Oil leak from oil filter area '93 Accord
Old 10-01-2008, 08:47 PM
864dr1.3lcarb's Avatar
Default Oil leak from oil filter area '93 Accord
I'm getting a leak from the oil filter housing area. Not sure what it is? Not the oil filter. I replaced that 2 times already. 1 time with OEM filter.
Old 10-01-2008, 10:01 PM
dtapia's Avatar
Default Re: Oil leak from oil filter area '93 Accord (864dr1.3lcarb)
on some models like the se and ex their is a oil cooler that the filter screw's on it and their is 1 o ring that seal it up
Old 10-02-2008, 04:04 AM
hon2984's Avatar
If the hollow oil filter stud came out with the oil filter then you are going to have to use a band wrench to get it tight ( happened to me before ). Check to make sure that there is not 2 gaskets on the oil filter. Also the oil pressure sending unit is directly above the filter, inspect it for leakage.
Old 10-07-2008, 05:49 PM
Default Re: Oil leak from oil filter area '93 Accord (hon2984)
No stud came out. I'll double check for the 2 oil filter gasket.
Old 10-07-2008, 06:30 PM
H-T Order of Merit
TouringAccord's Avatar
check to see if oil is coming from above the oil filter area. If so it could be your sending unit, seems to be a somewhat common thing when you get oil leaking around the filter area.
Old 10-11-2008, 08:48 AM
Wanosd's Avatar
Default Re: Oil leak from oil filter area '93 Accord (TouringAccord)
I had the same problem on my '92 Accord. The oil appeared to be leaking from the oil filter area. It would get on the exhaust area below it, heat up and have this burning smell (almost like the brakes were burning) in addition to generating smoke from underneath the car. It was pretty embarrassing to stop at a stop light...
I thought maybe it was the oil filter o ring, but when I took it in to a specialized car shop that does repairs only on Hondas, Toyotas and Acuras, they diagnosed it as a bad oil sending unit. It cost me about $70 bucks to replace it from them (including labor). I've been oil-leak free since.
Modified by Wanosd at 9:54 AM 10/11/2008
Old 10-12-2008, 06:47 PM
fleetw00d's Avatar
Default Re: Oil leak from oil filter area '93 Accord (Wanosd)
Same here on my 90 and 93. Likely the sending unit itself, not the threads. The oil actually leaks through the unit. Easy replacement, take the filter off to give you better access, if I remember correctly, it has a hex so you can use a socket.
Old 02-28-2009, 07:31 PM
Bad_dude's Avatar
What was the size of the socket, do you remember?
Having leaks from there, would there be big leaks or small leaks? I am getting a little leak every morning before starting the car. During the day, it would be dry but later on, once I get home, there more leaks, bigger ones.
This occurs after I replace my valve cover gasket.
Also last year, the distributor was leaking, so I got gaskets changed, change the valve then also. After a few days, there was tiny leaks, then I cleaned the car under and it's been dried until my recent valve cover gasket change.
My question is, I spray some carb cleaner on the top of the engine, would the leaks be residue from the spray. Mine this occurs a week after I change the valve cover gasket.
Thanks.
DelsolVted
14
03-15-2011 08:12 PM
wesk18
12-26-2008 10:56 AM
TuningHonda
02-26-2008 12:56 PM
TeGGY_LS
08-06-2004 01:16 PM
degradated
10-29-2001 07:32 PM
Quick Reply: Oil leak from oil filter area '93 Accord
