How's the AEM EMS for tuning?
I'm about to get the Hondata s300 to tune my N/A build but I was wondering if the AEM EMS is just as good and easy to tune? Which one do you reccomend?
Re: How's the AEM EMS for tuning?
umm.. depends on whos tuning and what they are familiar working with. If its you tuning, I'd scrap both and go with crome. Its soo easy even a moron can do it (YESSS! even I can do it :D)
Both those systems are good if your going all out either N/A or forced inducting but a touch overkill on a bolt on car in my opinion. Where you headed with this car meanshyguy?
Just don't want you blowing a crap load of money if you don't need such a expensive tuning setup.
AEM EMS is much more difficult to tune than the s300. Don't waste your time with freeware junk. The majority of reputable established tuners won't touch the freeware garbage.
I don't find all freeware to be junk. I think you should atleast try to be specific about certain free ware rather than bashing it all colectively.
In the end it does come down to what you can afford, and what your tuner knows how to use and thats it.
So in no shape way or form even under the strictest budgets would you suggest someone get tuned with freeware?
99% of the cars with free-ware EMS's are ghetto rigged. I know... because I see them come into the shop all the time. I'm a firm believer in you get what you pay for.
I'm going all motor for the drag strip on the weekends and drive it on weekdays occationally, my build thread is here somewhere.
moderator emeritus
eCtune, Neptune, Hondata (although I would never buy one personally), AEM, autronic, motec, dta, fast and more...all of those are real engine managements that work as they are intended and have support with program updates.
That does not mean that freeware EMS itself is junk, if that is what you base your logic on it is flawed. There are several rather high profile cars that have run, and continue to run Crome, etc, with success.
If you wish to debate the finer points of control on any of the freeware EMS out there you may do so with me, Anthony. I will agree that some of it is junk, but I'm certain it will be for different reasons. How's your assembler?
Disagree about AEM. I understand the AEM guys finally mastered the concept of an opamp and the v2.0 aka USB boxes will correctly support VR sensors, but AEM as we have known it for the last decade offers poor support for Hondas, Toyotas, and other cars that use VR sensors (some Mazda, etc). The v1.0 AEM was designed by someone very comfortable with digital but lacking even basic linear background; to correctly handle a VR sensor in a digital system requires variable rate of change calculations (calculus, and complex to do with an MCU)... or use of an opamp, which performs integration and differentiation by nature.
Pretty basic blunder IMO, but hey Motec made it too.
it depends on your budget. I would stay away from programs like Crome and uberdata because only some of the stuff works and somethings work but not as they are intended. Not to mention there is no support for either of those.
moderator emeritus
the support part was mostly from what i have experienced with ectune and neptune and read about with motec. I have had zero experience with aem other than downloading the program. You open it and look at all the things that need to be calibrated to each engine and its just breathe taking, lol.
Oh, I like AEMs, just not for not-Hondas which have easier alternatives, since half the stuff an AEM tune requires is already done for you in the stock-based code. The only issue with *all* of the good OBD1 ECU based solutions is the way the revlimiters are handled, it's not ideal as the Honda-based two steps end up a lot higher, but it can be lived with.
I've done a few Honda box conversions on Toyotas, Mazda Protege (pre-MP5 1.6 liter, the ****ed up one with hall and VR sensors), SBF, and I'm fitting 1050s right now to a K24 and an R34 Skyline and a 1000 box to a Porsche 951. On the VR-equipped cars I always end up recalibrating the idiot attenuation resistors to suit the individual vehicle as setting Sync Error RS to 0 and having a car that's slow to catch when cranking isn't how I roll. I have partial adapter board schematics and most sensor resistor locations for 1000, 1020, 1050, 1052, 1313, (and I'm sure others in the future) so if anyone ever has a wierd AEM swap problem hit me up. I'm not a weenie about sharing what I know.
Also, since we're on the AEM rant, the stock 1100 cal for the Mk4 Supra TT has the coil dwell tables hammered. The problem with those cars misfiring under boost is NOT because the system has been converted to wasted spark. I've made over 600 on stock coils with no DLI or other ignition box, and I'm fairly certain I can make more.
at some point the freeware probably becomes a restriction, and a real EMS is necessary to to go any further. to say freeware is "junk" is ignorant. no suprise from this place though.
heheh, this topic is going to get out of hand soon. When it comes down to battles of EMS theres wars to be faught HEHEH.
Freeware for the poor. Hondata for the rich. Everything else just falls inbetween.
I've used crome, and never had an issue with it. The local tuners use crome. I've never had any complaints about it, and don't see the point in spending hundreds more on JDM and Hondata and whatever else when I could use the money towards something more useful.
Read the whole topic. I support freeware and only use crome.
I was making a joke about how poor I am lol, and how rich other people are if they use hondata or similar expensive tuning systems
oh,..you never had to reload a map in crome? theres little bugs like that but nothing major that I've found. Burning to a chip is a bit touchy some times too I find using the Burn1
