Main relay click's?
Old 04-22-2009, 10:42 AM
4gen5thtime's Avatar
Default Main relay click's?
So I'm waiting for my ecu to get here and went to the j/y to get some ed(88-91) parts, sorry long story. But I found a 94 hatch and pulled the main relay just because its allways good to have an extra I've noticed from my 88-91 ownings to always have an extra. So I did the test on it to check continuity and it clicks when I hook up power to it and reads out 0. That means it's good right? This is the test I used.
Old 04-22-2009, 02:31 PM
Default Re: Main relay click's?
any one got anything on this?
Old 04-22-2009, 02:40 PM
fallbacdun's Avatar
if it clicks then it working
Old 04-22-2009, 02:48 PM
civic_driver's Avatar
There are 3 tests in this main relay "test." When you check for continuity, does your multimeter beep? If so, (and if you followed the steps correctly) that means your main relay is good. Also, 0 ohms, is good, yes.
Old 04-22-2009, 03:01 PM
Ha, I took a shower and was thinking about the 3 clicks when you turn the key. Duh, sorry I'm an idiot. But hopefully this will answer some one else's relay quetion. Thanks for the input though guy's.
Old 04-22-2009, 03:46 PM
The best way to test the main relay is as described in the diagram.
Wildwilly3
03-05-2019 04:41 PM
deepdownpaul
11-08-2009 05:15 PM
BigDaddyRich
03-30-2005 10:05 AM
C8V6C
01-20-2005 09:46 PM
Quick Reply: Main relay click's?
