obd1 injectors obd0 wire harness Q..
I have a d16a (93 jdm single v ) the car still obd0 wit obd0 injectors..
I cam across obd1 wire harness wit obd1 injectors.. If I cut the obd0 plugs and put the obd1 plugs and injectors will the injectors work?
Re: obd1 injectors obd0 wire harness Q..
you don't need to convert to obd1 to use the obd1 saturated injectors. splice on the clips and drop in the obd1 injectors. then all you have to do is remove the resistor box. its the grey box with a green plug on the driverside back corner of the engine bay. remove the box and solder the 5 wires going to it into eachother. (4 red/black wires and 1 yellow/black wire)
Sleepy_Red_hatch
03-04-2006 08:59 AM
