dohc zc into 92 civic HELP PLEASE
Old 01-14-2009, 02:33 PM
tyler100's Avatar
Default dohc zc into 92 civic HELP PLEASE
ok so i bought a 92 civic for 200$ and have the chance to buy a dohc zc for another 200$
i kno i can use my obd1 injectors for the dohc zc but i really dont have the money to buy the obd1 dizzy for the zc. is there a how to for obd1 dizzy on dohc zc ive seen a picture but now i cant find it. i put a D16a1 into my 91 civic and used the a6 obdo dizzy. and eliminated the cam angle sensor. but now im getting into obd1 and im trying to figure out how to convert the zc to obd1. ive searched all over but nothing that really helps. thanks h-t.
Old 01-14-2009, 04:00 PM
tyler100's Avatar
Default Re: dohc zc into 92 civic HELP PLEASE
no one?
Old 01-14-2009, 04:12 PM
esean93's Avatar
you can make a d15b7 dizzy work somehow.94eg8 know more about it
Old 01-14-2009, 05:41 PM
Seagull Management
94EG8's Avatar
Yeah, you can, you need a cam cap from a B18A1 (B18B1 should also work), this lets you attach the D15B7 distributor with one bolt, you wont have any timing adjustment for the ignition timing, but it does work, i've personally done it before, and so far as I know i'm the only person who has ever done it.
Old 01-14-2009, 06:53 PM
tyler100's Avatar
i got a cam cap. i think i might beable to make a bracket to hold it on too. but have you done the swap? got any write ups? is it even worth it?
Old 01-14-2009, 08:17 PM
REDesignIT's Avatar
yeah, thats right don't forget the torq #7 bolt on the end wheel you need to shave 2mm off that little guy to make it work.
Seriously though here is all the ZC parts link you could possibly use.
http://www.d-series.org/forums/showthread.php?t=91053
JDM motor more common as D16A8 (DOHC ZC)
Old 01-15-2009, 07:02 AM
Seagull Management
94EG8's Avatar
I've done an OBD1 DOHC ZC into a '95 civic before. But thats a pretty straight forward swap, it basically just bolts in. If its a JDM ZC out of a civic and you can get OBD1 components pretty cheap then it might be worth it. If you want some good ZC info check out thezcr.com
low91rex
12
08-06-2007 10:27 AM
freshly boosted DOHC ZC
01-12-2007 11:50 AM
Gold DA9
12-20-2006 03:41 PM
jdm169
05-28-2003 09:13 PM
Quick Reply: dohc zc into 92 civic HELP PLEASE
