Old 02-25-2009, 04:37 PM   #1
90_EX_Civic
90_EX_Civic's Avatar
Default "HOW TO: Fitting HX rims on big calipers."
okay since they're are a lot of people that wonder if they can fit HX rims on their car, and since i had a set. i decided to do a write up on it. the car is a 90 EX civic(hence the name). even though it is a ED(EF for all you other people) the EX model use's the bigger brakes; i.e. 10.3 rotors. so this would imply for all you other EX guys and SI(EM1) car owners. this would also include integra owners too. so here goes,
this is why the HX rims won't fit; notice the ring inside the rim
here is a better view;
^this is what is rubbing against the caliper. if you're wondering im guessing this is from the preveis owner.
the brakes;
^if you look closly you can see some scrapage from my earlier test fitting.
what to grind;
^were my finger is pointing at is what you have to grind down
how it looks once you start to grind it down;
i used a colored crayon to mark it. this is to see if it still rubs;
i test fitted the HX rim on and tried to spin it to see if it would catch, and this is what i saw;
^as you can see it was still catching a little bit. notice some of the crayon had rubbed off on the edge.
i grinded off some more;
i then rubbed some more crayon on the caliper and test fitted;
^as you can see after spinning the wheel a couple of times around, and taking off the rim. it looked good and didn't catch anywhere.
now i know a lot of you guys say use wheel spacers but i just don't like the idea of it. this only took me an hour to do both sides. would have been quicker but this all includes taking pictures and test fitting. hope you like.
EDIT* ALMOST FORGOT. WHEN GRINDING DON'T FOR GET TO PUT A LUG NUT ON WHEN GRINDING. YOU WILL MORE THEN LIKELY HIT IT, SO TO BE KIND TO YOUR WHEEL STUDS, PUT ON A LUG NUT.
90_EX_Civic is offline Report Post   Reply With Quote
Old 02-25-2009, 05:14 PM   #2
ALLxMOTOR EG
Vietnamese!
ALLxMOTOR EG's Avatar
Default Re: "HOW TO: Fitting HX rims on big calipers."
Good write up.
ALLxMOTOR EG is offline Report Post   Reply With Quote
Old 02-25-2009, 05:23 PM   #3
victor.m
victor.m's Avatar
Send a message via AIM to victor.m
Thanks a bunch for the write-up man, this is really useful for me as I have GSR front calipers and the HXs won't fit at all on my EJ1. If only I had seen this sooner. What did you use to scrape, a filer?
victor.m is offline Report Post   Reply With Quote
Old 02-25-2009, 05:26 PM   #4
90_EX_Civic
i used a grinder, dewalt grinder to be exact. but any grinder well work. you're taking a lot off, kind of, no more then 5mm give or take
Old 02-25-2009, 06:32 PM   #5
90_EX_Civic
wonder if this will get stickied?
Old 02-25-2009, 06:36 PM   #6
roadsqueegy95
roadsqueegy95's Avatar
it should be, great info
Get your honda-tech.com decals....on sale now!!
http://www.honda-tech.com/showthread.php?t=2573880
roadsqueegy95 is offline Report Post   Reply With Quote
Old 02-25-2009, 06:37 PM   #7
KuEy
1992 Honda Civic
KuEy's Avatar
wow. this answers a lot of question. great write up.
KuEy is offline Report Post   Reply With Quote
Old 02-25-2009, 06:42 PM   #8
90_EX_Civic
yeah, always heard the two camps. one said grind it. the other said wheel spacer. i went the grind it route.
Old 02-25-2009, 07:13 PM   #9
kaminam
kaminam's Avatar
nice write up.
kaminam is offline Report Post   Reply With Quote
Old 02-25-2009, 07:20 PM   #10
ONE-CAM-EF
ONE-CAM-EF's Avatar
Send a message via AIM to ONE-CAM-EF
i can deff use this write up..since my ef has gsr front calipers....i love the hx wheels..
ONE-CAM-EF is offline Report Post   Reply With Quote
Old 02-25-2009, 07:22 PM   #11
ajason24
ajason24's Avatar
paint the hx rims now
Your Mom ♥'s my Honda.
XBOXLIVE= YOUR M0MS BFF
http://honda-tech.com/showthread.php...5#post37422705
ajason24 is offline Report Post   Reply With Quote
Old 02-25-2009, 07:36 PM   #12
90_EX_Civic
i like the stock look
Old 05-20-2009, 11:48 PM   #13
EFfective
1991 Honda Civic
EFfective's Avatar
Send a message via AIM to EFfective
good write up. i just did this to a friends eg 2 weeks ago.
I don't recommend the use of wheel spacers unless you have extended wheel studs as the stock studs will only leave around 3-4 threads (or less depending on spacer thickness) to bolt the wheels on.
EFfective is offline Report Post   Reply With Quote
Old 05-21-2009, 02:21 AM   #14
xnvb
I'm glad I read this before I picked up a set of HXs, I've been looking for some for months. I've got an EJ1 with GSR brakes all around. Good write-up.
Originally Posted by Syndacate View Post
The only answer for your engine is a new motor, doesn't have to be a K20, but upgrading that Y5 for more performance is like humping a wall for the sexual experience.
xnvb is offline Report Post   Reply With Quote
Old 05-21-2009, 02:48 AM   #15
jhonda239
jhonda239's Avatar
i love hx rims. but for me its not worth the trouble.
** 100% complete d-series turbo kit for sale **
http://hondamarketplace.com/showthread.php?t=2669747
jhonda239 is offline Report Post   Reply With Quote
Old 06-08-2009, 09:54 PM   #16
richie-rich88
richie-rich88's Avatar
Send a message via AIM to richie-rich88
I did the same exact thing to my eg hatch and it didnt take long at all! good write up!
95 DC2 *luvn it* 92 DA *sold* 93 EG hatch *sold* 95 EG hatch *totaled*
93 DA b16 96 EK coupe *sold* 94 del sol *sold* 91 prelude si 4ws 2.05L *sold*
richie-rich88 is offline Report Post   Reply With Quote
Old 06-08-2009, 10:20 PM   #17
FearTheH
1999 Honda Civic
FearTheH's Avatar
Send a message via AIM to FearTheH
excellent! thanks for the info, always heard they wouldnt fit my EM1, but never looked into exactly why they wouldnt.
Originally Posted by chelt_scene View Post
97 civic coupe.
want a duckbill spoiler for it where can i get them from?
FearTheH is offline Report Post   Reply With Quote
Old 07-28-2009, 03:41 PM   #18
EdWord
EdWord's Avatar
Send a message via AIM to EdWord
great write up! i also have another question, will spacers mess up your stems?
EdWord is offline Report Post   Reply With Quote
Old 07-28-2009, 10:39 PM   #19
EFfective
1991 Honda Civic
EFfective's Avatar
what do you mean by stems?
Old 08-02-2009, 12:09 AM   #20
EdWord
EdWord's Avatar
well i have a set of hx's on my car right now with spacers. I was just wondering if it will mess up the stems since im using spacers thats all. and does anybody know how much it would cost to get some curbaged fixed?
Old 10-05-2009, 10:37 AM   #21
khmers0uljah
1997 Acura Integra
khmers0uljah's Avatar
Location: I'm always painting & polishing shiet, California
Or you could do what I did and run big ass washers on each stud. .
iLLiCiT -let it be known-
DC Squad Member #1 (V2)
khmers0uljah is offline Report Post   Reply With Quote
Old 12-13-2009, 02:24 AM   #22
Nickstadx
1988 Honda CRX
Nickstadx's Avatar
awesome my proble is now solved. ill be doing this very soon.
An 88 dx with a dream, that dream is to work.......someday
Nickstadx is offline Report Post   Reply With Quote
Old 12-13-2009, 09:13 AM   #23
SLURS
SLURS's Avatar
Send a message via ICQ to SLURS
good write up! was thinking bbout getting hx's are heller dop@!
SLURS is offline Report Post   Reply With Quote
Bookmarks
90, big, brakes, caliper, calipers, ef, ej1, fit, grind, hatch, hx, integra, rim, rims, rubbing
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
