Power steering belt Trick?
Old 01-16-2009, 05:06 PM
Hatch0126's Avatar
Default Power steering belt Trick?
Hey guys,
New here and I've been searching for a while and maybe it's cause my problem is so freakin simple I can't find anything. But could one of you tell me how to change my powersteering belt?....
I've asked and everyone tells me either just put it on and that it stretchs...ummm it don't stretch unless theres some trick..
So yeah, How do i change my power steering belt? Please help. Thanks
Old 01-16-2009, 05:48 PM
standbackimapro's Avatar
Default Re: Power steering belt Trick?
Losen the belt tensioner, remove belt, install new belt, re adjust tensioner
Old 01-16-2009, 10:26 PM
Hatch0126's Avatar
which one is the belt tensioner?
Old 01-16-2009, 11:26 PM
redboost10's Avatar
loosen the red bolt, then play around with the blue "wing" nut which is the tensioner.
Old 01-17-2009, 04:17 PM
Hatch0126's Avatar
You guys are awesome...thanks
Old 01-20-2009, 03:38 AM
Hatch0126's Avatar
***update. I changed the belt topped off the fluid and the bastard still sqeaks!! but it's very inconsistant...only on initial start up, then it goes away and on really cold days it's here and there. Sometimes between shifts, sometimes when slowing down, it's never constant...any ideas what else could be making it sqeak? Help please....
Old 01-20-2009, 04:21 AM
kine462's Avatar
WORKING FOR A LOCAL DEALER i HAVE LEARNED TO ONLY USE OEM BELTS, AFTERMARKET BELTS ALWAYS SQUEAK AND ESPECIALLY THOSE GOOD YEAR GATORBACKS!!!
Old 01-20-2009, 05:36 AM
Hatch0126's Avatar
Agreed but I have a unorthodox under drive pulley so I need a different size belt...and there isn't an OEM one for that.....
Old 01-20-2009, 05:42 AM
tech7427's Avatar
how tight did you tighten it?
Old 01-20-2009, 06:24 AM
Hatch0126's Avatar
As tight as I could get it.
Old 01-20-2009, 07:41 AM
Turbowa's Avatar
If you have an aftermarket pully you will need to have that belt so tight you could play it like a banjo. And if your using a Goodyear Gatorback you will always have noise. They never stop streaching, they will eventually break the cords inside the belt and then its really going to make noise.
Old 01-20-2009, 09:37 AM
Hatch0126's Avatar
I have a Gates belt. So no tighty? somewhat loose?
Old 01-20-2009, 11:43 AM
Hatch0126's Avatar
Well, since I'll be messing with belt tensioners how do I tighten the alternator belt?
Old 01-20-2009, 11:58 AM
non-VTEC's Avatar
im willing to bet that the alternator belt is not tight enough if you are still getting belt squeal on startup.
there is a 12mm nut on the top alternator bracket you loosen a little. stick a prybar between the bracket and alternator and pry the alternator back away from the engine to apply more tension.
its a tight fit and you will be fighting with it for a while to figure it out.
good luck.
Old 01-20-2009, 03:53 PM
Solbros Owns Me
Evs-One's Avatar
+1 on the alternator belt....PS belts don't really squeak on initial startup unless they are REALLY loose...
Old 01-20-2009, 04:05 PM
Darth ModerVader
Padawan's Avatar
I never had a problem with Gates belts squealing. I think you should double-check the tension on your alternator, PS, and AC belts, and also make sure that the pulleys are clean. It's been a while since I looked at it, but I believe the manual calls for somewhere around 1 cm of deflection. You don't want them ultra tight.
If you continue to have squealing problems, pick up a can of belt dressing and that should help, but the issue is almost certainly related to your belt tension.
Old 10-16-2012, 10:32 AM
Drozik's Avatar
Life savers again.
Drozik's Avatar
You guys know ur shiznit.
Old 12-19-2015, 01:22 PM
novice121's Avatar
Guys, I just registered to give a little more input!... This man is correct, but there is also another bolt similar to the bolt in red (pump lockout) that is located and visible to the side of the pump almost following the belt... it is reachable, and visible from the same upper view of the picture... just look for it a little, and you will see both bolts have to be loosen so that the tensioner wing nut can raise the entire pump and tighten the belt.
My honda was squeaking when turning the wheel, so I turned it on, opened the hood, and heard the squek, and also noticed the belt would slip easily when turning (not tight enough).
Like an idiot, I thought I just had to replace the belt, without inspecting it for wear. SO I bought a new belt for like 30 bucks from Amazon, it was supposed to be OEM (Hondas are really strict about certain OEM parts), but they sent me a brand named Bando.
Sure enough after taking the belt out, my old belt was just fine, even after 130,000 miles, and all it was, was just a not tight enough belt.
Here's the pic again just in case that one dissapears off the server:
Old 12-20-2015, 03:06 AM
rudebwoy's Avatar
Clean the pulleys, and spray silicone spray on the belts
Jdm_em1civic
10-21-2013 05:24 PM
lankan-balla
03-08-2013 01:02 PM
khronicboy420
03-03-2012 02:39 PM
highneo
01-04-2009 07:56 AM
d8168055
10-05-2002 06:59 PM
Quick Reply: Power steering belt Trick?
