modified oem H22 intake manifold
Well, it all started with this one day at work. I took the top part off and decided to smooth the and fill fill weld the bumps and grooves of the awesomely designed H22 manifold
this is a pic of everything smoothed out after welding grinding and JB welding.
after that i opened the TB opening to 70mm
Then I fill welded the back of the lower half. This was done because the fact that no.1 and no.4 intake runner do a 15 degree bend into the manifold, unlike the middle two runners which are a straight shot in. To get the runners to be the same as close as i could, I got all the way down to the bend of no.1 and no.4 intake runners and eliminated the bend. Unlike other people that I have seen porting these manifolds, the bottom on mine was smoothed out because the bumps or runner separation lines actually cross in the flow of the no.1 and no.4 intake runners. You'll know what i mean when you look down the intake manifold and see the angle that 1 and 4 has over the straight runners of 2 and 3. With this said, I think that my manifold will outperform some earlier ported versions and maybe even the Euro-R! Now I'm rocking my runners down to 7 INCHES .
The first bolt hole was also fill welded so I could smooth the inside out, allowing no flow disturbances for no.4 cylinder. It seemed to me that right after the throttle body as the air expanded the bump of the bolt hole by no.4 runner would disturb that flow.
Modified by AWOC at 11:03 AM 11/16/2008
Re: modified oem H22 intake manifold (AWOC)
Here's a shot of the inside. I love that shape!!! Oh yeah get ready to rotate your head
Here's a little BLING. I glass blasted the outside for a nice new finish look and I polished the top flat part where the sicker was then I stamped a little message (SKANK2).
Modified by AWOC at 11:18 AM 11/16/2008
Re: modified oem H22 intake manifold (Giant_Bean)
The car is apart right now. It is getting painted then going in for an H-B upgrade. I don't know when i'll have the chance to dyno the car. I IM'ed NAH2B to see if he wanted to dyno it against his setup, but no response. If a reputable member in here wants to dyno it with their setup I wouldn't mind. I'd even help with dyno costs if necessary.
Good work but just wondering, for all that work you did, wouldn't it be easier to buy the REAL SKUNK2 manifold and be done with it??? I mean which intake manifold flows better? the one you eye balled OR the real SKUNK2 Manifold??? and how much HP gain from the one you made and the real SKUNK2 manifold? and with out the supporting mods you wouldn't gain much... ?
Re: modified oem H22 intake manifold (iMPoRT GeeK)
So before you state that my manifold is "EYE BALLED" you better look at the pics and see that I have the equipment and education to where eye balling is not necessary. So why don't you seat back and relax and maybe you can learn a thing or two. This is a learning curve for most of us and we can only learn by doing it
I assume that you haven't seen the OEM vs Euro R vs Skunk2 dyno compairison. The Euro R made more midrange than the OEM and Skunk2. The Skunk2 made more top end than the OEM and Euro R.
Not that I'm a big fan of the Skunk2 but, to say it's crap is being ignorant. It makes power, just high in the RPM's. It all depends on your build to decide which is best.
But, nice to see some DIY
I'm wondering if this would be useful for those of us that are boosting. Since pressure is being produced rather then suctions. Please let us know if this produces any increase in tq and hp.
we have done this setup for years. it works great. dont forget to open up the sandwich plate, but be careful because it gets very thin and can crack so handle with care. as you increase your mods with headwork, larger displacement, cams, headers you will notice exponential gains! as you go bigger we have noticed solid gains with stacking the sandwich plates. on one of our race motors we had 3 plates on it and it screamed! GL with your setup. let me know if you need some assistance.
Very interesting DIY mod. +1 for originality and +1 for a good idea on the runners. Another note to add in the Honda Book o' Science. While the S2 actually does produce power now, it's a little late in the game and variations on OEM manifolds have been shown to to still be as effective, if not more effective, than the current S2 mani depending on the setup. They should have studied the Euro R, improve on it a little, make it fit USDM H22s, and just sell that. They'd sell like crazy. In the mean time, I still remain a fan of the OEM/custom mani. I can never forget that custom RLZ manifold on the Birdman's motor.
It took a long time so I would charge way too much. You can take you some dremel tools and go about it yourself. It's more fun when you do it yourself
It isnt that fun with dremel tools. haha. I used to work at a shop and we did the same thing with rotary tools and a CNC machine. We didnt go far down as you did though. I just knifed the bottum part of the manifolds runners. Your manifold looks like it took a really long time... Cant wait to see dyno numbers!
Would be curious how much you would charge to take the top piece and hone it out to 68/70mm and cut out the bottom half.
No porting and stuff inside just cut the dividers out???
could do this for other people if it proves effective. Could make some money on the side heh heh
So I started my journey with this with basic tools (big *** compressor that hasn't shut off in 2 hours haha) I love die grinders and a 50 pack of cutoff wheels. I cut the bottom of the top half, the plate with Iab guts taken out and on the bottom I am only gonna cut out the little pieces since they are divided pretty nice between cyl runners.
Won't be as nice as yours but since hours are slow and checks are shorter and I get guaranteed 40 hours a week to sit at home then I figured might as well venture onto the DIY a little more.
After cutting the dremel and some grinding stones and flapper wheels will be coming out.
Looks good and if you get a dyno comparison of this post it up. Definately interested.
