How can I acheive 12 sec on a GSR Allmotor setup
Hey guys. I need some ideas on what can I do to acheive 12 sec on a gsr setup. Please no boost, nitrous , or superchrged. Any help will be greatly appreciated. Thanks.
Re: How can I acheive 12 sec on a GSR Allmotor setup
it will cost way to much IMO... but build the motor which you should know that. thats pretty much all you need to know ha. upgrade all the main parts in the head and block and bam your in the 12's
What chassis are you using?
b18c block with civic type r pistons and stock head with ctr cams with camgears tuned, chipped ecu. Ive seen many of these setups run high twelves, with slicks in a light hatch chassis of course.
I know this has nothing to do with this post but, my speedometer quit working so I replaced the speed sensor and it still doesnt work . Can anyone help me out I DONT HAVE A LOT OF TIME TO WORK ON IT AND I FINALLY HAVE A WEEKEND TO KNOCK IT OUT THANKS IN ADVANCE.
OP, I would think in a stripped CX EG frame with high compression pistons, some good cams, port jobs here and there with an awesome tune, and you could run HIGH 12's.
Do some research and steal ideas from other people's setups. Check the All Motor subforum, search for all motor quarter mile time threads; stuff like that. A lot of it depends on the driver too. I've seen guys run at the local drag strip, where they ran up to 4 seconds slower than what their cars should have been capable of running. And don't just focus on the engine, think about stuff like suspension, tires, and drivetrain. You're really not going to get any spoon fed answers here, even with the horrible search engine.
the question really is, can you afford the setup of a 12 second GSR n/a? hmmmmmm... hehe in reality though stop being so vague at least tell us what kind of car jeezus.
http://www.hondamarketplace.com/show....php?t=2678683
Thats my brothers car, look into that. He has a built all motor Type R in the 12s his build is explained in there. That should give you some idea as to what direction to go.
blu_ej
09-11-2010 09:39 PM
91sicivic
10-14-2004 09:37 PM
