatar
also not on any wiring diagrams that i found traced wires back
Old 06-20-2009, 09:45 AM
I checked the fuses; again. There are unfortunately no blown fuses. I started messing with my turn signals and interior lighting and then they randomly came back on.. Kind of a good thing and bad thing. Does anyone think this could be linked to having HID's? (the system is wired correctly).
Old 06-21-2009, 07:32 PM
pumpkin129's Avatar
if it is like the 88 cluster all the bulbs have to be good to complete the circuit. If one bulb blows the circuit is incomplete and none of them work
Old 06-21-2009, 11:37 PM
8894honda's Avatar
Have you took the cluster complete out and look at the back of it? I had the same problem. My problem was I burnt the back of the cluster out Here is a picture. You know you can try to jump the dimmer switch to see if that is your problem
DEA7H
09-30-2008 10:33 AM
Civic_kid_666
01-08-2008 01:40 PM
Timmah!!
08-01-2007 09:28 AM
shaferz
02-29-2004 07:19 PM
Quick Reply: 89 CRX Si Instrument Lights not working(dash board)
