5Zigen Twin mode clutch system??
i am currently working on a 99 civic coupe and i am looking to install the 5Zigen Twin mode clutch system into the civic i was wondering if anybody had any info on this or insit. i already have the 5Zigen Twin mode clutch setup im just not sure were the wires and clutch lines run. ive tried searching and all i found was people asking about them for subarus and so on. thanks in advance
for those that dont know what i am talking about this is the 5Zigen Twin mode clutch system.
5Zigen Twin Mode Clutch System
MSRP: $2100 Avg Rating: 5/5
Description:
Depressing the switch turns the system on, and the transmission will act like a clutch-less shifter, where each push of the gear **** will raises a gear, and each pull of the gear **** will knock down a gear. The switch on the gear **** is to activate an actuator connected to the transmission oil pressure line. Actuation is controlled by a motor which mechanically disengage the clutch.
[img]http://www.subarureview.com/images/869.jpg[img/]
Description:
