No "True" Integra Lover Knows!!!!
I have been asking this question for quite a while now and a I never seem to get a clear answer.....I wonder if anyone truely knows!!
How do you read the "clock" info on the front of the engine head?
There are 4 "clock locking" emblems on the head...SO WHAT!!! How Do You Read Them
I am trying to fing the exact date and make of my engine but no one can help!!
I know, I know the block says B18C and nothing else...
They say the head has a mark on it but no one can tell me where...
Does AnyOne Know????????
Re: No "True" Integra Lover Knows!!!!
JDM SiR Block manufactured 95-97.
Its a JDM version of a USDM Type-R
Spec.
JDM Honda Integra Type R
Power: 214 hp @ 8000 rpm
Rev-limit: 8,700 rpm
134 ft·lbf @ 7300 rpm
Transmission Type: 5-speed standard with LSD
Displacement: 109.7 cu in
Compression:y 11.1:1
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
Spec.
AND???
what does that tell me?
I am trying to find the exact year and if it is a jdm GS-R or a JDM type-R
how do I find out?
...and thanks for your quick reply!!!
how do I find out?
I agree but it matters to the owner...LOL! I am just curious how to find the date...
and how are you sure its the type-r and not the gsr..Theres a differance of 180 hp to 195 hp...thats something else I would like to know..
and with all honesty...THANK YOU j bizach for speaking with me!!! (The name cracks me up too)
Do you have the head that came with the motor
The head will tell you which it is
OK!!! now we're getting somewhere!!! I do see P72 so I assume I have the gsr..No Problem That is very acceptable!..now to find out how to find the exact date of engine...is the 95-97 all OBD1 for JDM?
lol alrite here the deal not all are obd2 95 is obd1 then in 96 the standard went to obd 2 so a 96 nd up is obd2 now how to tell the diffence is waat im figuring out.
no heres my delima...i'm trying to put this engine in my 90 crx...I need to know if its obd1 or obd2..thats why I need to know so I can figure out which jumper harnesses ect...It's pretty crazy.I'm to the point I need to wire this up!
thanks for your time j bizach...as soon as all this is done ...I will be listing a post so others will know all the info I know..and that you helped me figure out!!!!!
you are sure of this dkrex001 ? Do you know what the other numbers stand for?
and is this a pic of an integra motor or civic?...just making sure there is not a differance in the way they dated them...ya know?
thanks!
thanks!
The jumper harness for obd1 round and yellow
obd2 gray and square
Thanks all-mtr-teg!!!! Your stern post gives me confidence!...Any idea what the other "clock" numbers mean for curiosity sake?
Thanks again!!
Thanks again!!
