Mustang dyno, or Dynojet dyno...
Mustang dyno, or Dynojet dyno?
Question is I made 369hp, and 291tq on a dynojet dyno, then made 265hp torque can't remember. on a Mustang dyno, is there that much of a difference in the dyno's.
B16 on 16psi and a 30 shot of spray.
Dynojets give inflated numbers compared to a properly setup mustang dyno. Dont worry about the numbers. Use the dyno as a tuning tool and only try to make comparisons when keeping the dyno you use constant.
You should not worry too much about the #s just the gains and the tune. There are some mustang dynos that read higher than dynojets. Just really depends how it is calibrated. The most important thing is that you used the dyno for what it really is. A tuning tool.
