#1 | |||||
Custom alarm installs pm me for details FS: B Series Parts http://hondamarketplace.com/showthread.php?t=2640767 FS: K Color Fog Switches http://hondamarketplace.com/showthread.php?t=2624551 |
#2 |
pics would help
#3 |
pics will come but basically there is shit under and in the clear coat, there are areas where it was wetsanded and polished and whatever was in the clear, took the clear and paint off with it. There is also a lot of what appears to be dirt (or specs) of something in the paint.
#4 |
Sounds like poor prep work left dirt and "junk" on the car which they painted over.
How do you owe the shop money a year after the work was done? |
#5 |
LOL LONGGGGGGGGGGGGGGGGGGGGGGGGGGGGG story, and if I keep it, someone owes me a new paint job....
#6 |
....so, are you going to post pics?
#7 |
when i get my lens back, I cant get close enough pics with my 55-200mm lens.
#8 |
1992 Honda CivicJoin Date: Sep 2005
man. that sounds like poor prep work, bad guns, and a bad booth. you should either get a respray for their poor work.
#9 |
i got pics hold on
#10 |
It sounds like you got a little over spray on the base coat and the clear coated over it, and second it sounds like they didn't mix the hardener right not mixing the hardener can cause chipping of the clear coat in some cases . With the over spray they must of sprayed some other job by your car and it got on you paint .
All in all a body shop is suppose to get the customers approval and OK about the jobs they do, if there is anything wrong upon picking up your vehicle we as body shop owners are suppose to correct it to meet your satisfaction, i run a body shop so i dealt with little complaints . Last edited by Paul-R; 03-13-2009 at 02:27 PM. |
#11 | |
#12 |
#13 |
1999 Honda CivicMy Garage |
trash in the paint/ under the clear... :thumdown: kinda looks like ash to me... were they smoking while they painted? that would suck if they did!!!! no matter what it is.. complain to them.
#14 |
no its not ash, that is the result of the nip and buff and the wet sanding taking off the clear and paint.
#15 |
1998 Acura IntegraMy Garage |
damn that blows mikey... that paint job was super expensive too!
#16 |
It's dirt under the undercoat.
Check out the BASF commerical lol http://images.honda-tech.com/set1/smile/emsmile.gif http://youtube.com/watch?v=6RLM-QyrpS4 "We are all here for one purpose.To show our love to H-O-N-D-A-S http://images.honda-tech.com/set1/smile/emsmile.gif http://images.honda-tech.com/set1/smile/emthup.gif." |
#17 |
thats booty
#18 |
same thing i was thinking
'99 Civic Hatchback CX - sold 8-2-09 [Twisted] I <3'd my Honda |
#19 |
well whatever it is/was its definitely avoidable and should not be there?
#20 |
poor prep and a dirty booth....did you see the booth they used? some1 prolly opened the door or left it open when they were painting the car and you got stuff iin the base and clear.
\ can you feel bump when you rub your finger over them or is it kinda sharp? bump means its under the clear kinda sharp is in the clear. |
#21 |
thats def not normal. Trash in the paint and in the one pic it looks like there was a few paint drips on it
94 GSR |
#22 |
its both in and under the clear
#23 |
i think they also had a bad gun, that's where the dark spots of the blue is coming from.
#24 |
so regardless of what exactly it is, the fact is that it shouldn't be there and the car should be resprayed?
#25 |
i would not blame that on the gun, the light and dark spotting is the painters fault for not having even coats with equal overlap on each spray pass.
those spots and will not come out the are under the clear coat, i bet they sprayed the base coat then waited a while before the clear coat so dust and junk could settle down on the base coat before the clear was applied. i would go complain right away. i know i would not let a car i painted leave like that! |
| Bookmarks |
| Tags |
| assuming, correct, cough, fa, im, pa |
