95' Honda Accord- Turn Signals Dont Work!!!!
I have a 95' honda accord LX 5speed and just recently my turn signals stopped working. CAN ANYONE HELP ME OUT???
you can send me any e-mail, at benjamin.perez07@live.com
Re: 95' Honda Accord- Turn Signals Dont Work!!!!
Does your hazards work? If not, it can be the hazard switch on the dash.
Or it may be the turn signal relay in your underdash fuse/relay box. You might have to remove the kick panel to get to the relay area on the fuse box (the first relay, left side on the fuse box).
i had a similar problem with an EF i had, except it was the headlights. it could just be the metal that touches each other to create the circuit that makes the light turn on, it is probably dirty, so its not sending a current when touching. i opened mine up and it was all black from dust and there was no metal exposed between the two, so when they touch it wasnt metal to metal, it was just dust to dust. so it could just be something that simple.
On your driver side bottom, inside of car, there is a fuse/relay box. If you only open the door/cover, you will only see the fuses portion. You may need to remove the kick panel to see the relays. The relay on the left side, bottom one, I believe is the turn signal relay (or what people also call the flasher).
cb1999nj
12-18-2005 02:26 PM
