> Acura Integra
Old 11-05-2008, 08:23 PM   #1
Jayman_Gsr
Jayman_Gsr's Avatar
Send a message via MSN to Jayman_Gsr
Default Integra Walbro Pump Install
Well I got the Fuel Pump in the mail and had it in the car within 30 min :D, Here is a lil write up on what I did:
Acura Intega Fuel Pump Install
Walbro
1. Remove the back seat, remove the cover using a philips head screwdriver. Then remove the 6 (10MM) bolts supporting the pump inside the gas tank. Also disconnect the fuel lines and electrical connections to pull the Pump out at a 45 degree angle.
2. Remove the pump from the brace by unpluging the connection then removing the clamps, lifting up on the pump to get the bottom lose the pull outward.
Stock Pump vs Walbro Pump
3.Install the new pump using the new fuel hose cut a bit shorter due to the larger size of the walbro. Use stock as a comparison to get a general idea. Connect the electrical connection reusing the plastic connection lock.
(Note. I had to reuse the screen)
4. Reinstall by CAREFULLY sliding the new pump in at that same angle, tighten the 10MM bolts then reconnect the fuel hoses and electrical connections. I tested before I tightend just to make sure. Then just screw the cover back on and install the back seat.
All DONE!
Not responsible for any damage you may do to your vehicle!!!
97 GSR-Turbo
220whp 208ftlbs tq on 5psi
http://intenseaddictions.com/
Jayman_Gsr is offline Report Post   Reply With Quote
Old 11-05-2008, 08:30 PM   #2
92DAIntegraXSI
92DAIntegraXSI's Avatar
Send a message via AIM to 92DAIntegraXSI
good wrtie up just forgot to mention to disconnect the battery. not to many people are bright enoguh to figure that out. im sure you did thow.
92 DA9 High Compression monster
DA squad member:#329
92 EG8-sold 97 DC4-sold
92DAIntegraXSI is offline Report Post   Reply With Quote
Old 11-05-2008, 10:32 PM   #3
Byaaah!
Byaaah!'s Avatar
Default Re: (92DAIntegraXSI)
Great write up.
What'll happen?
Like a 84' Camaro Z Two Eight iROC
Authenticity WILL prevail. If you wear fake Jordans, / yourself.
KTHNX
Byaaah! is offline Report Post   Reply With Quote
Old 11-06-2008, 02:14 AM   #4
FULLYBUILT2.0
FULLYBUILT2.0's Avatar
Default Re: Integra Walbro Pump Install (Jayman_Gsr)
nice
FULLY BUILT 2.0 B18c1
FULLYBUILT2.0 is offline Report Post   Reply With Quote
Old 11-06-2008, 08:33 AM   #5
Schister66
Man U FTW
Schister66's Avatar
**added to the Forced Induction FAQ**
Bullseye Powered 1999 GSR
S256 @ 16psi on 9.8:1 LS/VTEC + E85 = 385whp/285wtq
Schister66 is offline Report Post   Reply With Quote
Old 11-06-2008, 12:28 PM   #6
Jimmy
Moderator
Jimmy's Avatar
Default Re: (Schister66)
Good idea.. added this to the integra forum faq
/// 1994 Integra RS-T | 2002 cbr f4i
Jimmy is offline Report Post   Reply With Quote
Old 11-06-2008, 12:32 PM   #7
twentyhurtz
twentyhurtz's Avatar
Default Re: (Jimmy)
* i like the, not responsible for any damage to your vehicle note! ha good stuff, i wish all honda's were like this, my girls 89 hatch has the gas level sensor there and her fuel pump is towards the back of the tank, thus you have to drop the tank to change the pump.
90 accord ex
94 civic hatch, 145.5 db on TermLab (800w rms)-sold
95 integra gsr-jdm b18c
twentyhurtz is offline Report Post   Reply With Quote
Old 11-06-2008, 01:12 PM   #8
mac_24_seven
1994 Acura Integra
mac_24_seven's Avatar
Default Re: (twentyhurtz)
Nooo!!! I got Walbro pump in the mail today and was gonna do a DIY. You beat me to it.
And I want to have a DIY in the Integra FAQ!! Guess I never did one good enough And 24 posts too. Gahh!!!
Enough with my whining, good job!
mac_24_seven is offline Report Post   Reply With Quote
Old 11-06-2008, 01:14 PM   #9
Jimmy
Moderator
Jimmy's Avatar
Default Re: (mac_24_seven)
Any helpful thread/info is added to the FAQ.. If you find something or make something post it in the faq thread and it will be added (as long as the images work)
Old 11-06-2008, 01:17 PM   #10
mac_24_seven
1994 Acura Integra
Default Re: (Jimmy)
YAY!!! I have 2 in the FAQ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
I'm pathetic, I know. That kinda made my day Tells you what kinda day I've had doesn't it?
Old 11-06-2008, 02:56 PM   #11
Jayman_Gsr
Jayman_Gsr's Avatar
Actually I didn't disconnect the battery but I did disconnect the main before working on it. My alarm doesn't like the battery to be disconnected.
97 GSR-Turbo
Bookmarks
acura, connection, diy, fuel, gas, honda, install, installation, integra, pump, rsx, tank, tech, walborough, walbro
