Nut size??
36 is the front. It should be a 32mm, I just went into my garage and put an 1.25" socket on it and it fit fine.
What vehicle did this knuckle/spindle come from?
all is good, It's snowing here, and I'm just sitting here next to the fire with my laptop and a Guinness passing time too. I probably have a slight advantage where my garage is attached to my house and it just so happens to contain a fully stripped Accord. I can pretty much measure anything in a matter of minutes
I suspect that the bearings in the disc set up are bad and I wanna use the bearings from the drum setup.
OK so given the information that the drum in question is from a wagon. I would say you have the 24mm diameter spindle, and I would assume that would probably need a 34mm socket.
Did you find out for sure if it's a 34mm? I know I just tried a 36 on my 93 lx w/drums and it's too big
Now I need to get a socket to fit it. Can't wait till I get all this #@#$ back together.
Hondata
Mar 24, 2004 07:07 PM
