Stock GSR turbo 444whp/317tq, 57trim, E85, 175k miles
Well I recently picked up a Daily driver, this car used to be my Daily and has been for the past 3 years. i always said the only thing that was holding me back from turning it up was a Daily .
I have put about 32k miles on this turbo setup on the car, along with about 200 1/4 mile passes. The car is not babied .
1994 GSR with 175678miles
ITR cams
ITR valve springs
Blox Intake manifold
Tsudo 70mm exhaust
AFI Street series turbo kit 3in downpipe
57Trim
AEM Tru-Boost
AEM wideband
Precision 880cc injectors
Single Walbro 255
Tuned on E85 with Crome Pro
boost was 16psi@8200rpm
We decided thats all we are willing to go with this turbo .. boost was falling off uptop and the injectors were about maxed out... If i had some bigger injectors and a different turbo we would have gone higher, but im fine with the power where its at... its a blast to drive on the street thats for sure!
ITR cams
ITR valve springs
Tsudo 70mm exhaust
57Trim
AEM Tru-Boost
AEM wideband
Single Walbro 255
Re: Stock GSR turbo 444whp/317tq, 57trim, E85, 175k miles
Thanks Ant! i wish i had you 35R!?!?1
the car is still not that light, 2600lbs with me in it with no interior, if i can get it down to 2500lbs then i think i have a better chance, unless i can get the car to cut a mid 1.6 60ft and a good 330... right now at 2600lbs and 444whp it says its a 129 trap...it would be nice to be able to punk off a 10!
Make mine whatever you want
Nice Myles! Great numbers on your freak stock motor! It still scares me though, that thing has been runnin hard for a while lol. I'm considering going in on Friday if there's time and get a tune on either race gas or E85 . Unless something goes wrong, you can expect to see me out at PIR on Friday.
I think you will punk some 10s strip that bitch down! I cant wait to get down to woodburn and run on a real track again ! Let me make a guess on tunning? Englishraceing???
great numbers nice to see its still going hard do you still have ac and ps and **** ? back seats spare tire ? with 200 passes under your belt i see a 11.0 -10.8
damn nice job, you just keep pushing the limit of that motor What numbers where you previously making? was it 415whp?
Stock block setups are just funny as hell to me, especially setups with the kind of mileage you have on yours.... In for a 10sec slip
HELLO,GOOD MORNIN'
that's what makes it fun.
Yooooo......do it up big time dude. Try and get it down to the weight of my car and then maybe you will get some 10's!! hahaha j/k....
Goodluck with it dude, loving the high hp on the tired old stock engine.....something about it makes me giddy on the inside! hehe
TJ from English Racing in Camas WA(www.englishracing.net)... This would be the 2nd highest hp Stock gsr he has tuned, First one was 460whp@21psi on an SC61 (that car went 10.9@130).
The car doesnt have AC and it has PC but the belft came off along time ago and i just havent had the Will to put another one back on. No spare tire either. Its about 2600lbs even with me in it. Im going to do some weight removal here in a week or so and hopefully i can get it down a bit ..
As far as the 10 sec pass, Well i will need to be on a good track that Hooks and i will only get a max of 2 runs. As soon as i go under 11.49 they start to bitch alot here. My guess is its going to be a low 11 if i can bang all the gears and get a good 60ft... Most Hondas around here need to be in the low 130's traps to be able to run a 10 sec pass. unless i can get the weight down at that power level i dont see it going 130+...
Heres the car at BOTI woodburn:
It would definitely be difficut to make a 10 second pass in Portland lol, but it may be possible on a nice day at woodburn if you got a bunch of passes in. You need a roll bar!!
You plannin on taking it out this weekend?
Yeah 10 sec pass @ PIR will not be that easy
