#1 | |||||
<U>1995 240sx SR20DET</U> - GT25R, widebody, 400whp too much to list |
#2 |
I have read the techedge article already to find the information, thanks for posting.
My question is: Let's say the A/F ratio is at 12.5:1 full throttle 7500 rpm constant. The mixture is perfect but EGT temp. can change due to timing event. Generally, what temp. do you see at this example on honda engine? Maybe it's not enough information but due to lack of dyno access and experience maybe you can explain much better on how is too retarded or too advanced effecting the EGT temp. I know that generally, correct advanced timing ( say 35-40 degree of timing) will lower the egt. overly retarded timing will rise the EGT. On a boosted honda with around 10psi full throttle near redline of 8200, what temperture you usually see that is optiumal? [Modified by [Evo]Hybrid, 10:40 AM 8/8/2002] [Modified by [Evo]Hybrid, 10:45 AM 8/8/2002] |
#3 |
thank you
right click save ![]() Rob
Back to civilian life, and adapting well http://images.honda-tech.com/set1/smile/emsmile.gif |
#4 |
boosted Honda is far too vague. As stated in the article, EGT can change with barometric pressure, engine and air temperature, compression ratio, cam choice, cam timing, and many other factors. What should be most important to you is that the air fuel ratio is correct and safe, and the ignition advance is within safe parameters of your known combination. This is where tuning experience pays off. So, I retort your question with another - which boosted Honda in particular?
#5 |
9:1 compression B18C1.
Stock cam, stock camgear setting. stock distributor timing at 16 degree. On the ignition map, I set low rpm city driving mode around 35-37 degree of advance. At 8psi 8000 rpm I set the timing at 25 degree of advance. Timing increase as it decreasing boost. All I'm saying is generally, what temp. you usually like to see? 700 celius? 800 celius? I don't think I would want to see anything above 850-900 but who knows. I think 700 is alittle low. [Modified by [Evo]Hybrid, 10:51 AM 8/8/2002] [Modified by [Evo]Hybrid, 10:53 AM 8/8/2002] |
#6 |
Better than steak
Click on this----->
![]() Keep this in your note pad!
10.006@150mph T1 Race Development -Competition Clutch -Full-Race Motorsports Don't call it a comeback... |
#7 |
LOL
#8 |
now I ask you another question - where is the EGT probe tapped? Location is another big factor, as a movement of only 4 inches can drop the EGT reading dramatically. I usually keep them in the manifold, close to the head, and have seen 1000 deg celcius without a failure.
#9 |
#1 cylinder on the manifold one inch away from the head.
Holy shit!!! 1000 celius? Wow, my greddy egt gauge turn red mark as pass 900. [Modified by [Evo]Hybrid, 11:02 AM 8/8/2002] |
#10 |
read above post
#11 |
okay, 1000 celius is probably too big balls for me. Any other suggestion for a safe boosting day?
#12 |
my question is, why is that too big balls for you? Again, there are so many variables that go in to EGT's. What you should be most concerned with is pre ignition, detonation, and air/fuel ratio. Use EGT's as a reference, not as a guide.
#13 |
I understand there is other variables but truthfully at that temperture I wouldn't buy it. Above 900 degree celius is pretty much melting stage and I wouldn't recommend that to anyone. You are telling me that beside 1000 degree, there is no other average temperture that you like?
I have no detonation or preignition and my wide band is also showing around 12.5 A/F. We all know how A/F should behave like but EGT temp. is sometimes very mysteries. [Modified by [Evo]Hybrid, 11:13 AM 8/8/2002] |
#14 |
Every car is different. Some like it hot...some don't. The point of this article and thread was to show you how to use EGTs, and to show you how uncomparable they are.
#15 |
Okay, let's just leave it here. I thought you were actually going to give me a suggestion but nevertheless, tuning secret is tuning secret. Actually I never asked for tuning secret just a average temperture that you see which you like since you should tune quite a few cars on the dyno if I'm correct. I need not to debate over theories but actually just want to share a few experiences. Thanx for your help anyway.
BTW, EGT is important. Beside dyno for torque amount, EGT will tell you if your timing is correct at a certain degree. A/F of coarse is first prioty. [Modified by [Evo]Hybrid, 11:23 AM 8/8/2002] |
#16 |
Better than steak
Ok, the variables depent on Air to fuel, fuel used(gasoline, butane, propane), octane, and compression.
Now, What I think you are asking is; what is the egt temp at X amount air to fuel? Right?
#17 |
I already understood and knew some of what that article was talking about, but thank you for informing us again and to those who didn't know.
My egt is tapped in the dp at the VERY top where it meets the turbo.... highest temp I've seen is 880c during a highway sprint in 3rd gear climbing to redline.... it was scary I must've been leaning out at the time. Had stock timing, inline pump, stock injectors, stock fuel pump, 12:1 fmu, and thats it ![]() A friend running the AFC hack his temps don't go above 810c and we essentially have the exact same car only 4 years apart
[Stolen 10/19, recovered 10/21, stripped and destroyed] R.I.P. http://images.honda-tech.com/set1/smile/acura1.gif 99' Integra LS 2dr (auto-no more) 5spd now 14.338 @ 101.29 MPH 189whp @ 8psi (.58 bar) 167lbs of tq Rev Hard Stage 2c T3/T04e S-AFC hack + Rc 440cc injectors (TUNED!!) TechEdge wideband o2, Greedy Boost + Egt gauges Stock internals Pics and mods here: http://shadowdawn.dyndns.org:81/car.htm |
#18 |
After reading that article I feel that spending $160 for an EGT gauge is a complete waste of money for me. But my mani is already tapped for one.
All I want to be able to do is make sure that my A/F ratio is where it should be. If my EGTs are going to change due to an infinite amount of variables that tells me absolutely nothing. I need something that will help me be able to properly tune my VAFC to rich or lean out my fuel mixture (dont have an A/F gauge) and it sounds to me like spending $160 for an EGT gauge isn't the answer.
95 Civic DX beater |
#19 | |
Local to PA? Check out http://www.pa-imports.com |
#20 |
so basically since my mani is already tapped i get to spend $160 on a gauge for looks.
#21 | |
#22 |
i guess i can, just have a muffler shop weld something over the top of it?
#23 |
Forgive me if this is a stupid question as I never really knew what EGT's are. From reading this, it would seem to me that a whole lot of other factors can come into play, such as how good your cooling system is? For instance, if your IC isn't cooling the air good enough, that in turn would cause higher EGT's won't it? Or am I missing the point?
#24 |
buying a egt gauge is not unimportant, its a good tool to use when combined w/ an a/f gauge.
WARNING THEIVES: This vehicle is equipped with a page notification alarm system, beware of owner and the KEL-TEC 9mm handgun http://rely.net/~htimages/smile/emwink.gif |
#25 |
is the greddy A/F gauge better than the Autometer or do they both suck mainly because they aren't wideband?
| Bookmarks |
| Tags |
| 2000, accord, af, afr, air, average, concern, egt, engine, exhaust, explained, fuel, gasoline, gauge, honda, ratio, temp, timing |
