Need help with 96-00 civic fog lights....
Where do these 2 go to?
I know 1 of them is suppose to go into fuse #5 but what about the other wire? there are 3 plugs total. 2 female single pin plugs and 1 male single pin plug
I already connected the 1 male single pin lug to another plug that was taped up with blue tape as instructed
These switch light harness are similar to the oem ones. Its not a depo brand and it doesnt connect straight to battery. Im lost on these instructions.
http://www.passwordjdm.com/Install_N...tall_Notes.pdf
I just need to figure out the 2 plugs mentioned on top.
Re: Need help with 96-00 civic fog lights....
See #25 in the PDF link you posted. Connect the switch harness wire (red) and the fog light wire (red) together.
see the problem with that diagram is that I dont have those red wires.. it doesnt come with it unless its depo or something.. the red wire you see in the background on picture 1 (not the red one im holding) is for my old fog light setup which were depo..I just forgot to unplug it.. anyways I bought new fog lights and the switch and fog harness are very similar to oem. As you know depo fog lights connect directly to the battery whereas oem or these fog lights dont..
I wired fog lights on my 97 hx and all I bought was the oem switch, bumper harness and the one for under the dash that connects to the light switch and I belive the other end went to a brown wire or connector. I never had to plug anything into the fuse box and everything I got came straight from the dealer. The one under the dash came with an inline fuse holder but I also needed to get a relay which is the same one that the horn uses oh and the relay on mine didn't go in the fuse box it connected to the harness itself.
you in cali... where about`s. just askin maybe i can help with the set up. ok well i will update this message in da morning, or you can call me personally in regards to your situation. my personal email is battleholexkrue@live.com, i will stay online for another hour if any ???`s tonite... O.C. time 714 area
ok i found sumthing that may be detailed and usefull with sum pic`s. https://honda-tech.com/forums/lighting-107/fog-light-loom-install-96-98-civic-2409640/
i hope it helps
i hope it helps
http://www.hondacivicforum.com/forum...ad.php?t=61880
heres another
heres another
sorry those 2 doesnt help.. I will take it apart and take a picture of exactly what wiring I have.. its really weird compared to my old depo ones.. the old depo ones connect straight to the battery whereas these dont..
DOMAN!EJ8
16
09-02-2009 10:17 PM
alacard
22
01-08-2008 06:28 PM
