bprsk8r4272's 90 civic si Build Thread
Old 10-28-2008, 03:03 PM
bprsk8r4272's Avatar
Default bprsk8r4272's 90 civic si Build Thread
I bought this 1990 civic si for $200 in july or august of 07
heres how it looked when i bought it, It had some ugly clear tail lights, battery relocation kit, and didn't have a hood, engine wire harness, gauge cluster, some interior trim, drivers side seat was ripped on the bolster and the seats didnt fit right i think they were out of a crx si, some of the trim was painted white and yellow but previous owner painted over that with black it looks alright but does need to be re done, the shifter/linkage was not connected, there is some rust/rot on quarter panels near wheel wells, no exhaust or cat, has a pace setter header, and came with crappy rims/tires.
CLICK THE PICS TO MAKE THEM BIGGER...
when i got it home i put on the hood, changed the tail lights, unmounted the battery relocation kit cause it was grounded in the wrong spot and i didnt like where it was, and put different rims/tires on.
here it is as it sits now
i bought the engine wire harness and the shift linkage hooked that up put new ngk plugs/used wires in and a oil change, re-mounted the battery relocation kit, put in a different injector resistor box, and put in a new TPS from a d16y7 and it started right up. i also had to put on a new gas door and popper. bought and hooked up the gauge cluster.
I put on the exhaust and the muffler tip sticks out a lil to much so im going to cut the high flow cat down a couple inches.
15" Acura El rims(center cap not on but i do have all of them)
News:
i took out the engine sold the mpfi swap.
im going to put in a d16z6 and convert to obd1 im getting the engine for $150 and im going to put on a d16y8 IM and LS throttle body.
mount bracket swapped over from the a6.
injector resistor wires connected to each other.
p28 and 92-95 si ecu plugs.
new rear main seal, flywheel & clutch bolts torqued and they have loc tite on them, and si tranny mounted on.
new alt. belt and si alt. swapped over.
dizzy plugs cut off of the si harness and z6 dizzy plugs put on.
i traced back the fan switch wires and cut them down and put on the obd1 plug for it. vtec, 02, and injector plugs added to the si harness then i put a plug on the other end of the vtec and 02 wires to make it look factory and be able to be disconnected easily.
engine in and map plug extended purge plug extended and the clip was different so i changed it.
B&M short shifter in.
header and cold air intake on.
stock ecu plugs cut off and obd1 ecu plugs put on data check wired in also. ecu under the ecu plate.
94+ integra center console and the armrest bracket installed.
well good news she started right up runs good may burn a lil oil but during winter shes getting all new gaskets bearings and rings.
cd player i got.
exhaust cut down 2" and sitting better.
mk3 golf front lip installed and getting ready for a trim.
honda mtf.
1987 accord glove box lock.
Rear wheel arches.
Energy Suspension trailing arm bushings installed and trailing arms painted.
Passenger side wheel well getting ready to be cut out and new piece cut to size.
Passenger side wheel well almost done.
Driver side rust cut out.
Rust on my hatch grinded down now i have to make some pieces to weld in.
Passenger side panel welded in.
Driver side panel welded in.
Passenger side 1/4 panel first layer of duraglas.
Had to add 2 small patches near the gas door.
Rocker rust cut out and a piece welded in.
Front passenger side rocker all welded in and first coat of duraglas on.
Patches welded in on hatch and first coat of duraglas.
First coat of duraglas on drivers side.
Patche welded in on the passenger side door and duraglas on it.
2-3 coats of filler on the passenger side.
Body filler now on the driver side 1/4 panel.
Filler Primer now on the passenger side 1/4 panel.
Found some rust on the roof so i had to take care of that then put some tiger hair then duraglas.
heres some stuff i bought for it so far:
5pc strut bar set $59.99
Tie rod ends $8.36
Mevotech ball joints $26.26
Eibach Lowering Springs $20.00
Cold air intake $20.00
90 si rear sway bar $32.00
15/16" master cylinder $25.00
94-00 integra center console $25.00:
ebay tenrai catback exhaust and ebay high flow cat $174.00 & $28.50:
radio mount and wire harness $2.00:
tsunami power distribution block $29.96:
ebay ss brake lines $66.95:
integra 40/40 brake prop valve $39.99:
glowshift triple pillar gauge pod carbon fiber look $35.45:
90 crx si rear disc conversion got it with the car:
90 civic si front seats $126.00 no rips:
Ractive E-brake handle & boot $25.00
Owner's manual $15.51
Stock radio harness clip $15.00
Gauge Cluster $45.00
Engine wire harness $149.99
NGK Spark Plugs $8.55
Radio Shack piezo buzzer $3.00
Cargo cover $55.99
Dome Light $5.99
Rear bumper $30.00
2.5" Intake bypass valve $6.99
B&M short shifter $29.00
Honda MTF x2 $13.64
1987 accord glove box lock $24.99
Rear wheel arches $62.10
Es TA bushings $24.00
Chipped & Tuned p28 ecu $50.00
Moates Xtreme HULOG Datalog Interface $40.45
Felpro Valve Cover Gasket Set $26.17
NGK Spark Plug Wires $45.06
need to buy:
Steering wheel or horn button
Rear view mirror assembly
Driver side interior 1/4 piece
Rear speaker mounts with trays
Passenger side door interior window strip
Antenna
3 2 1/16" gauges
Tokico Illumina Struts & Shocks or konis/gc
Integra E-brake cables
i plan on doing:
get some missing interior pieces
ls/vtec or crvtec/build and turbo kit
I made a website for the project:
http://civic.gotskillslounge.com
will add more later and more pics
Old 10-14-2009, 02:06 PM
Default Re: bprsk8r4272's 90 civic si Build Thread
Temp. primer on the rest of the working areas just so nothing happens to the areas.
Working on the doors.
Fenders are done.
Everything primed.
Chipped p28 ecu and Moates Xtreme Hulog.
Acura el valve cover, valve cover gasket, and ngk wires.
Old 10-14-2009, 02:46 PM
Keyboard Humorist
4drEF's Avatar
Suggestion on your site.
For the supersize pics reduce the resolution
Things are TOO BIG and take too long to load.
Old 10-14-2009, 07:28 PM
a couple more pics added.
^i'll prolly use my photobucket links eventually like im using on here. the site will just have pretty much whatever i post in here.
Old 10-23-2009, 07:41 AM
more pics added
obd1 dizzy wiring complete
Old 10-23-2009, 11:44 AM
blasterman87's Avatar
looks good so far, i have a 89si thats black also..
Old 10-23-2009, 11:58 AM
macknjack's Avatar
not bad man. keep it goin, we gotta keep the old hatches alive
Old 10-24-2009, 02:45 PM
munky69's Avatar
nice. i'm restoring a beat POS to ;P paint should be soon on mine, gonna be a world of difference LOL.. where'd you get the seat from?
Old 10-27-2009, 01:26 PM
i got both the front seats off of ebay
more pics added
done with converting the engine harness to obd1
extended the map plug and purge extended and plug changed
the engine is in
ecu plugs converted to obd1
wiring is all done
94+ integra center console installed
now i gotta get wires, anti-freeze, honda MTF, and oil change.
Old 02-05-2010, 10:00 AM
87 accord glove box lock from ebay and my rear wheel arches from fixmyrust.com came today
Old 04-20-2010, 07:20 PM
patch panels welded in and es bushings installed on my trailing arms
Old 04-20-2010, 07:49 PM
89LSED's Avatar
Daaamn bro, your putting a lot of time into that thing!! Keep it up! Lookin good
Old 06-11-2010, 06:46 PM
^thanks man
more pics added
Old 09-08-2010, 11:06 AM
car is in high build primer as of a month ago juss waiting for money and to pick a color
Old 09-22-2011, 08:01 AM
havent updated this in a while but my buddy bought a 90 civic si parts car so im taking out any missing pieces and getting rid of some interior that was painted also changed my hood cause it was hood lol
Old 07-22-2012, 12:25 PM
new updates:
i have a chipped p28 with a basemap on it
installed the acura el valve cover along with new ngk wires
more coming soon
Old 09-06-2013, 08:47 AM
finally got to mess around with this again
I installed the new balljoints, master cylinder, and 40/40 brake prop valve
started messing around with the rear disc install but a rear upper control arm bolt broke and a compensator arm bolt started spinning. so I bought both upper control arms and compensator arms used off ebay from cali they just came in today. also last week I ordered from the dealer a rear lower control arm bushing since someone snapped the bolt off and left it like that.
so hopefully this weekend or next weekend I can get to install them then get a alignment
Old 09-06-2013, 10:55 AM
Freemananana's Avatar
Where'd you get lowering springs for $20 or outter tie rods for $8?
Old 09-06-2013, 09:04 PM
got the springs from my buddy and the tie rod ends from a parts place online cant remember which one though
garthjenkins
28
08-02-2011 08:09 PM
RACERX72
01-11-2010 11:14 AM
sonic47
33
12-07-2008 04:04 PM
dohc_profile
17
04-25-2006 05:56 PM
B18Arex
08-29-2002 11:50 PM
Quick Reply: bprsk8r4272's 90 civic si Build Thread
