Classic Hondas All Pre-1988 Hondas.
1965 S600 Roadster with an F20C heart..
Old 10-03-2011, 02:16 PM
  #201
GreazyEJ2's Avatar
Default Re: 1965 S600 Roadster with an F20C heart..
:cough: updates :cough:
Old 10-11-2011, 08:12 PM
  #202
95egianp's Avatar
I absolutely love the look of these old S600's!
Old 10-14-2011, 10:05 AM
  #203
rrambo4u's Avatar
sweet ride, now for some updates.
Old 10-15-2011, 10:40 PM
  #204
ic
ic's Avatar
been checking in on this for a long time.
looking amazing.
Old 10-16-2011, 05:14 PM
  #205
xero_xero's Avatar
I am glad i tripped over this. amazing build. fab looks near perfect.
Old 10-31-2011, 06:57 PM
  #206
willywilly's Avatar
wow, this thing is gonna be badass!
Old 11-01-2011, 12:09 PM
  #207
Andrew Marquis's Avatar
Great job.
Old 11-02-2011, 08:44 AM
  #208
E-AT_me's Avatar
looking sick. i love it so much. can't wait to see.
Old 11-02-2011, 10:28 AM
  #209
ic
ic's Avatar
this is gonna be so goddamn baller
Old 11-02-2011, 02:15 PM
  #210
bombastick's Avatar
Nice work ;o
Old 11-06-2011, 08:59 AM
  #211
vinem1's Avatar
Nice
Old 11-14-2011, 02:47 PM
  #212
Peter Davis's Avatar
What a beast. I've bought a coupe, complete, but in a million bits. Currently tossing up what to do. Modify and update to improve or stick with original. I must say you're committment is impressive. I'm exploring the possibility of installing another bike motor. A current 600cc honda motor produces double the original horsepower and is actually more compact. The trick is how to convert to rear wheel drive?
Old 11-14-2011, 07:32 PM
  #213
Wrona's Avatar
this car is being done right good luck to you
Old 11-15-2011, 02:56 PM
  #214
trewqs600's Avatar
Leo, your car is looking great.The engine bay didn't require much alteration at all. Are you going to keep the interior original? I hope it looks like a s600 coupe that goes like a scoulded cat.
Old 11-15-2011, 06:12 PM
  #215
Originally Posted by astroleo_1976
If it complete, i would say stick with it..
There is a guy here in Aus that has a Kawasaki zx12 engine in one. Just google search honda s600 zx12 there's a few you tube clips might be able to contact him.
Have a look at this motor. They make kits to convert Hayabusa motors to rear wheel drive car applications. The also make a v8 essentially using two hayabusa motors. Hartley Enterprises
The H2 is designed to provide a rugged durable platform for those that desire to put a Hayabusa engine in a car type application. It has a billet case and sump, flywheel for mounting a clutch and rear drive take off, 60 amp alternator, 4 stage dry sump and starter. Rear adapter plates are planned for popular gearboxes. The engine is estimated to have a fully dressed weight of 140lbs and can produce 175 to 250 hp NA; and much more in turbo form.
The H2 BUSA engine is offered as a kit or complete engine. The base kit utilizes the Hayabusa crankshaft by using a special adapter for mounting the flywheel. A Stoker kit is offered with bespoke 72mm stroke crankshaft, with larger bearing journals, H beam billet rods and related pieces to allow building a 1.6 liter engine.
See the price page for more details.
Considering the interest in buggies and auto-cross, the engine was designed with an enclosed belt drive for the alternator and oil pump. Using a single belt instead of two belts shortens the engine length by 20mm.
This picture shows the belt drive with the cover removed. The pulley drive for the oil pump and alternator can be seen. The large hole in the front cover is to allow air to circulate through the belt drive and out by the alternator aided by the alternator fan. The large hole is shrouded by the pulley's shoulder so it is effective at keeping out large debris.
The engine lower part of the case is machined from 6061-T6 solid aluminum. The primary design objectives were compact size, stiff and robust and optimize packaging for 4 wheel applications.
This view shows right side of the engine and the 4 lb flywheel (140mm clutch). The ancillaries are all placed under the intake side to aid in packaging. It also keeps them away from the heat of the exhaust and gives plenty of room for that extra large turbo which will one day find it's way to this engine.
Dyno testing proved durability and power. The engine tested is over-bored to 84mm (1.4 liter) but otherwise uses completely stock Hayabusa heads and cams. On this run it produced 195hp with a very flat torque curve, but more is available with modifications.
The engine is very smooth. The bit of vibration seen at the end of the video was due to the the engine hitting the 11,000 rpm rev. limit.
Old 11-30-2011, 08:08 AM
  #216
john420420's Avatar
I was considering the same type of swap on my 65 LHD coupe. Looks great!
Old 12-28-2011, 08:57 PM
  #217
Bozwell's Avatar
looking good Leo. got it back on the chassis yet?
mine is way behind shedule and so much still to do.
Old 01-01-2012, 11:16 PM
  #218
franckcrx's Avatar
Congrats, it's a very nice work you are doing, i will keep on following ^^
Old 01-06-2012, 05:54 AM
  #219
kp
kp's Avatar
Ooooooh yes, very good. That is one beautiful build. It must be nice to lay out every wire and hose just the way you want right from the start. Keep up the solid work!
Old 01-06-2012, 02:34 PM
  #220
Bozwell's Avatar
6PK 1000 belt, adjustable altenator bracket and idle gear swapped for the grooved one for a simple belt arrangement. but the alt is very close to to the uprite.
and i'm actually making the complete exhaust system at the moment so i know where to weld the brackets to the chassis. chassis weighs a ton with all the extra metal iv'e added.
i'm very jealous on how far ahead you are though. (even though it isn't a race) iv'e got lots of thoughts on the exhaust system so if there is anything you wish to ask send me a PM
Old 01-17-2012, 02:09 AM
  #221
I notice from the photos you are running a standard steering column. Since you've gone over 45%of the original motor capacity according to the RTA guidelines you must install a collapseable steering column. Has your engineer advised differently?
You're headers are very close to the steering column and inner guard. Could there be an issue with engine rotation under load?
Regards,
Peter
Old 01-24-2012, 11:36 AM
  #222
1AKatie's Avatar
Subscribed, this is unbelievable!
Old 05-27-2012, 03:35 PM
  #223
MiraiZ's Avatar
bump...more please!
Old 05-28-2012, 12:11 PM
  #224
Dave600's Avatar
Fantastic project. Car looks great thus far. I just picked up poor condition and engineless 1965 S600 so this is great inspiration.
Old 05-28-2012, 10:40 PM
  #225
mvnssa's Avatar
Hi,
can I ask were did you get the POLYURETHANE 75 A body mounts from? I live in Australia.
Quick Reply: 1965 S600 Roadster with an F20C heart..
