> Forced Induction
Old 03-09-2009, 03:53 PM   #1
Evans-Tuning.com
Former Vendor
Send a message via AIM to Evans-Tuning.com
Default Dyno comparison: Skunk2 Pro 1's vs CTR camshafts
I finally got a chance to do a back to back test on a customer's car that was previously using CTR cams and recently switched over to Skunk2 Pro 1's cams. I have not seen a real solid test at the same boost levels comparing the ITR/CTR cams to the Skunk2 Pro 1's, so I thought H-T would appreciate the info. Here is a quick run down on the car:
Full Race Stage 3 GT A/C kit (GT35R .82 a/r)
Thermal 3″ exhaust, no cat
84mm x 89mm b-series engine, 9:1 comp CP pistons, Manley Turbo Tuff Rods
ITR cylinder head, Pro Port headwork, Ferrea Competition Plus valvetrain
Edelbrock victor x intake manifold, 70mm throttle body
Injector dynamics 1000cc injectors, walbro 255lph HP fuel pump
93 Octane fuel
Here are the comparison graphs:
The pulls were done at several different psi levels, but I used the closest boost levels (18-19 psi) to illustrate the gains from doing the cam switch. There is a solid 60 whp gain in the higher rpms, with 300-400 rpms faster spool. When reviewing the boost plots the Pro 1’s had a peak boost of 18.5 psi, where the CTR cams had a peak boost of 19.8 psi. The Pro 1’s were able to make significant gains with approximately 1.5 psi less boost between 8,500-9000 rpms! I hope this test can end alot of the "which cams are best for boost" posts I see several times a week on here.
I do want to make sure that everyone is clear, DO NOT USE THESE CAMS WITH A LOG MANIFOLD!!! They will lose power, bottom line. You need a GT35r or larger turbo, equal length manifold, large plenum intake manifold (edelbrock victor x or similar) and 3" or larger exhaust (no cat). I have had several customer's car come in with big cams like the Pro 1's, Tuner 2's, etc running log manifolds, 2" exhausts, etc and either have to turn vtec off or have it engage at 8,000 rpm+.
This write-up is also available at our blog.
Evans-Tuning.com is offline Report Post   Reply With Quote
Old 03-09-2009, 04:05 PM   #2
KeyserSoze
KeyserSoze's Avatar
Send a message via AIM to KeyserSoze
Default Re: Dyno comparison: Skunk2 Pro 1's vs CTR camshafts
Very nice comparison. Thanks for taking the time to do this for us.
Originally Posted by VtecbOi
why need vtec when you have turbo. the whole point of turbo is to not run vtec. why have vtec when you can run vtec all the time. which in term no vtec. why would you wanna run the low lope and then the high lope. just run high all the time. unless you wanna save gas then that's another story... plus you won't have to worry about the switch over point, specialy when you have the turbo.
Vouches:xtremecivichb,dfoxengr,SHystrdyGSRtdy,a132 0addict,BodyKits NW
doublej http://images.honda-tech.com/set1/smile/emsmile.gif
RIP Earl
KeyserSoze is offline Report Post   Reply With Quote
Old 03-09-2009, 04:36 PM   #3
GSR-EG-92
GSR-EG-92's Avatar
Solid right there, thanks...
GSR-EG-92 is offline Report Post   Reply With Quote
Old 03-09-2009, 04:51 PM   #4
Boosted_Coupe
Boosted_Coupe's Avatar
Awesome comparison!
Now I've had a few people advising me to run Pro1's on my Topmount 60-1 Turbo 1.8l setup, but i'm hesitant to run them becuase I've read you saying only to run it with a GT35R or larger. My 60-1 doesn't fall into the ladder does it?
1995 Honda Civic Coupe
11.44 @ 125mph Dailly Driver
For sale:http://www.honda-tech.com/showthread.php?t=2660318
Boosted_Coupe is offline Report Post   Reply With Quote
Old 03-09-2009, 04:52 PM   #5
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Send a message via AIM to 96 GSR-T
Thank you Jeff, this is without a doubt the best cam comparison I have seen yet
1.8L Integra GSR T3/T67h.o
11.01 @ 137 - E8516-20psi 1.83 60'
2010: Completely new setup, 700+hp
96 GSR-T is offline Report Post   Reply With Quote
Old 03-09-2009, 05:00 PM   #6
turbo-crx
turbo-crx's Avatar
finally the test i have been waiting to se!!! nice job. i think i will be doing the switch.
lsvtec turbo gt4294 street beater.
verizon blackberry curve fs: $150
turbo-crx is offline Report Post   Reply With Quote
Old 03-09-2009, 05:01 PM   #7
Turbo-charged
H-T Basic Sponsor
Turbo-charged's Avatar
good test Jeff. i like the pro1's a lot!
Tempest Racing
301-290-0330
Turbo-charged is offline Report Post   Reply With Quote
Old 03-09-2009, 05:03 PM   #8
tony1
H-T Basic Sponsor
tony1's Avatar
Nice test Jeff and killer power for 93 octane!
T1RaceDevelopment.com
Check out the new site!
The ID2000 is here...
tony1 is offline Report Post   Reply With Quote
Old 03-09-2009, 05:08 PM   #9
red02s2k
red02s2k's Avatar
Send a message via AIM to red02s2k
93 OCTANE WOW!!! Does anyone want my itr cams so I can get the pro 1's!
Toyotaofplano.com if you need a car/truck let me no new or used anything!
red02s2k is offline Report Post   Reply With Quote
Old 03-09-2009, 05:10 PM   #10
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Jeff did you make any pulls past 9k rpm? I would love to keep my GSR cams in when I come back for a retune and do a GSR vs Pro1 comparison, bet that increase would be massive.
Old 03-09-2009, 05:10 PM   #11
Evans-Tuning.com
Former Vendor
Originally Posted by Boosted_Coupe View Post
Awesome comparison!
The 60-1 will work fine with the pro 1's if you are using the t350 aka stage 5 turbine wheel. I have not tried them on the stage 3 that typically comes with the t3/60-1's. I have used the tuner series stage 1's and pick up some nice power over GSRs on the t3/60-1.
Old 03-09-2009, 05:12 PM   #12
B20luda
Awesome power, appreciate the info
I wish the pro1's didnt cost an arm and a leg
Popup head light girl car
604whp 435wtq boat anchor FTW!
B20luda is offline Report Post   Reply With Quote
Old 03-09-2009, 05:15 PM   #13
Evans-Tuning.com
Former Vendor
I am not really into making crazy power on pump gas, but this car just wanted to make power so easily it was unreal. The engine with CTR's installed was actually tuned to 540whp at 21 psi previously, which I did not want to do on this set-up. The duty cycle on the solenoid was really touchy, so it was hard enough getting the boost dialed in to overlay on the old plots. 60% duty cycle gave 18~18.5 psi, 63% duty cycle gave 21 psi but i lifted out of those runs around 6k...it was headed for 600whp range lol. The car is a full weight ITR, and trapped in the 133-134 mph range at 475-500whp previously so I cant wait to see what it does this time around with the new cams.
Old 03-09-2009, 05:17 PM   #14
Evans-Tuning.com
Former Vendor
I didnt make any pulls past 9k simply because the old graphs ended there. I was more interested in getting a good comparison. Limiter is at 9.5k on the engine, so revving it out a bit probably wouldnt have done much more.
Old 03-09-2009, 05:20 PM   #15
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Ok cool, I was just curious of the gains at around 10k with them, it looks like they were going to keep making power if the boost stayed constant at 9k.
Old 03-09-2009, 05:37 PM   #16
Turbo-charged
H-T Basic Sponsor
i love cars like that. its weird how some cars just want to make all of the power in the world. i wish they were all like that!
Tempest Racing
301-290-0330
Old 03-09-2009, 07:24 PM   #17
slooogsr
slooogsr's Avatar
Location: if u steal my car ill kill you......, NJ, USA
Send a message via AIM to slooogsr
Nice comparison......
I'm guessing for a t3/t04e I should just stick with the CTR or ITR intake cam on a b18c1? I may just go with the pro 1's in case I upgrade the turbo later......
95 MR GSR Finally B00sted! 12.79 @ 115.24 - Daily Grind = 08 Mazdaspeed 3
My build: http://www.honda-tech.com/zerothread?id=1827900 Thanks to First State Motorsports & Xenocron Tuning
slooogsr is offline Report Post   Reply With Quote
Old 03-09-2009, 07:50 PM   #18
D-Rob
D-Rob's Avatar
Send a message via AIM to D-Rob
I have had several customer's car come in with big cams like the Pro 1's, Tuner 2's, etc running log manifolds, 2" exhausts, etc and either have to turn vtec off or have it engage at 8,000 rpm +.
Hah, funny you mention that!
We've had several customers with similar setups and did the same exact thing. It's ridiculous!
- Derek
InnovativeMotorWorks
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m
Cleaning Out Sale! --> http://www.hondamarketplace.com/show....php?t=2679505
D-Rob is offline Report Post   Reply With Quote
Old 03-09-2009, 08:07 PM   #19
totsie7944
totsie7944's Avatar
Send a message via AIM to totsie7944
Jeff...great tune as always, the car has been driving like stock. Figured I'd post a few pics and mod list for those interested:
Full Race ProStreet AC Stage 3 GT Kit
Thermal 3” Exhaust
Full Race 3" Downpipe
22x8x3 Intercooler Anodized
GT 35r Turbo .82 A/R Exhaust Housing
Tial 50mm BOV
Tial 44mm Wastegate w/ 10lb spring
Walbro 255lph HP Fuel Pump Intank
Competition Stage 5 clutch w/ upgraded pressure plate
Competition Ultralightweight 7 lb Flywheel
RPM Services 72mm TB
Plug Wires NGK Blues
Greddy Timing Belt
Edelbrock Intake Manifold
AEM Fuel Rail
Aeromotive A1000 FPR
Hasport Motor Mounts
Injector Dynamics 1000cc Saturated Injectors
Darton Sleeves 84mm bore x 89 mm stroke
ERL MID kit
9:1 CP Pistons
Manley Rods
Ferrera Competition Plus Valve Train w/ TI retainers, bronze valve guides
LS Crank
Skunk 2 Pro 1 cams
T1 Catch Can
Omnipower 4-bar map sensor
Outlaw Engineering IM gasket
Autometer (Wideband, Boost, Oil Temp, Oil Pressure, Fuel Pressure, Wire Temp & Press)
Sparco Wheel/Hub/Bolt-On Quick Release #Civic/CRX 92-95
Battery re-route kit
Port & Polish Head
Neptune
ARP Studs (Main, Head, clutch & flywheel bolts)
Toda Cam Gears
totsie7944 is offline Report Post   Reply With Quote
Old 03-09-2009, 08:46 PM   #20
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
I want your car sooo bad, I bought one brand new back in 2000 and totalled it 5 months later Big congrads to you does the car feel faster now with the new cams even though you are at basically the same power level as before?
Old 03-09-2009, 09:29 PM   #21
tegman23
tegman23's Avatar
Send a message via ICQ to tegman23 Send a message via AIM to tegman23
Nice job jeff...That gives us all great info. We all know for sure which is better now..
92 DA 11.70@124mph
2.0-T power
IMW/JK Tuning
tegman23 is offline Report Post   Reply With Quote
Old 03-09-2009, 10:16 PM   #22
Teglove2
Teglove2's Avatar
Send a message via ICQ to Teglove2 Send a message via AIM to Teglove2
I love type r's....sweet power
RMSfabrications@yahoo.com
Teglove2 is offline Report Post   Reply With Quote
Old 03-09-2009, 10:27 PM   #23
jasoncrashtech
jasoncrashtech's Avatar
love the post. thanks guys
ej8 squad member #346
valve cover how to http://honda-tech.com/zerothread/2188046
my daily http://honda-tech.com/showthread.php?t=2603420
jasoncrashtech is offline Report Post   Reply With Quote
Old 03-09-2009, 10:43 PM   #24
V-SPEC 1
V-SPEC 1's Avatar
Send a message via AIM to V-SPEC 1
thanks for the test jeff.
10.28 @ 149mph
Built and tuned
V-SPEC 1 is offline Report Post   Reply With Quote
Old 03-10-2009, 05:57 AM   #25
Tjabo
Tjabo's Avatar
Can anyone give an approximate difference between these two sets of cams in terms of duration at .050" or 1mm (whichever is handy), and overall valve or lobe lift (again, whichever one is handy)?
Thanks in advance!
Tjabo is offline Report Post   Reply With Quote
Bookmarks
20, cam, cams, camshafts, ctr, dyno, grind, gsr, motor, pro, pro1, put, skunk2, tuner, turbo
