white exhaust valves turbo b16 : pics
Old 02-25-2009, 01:00 PM
AbitAvenger's Avatar
Icon2 white exhaust valves turbo b16 : pics
ok well last night we popped the head off a b16 with 140k on it. this was the first time the head was taken off of this motor. The exhaust valves are super WHITE which I think means it's running lean? Not sure... They also have what looks like a buildup on the exhaust valves which may be some additive in the fuel, i have no idea. Why are my exhaust valves so damn white?
There is also a shiny spot on 2 pistons (if i remember correctly, 2 and 3) in the valve reliefs. I don't think there was piston to valve contact but it sorta looks like it. Any ideas?
The car is tuned on Hondata S200 and the AFR ranges from 11.4-12.3. I have no idea what the timing is either need a chip burner
sorry i didnt resize the pics, they gotta be big to see the detail
PICS
Old 02-25-2009, 01:16 PM
spoolin turbo s's Avatar
Default Re: white exhaust valves turbo b16 : pics
i always thought white meant lean but is that with plugs?, have you used any additives?
im not really sure but im sure someone on here can tell you
Old 02-25-2009, 01:22 PM
no additives
only 93octane
Old 02-25-2009, 04:39 PM
i ♥ snails
quicksilver1689's Avatar
there is always additives in gas from the pump of some sort, most exhaust valves ive seen have always been white, the combustion chamber seems to have a good amount of carbon, most likely not running too lean, but it has 140k so it has alot of history. Timing would have to be pretty retarded to overheat the exhaust valves. just some thoughts i got when i saw ur pictures, im no expert.
Old 02-25-2009, 05:01 PM
HiProfile's Avatar
If you were running a very conservative tune, the exh valves will suffer a bit. Retarding timing means burning the mixture later, which can lead to higher egt's. That directly impacts the valves' temps, usually for the wrose.
Its hard to tell anything about the pistson, other than the fact there is a lot of carbon on them, and that the person pulling the head failed horribly at draining the coolant. Be certain that person reads fully the actual documented instructions on how to remove/replace the HG. Its simple to do if you don't care about warpage/etc, but there are a few fine steps if you DO care.
Old 02-25-2009, 05:31 PM
vadimkag's Avatar
Blown head gasket...?
Old 02-25-2009, 05:40 PM
non-VTEC's Avatar
oil consumption. the white on the exhaust valve is ash residue burning off from the oil.
looks normal asside from the carbon build-up.
Old 02-25-2009, 05:58 PM
FactionR's Avatar
yep, i just pulled apart a type-r that was going through a quart a week. look at the valves and piston tops on mine:
Old 02-25-2009, 08:19 PM
seals on the turbo were blown, there was oil in the intake mani and intercooler
oh yeah and we forgot to drain coolant somehow lol
Old 02-25-2009, 08:21 PM
FactionR's Avatar
well there is your source of oil that is burning.
Old 02-26-2009, 01:48 AM
blackeg's Avatar
just wondering if you had some sort of anti lag set up on that motor
Old 02-26-2009, 10:21 AM
thats what it looks like by looking at the exhaust valves but no there wasnt. that was the plan to retune and use the antilag for when we're launching on slicks at the strip but i dont know now, didnt know they took THAT much abuse just by running conservative timing, I don't even wanna c what they look like after some anti-lag. Like I said I don't know what timing theyre running on this motor but it's looking pretty conservative.
hiprofile : we followed all the steps of removing the head except for draining coolant, dunno y but that was forgotten until coolant was already everywhere lol
anybody see on the piston pics the shiny spot on the valve relief? I don't know what this is, is it contact or just burnt up **** cuz i couldnt scrape the shiny spot off, looks like fresh metal
Old 02-26-2009, 10:40 AM
D16SohcVtec's Avatar
I've always thought the exhaust valves would be white due to the fact that they are exposed to higher heat going out from the combustion chamber. And the cooler air from the intake is what keeps the intake valves from changing. Every head I've removed looked like that so I wouldn't think that's an issue.
Old 02-26-2009, 12:22 PM
Yeah it makes sense. I've never taken apart an oldish motor before without running seafoam first. Seems to clean it out pretty well.
Ok just for discussion sake what would the opposite mean? Another ls/v in a buddies car has one cylinder with white exhaust valves and the rest have blackish valves.
Is there any way to clean the piston tops easily before putting it back together? And a light wire wheel wont hurt the valves will it? Or just get new ones?
Old 02-26-2009, 02:48 PM
Keyboard Humorist
4drEF's Avatar
The marks on the pistons look like areas where some carbon build-up broke off.
Nothing wrong with that.
Old 02-27-2009, 05:05 AM
Turbo-LS's Avatar
Looks like high egt's from antilag or improper tuning IMO
Old 02-27-2009, 08:32 AM
00si2's Avatar
Whats the best way to remove that buildup?
I have some buildup on mine also and tried a few things to remove it without any luck.
Old 02-27-2009, 09:00 AM
Keyboard Humorist
4drEF's Avatar
Best way I have found is when the car is running.
Seafoam does a great job.
With the head off I have covered the pistons with towel and poured B-12 chem tool on the rags (rags to keep the liquid on the surface of the piston and to slow evaporation). Seemed to eat it up decently.
Oil change is a must after either method.
Old 04-12-2017, 04:54 AM
Mikeymikey023's Avatar
Hey guys I'm new here, still tryna find out how to work this.
ive just bought a 5th gen prelude , H22a4
was throwing multiple misfire code and cylinder 3 misfire code. Just pulled the head off and seen the timing was off on the intake side. Also the exhaust valves are white with a lot of build up as well as in the combustion chambers , would this cause the multiple misfire code and cylinder 3 missing?
ill try to upload some pics The timing marks
The combustion chambers
All exhaust valves look like this
Old 04-13-2017, 10:27 AM
Moderator
TheShodan's Avatar
No. Not necessarily. white valves like that are typical with higher mileage engines, especially those that run in too high of a gear attempting to accelerate. It's rather common.
Your misfire sounds more ignition related. (distributor, internal coil, spark plug gap, etc).
Start checking there 1st. Make sure cap & rotor are changed, usual maintenance, etc..
eg:R
05-24-2009 12:54 PM
MumBleZ_94gsR
05-19-2009 09:05 PM
92ehatch
21
11-13-2007 01:58 AM
tuan...
09-07-2004 04:27 PM
Quetzolcotl
08-30-2003 09:59 AM
Quick Reply: white exhaust valves turbo b16 : pics
