SONEM EF bolt-in hydraulic clutch conversion
#176
Re: SONEM EF bolt-in hydraulic clutch conversion
Can you put together a parts list with numbers or vendors?
#177
$40!...
Here is where I mounted my resevoir...
And for those of you worried about space constraints, THIS is what you have to work with...
#178
#180
#182
The air never really made it over to that one on my CRX either. Its been somewhat cold the past 2 days and I dont miss it. The pedal feels great. I'm still messing around with the length of the rod on the MC trying to decide where it feels best. But it grabs very nicely. I'm happy I did the conversion. The guys at Suja seem pretty cool to. They seem like they are willing to listen to suggestions.
#184
Well defrost is a nice thing to have for the side mirrors so that's enough of a reason to attempt to keep it hooked up. Can you explain the rod length thing?
#185
#186
bravo. thought it'd be useful common knowledge. i'm just waiting on the bracket now. going to take the car to the shop today and pull the dash, repair some wiring and wait on parts from a few different places.
#187
I got my bracket in three days. I believe I ordered on tuesday, and got it friday.
#189
First I used this method that you can find in your shop book
I still wasn't getting full engagement of the slave though. Then I found this method somewhere. I believe it was on a Saab site.
1.Connect hose to slave and submerge in fluid.
2.Loosen bleeder bolt but keep wrench in position.
3.Manually push in the piston of the slave. Fluid and/or air should come out. But, before releasing the the piston close the bleeder valve. Then release the piston. That should draw fluid down the pressure line into the slave.
4.Repeat 1-3 until there are no more bubbles.
(Of course you should monitor your reservoir while doing this)
I was able to still get some air out of the line using this method right after I had just done the other. But I wouldn't trust only using the second method if it's a new install. The MC needs to be primed and filled. I think the second method is good for getting those last couple stubborn bubbles out of the line.
I see you're selling your cable to hydro adapter. I have a feeling we might be seeing more of that. Are you planning on installing this kit or are you getting rid of it for another reason?
#190
i switched from cable to hydro this winter and i was planning on using the hasport peice. i really wanted to go full hydro in the first place, but i found a good deal on the hasport kit, before this came out. so i'm hoping to sell the hasport conversion and give this a shot. i havent even tried the hasport piece, but i like the simplicity/function of this setup.
i'd like to see a few more reviews until i make my decision. i'll be using the kit in a drag racing environment so i'd like to see how it works with beefy clutch's and high rpm shifts.
#191
I only have a full face exedy with upgraded pressure plate ("stage 1") so I cant really speak to beefy clutches but, I have had the rex up at 8.2k with the new kit. It seems to react quickly and maintain smooth shifting. But there may be other factors involved there. Like, brand of MC and Slave, bore of MC and Slave, etc. From what I have been looking at it seems Honda always uses a 5/8 bore MC (.625 inches) I was thinking of trying a wilwood MC a size or two up. I want to see if the extra pedal effort is worth the shortened pedal travel. I just need to find out what a Honda CMC measures from stud to stud. If anyone has one out of the car I would really appreciate if you could take a quick measurement. Mine is under the dash. If they do have the same measurement I may try one out. Here's a link to the site for the MC.
http://www.wilwood.com/Products/006-...RRMC/index.asp
#192
pb16b:
My brother says the kit just came in the mail, thanks for the quick delivery. However there is one set back. He said he had to pay the delivery guy $50 C.O.D.
I thought I already paid you extra for shipping to Canada?
Please advise. Thanks
#194
that tubing only supplies the one top vent all the way on the left and the little window defogger on the door from what I could tell. I don't know if all CRX's had the same issue but I hardly got any air out of that vent, I'm assuming thats because its the farthest from the blower?? Thats why I wasnt too sad to see it go.
#196
there shouldn't be COD, maybe duties but $50 for duties is insane! i'll call UPS and find out what happend and get that $50 refunded.
#197
Location: Where the wild things are in, NY, United States of America
1 Post
Actually, if you were going to change to a wilwood master cylinder, the best for ease of use and fitment would probably be the new 'ultra-compact' master cylinders, they come in 5/8", 3/4", 13/16", 7/8", 1" and 1 1/8", and despite the below picture, the kit also comes with a top, feed line and remote resevoir thats like 4.0oz.
Oh P.S. I stock these
