> Forced Induction
Old 04-07-2009, 09:12 PM   #26
TheShodan
TheShodan's Avatar
Send a message via AIM to TheShodan
Default Re: when does 2.5" intercooler piping start to become a restriction
Originally Posted by TopEndTuner View Post
Okay I was thinking that the CFM I calculated was the Max output and I figured that would vary by the amount of boost. Glad to know I'm good. Does anybody know an equation to calculate the cfm of say any charger at only a percentage of its max?
There is a way to do that, but it is not easy and you have to put in at least 10-15rpm points in order to find out the CFM of the engine to match with the turbocharger. Going by the amount of boost is not as accurate as using CFM. remember, the turbo is an air pump, so volume per cubic meter is best to use.
"Just because it has a divided housing does not make it a damn "Twin Scroll". People need to quit using buzz words they don't understand" -John Roben, Project Manager of Honeywell R&D
TheShodan is offline Report Post   Reply With Quote
Old 04-08-2009, 11:50 AM   #27
HiProfile
HiProfile's Avatar
The fact of the matter is converting still leaves you in the same boat - you'll never know the limit to a given setup w/o some massive amount of formulas & calculations. The esiest way is to look at other setups & how they've done.
As far as the small/large piping, there's virtually no benifit. No body has made any compairisons, they just expect it to work like an NA header with stepped primaries. The problem is the pressure drop the fmic introduces - you don't need stepped charge pipe sizes.
1994 Del Slow VTEC - OEM B16A3 - winter beater
1995 Civic EX coupe - turbo D16Z6 - summer beater
1967 Firebird 326 H.O. - SMC 350ci - needs a bigger cam, or turbo...
HiProfile is offline Report Post   Reply With Quote
Bookmarks
25, az, cfm, convert, flow, hard, holset, hx35w, intercooler, itercooler, lbmin, matter, phoenix, pipeing, piping, size, turbo
