Old 03-31-2015, 04:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications and General Overview
Print Wikipost
FAQ: Maintenance Schedules
Old 09-16-2008, 10:21 PM
Sanji
toyomatt84's Avatar
Default FAQ: Maintenance Schedules
Here's the maintenance routines for 2001-2005 Civics:
(NOTE: Check engine oil and coolant at each fuel stop.)
<u>Normal Conditions</u>
10,000 mil/16,000 km/1 yr
- Replace engine oil.
- Rotate tires.
20,000 mil/32,000 km/1 yr
- Rotate tires.
- Replace engine oil filter.
- Inspect front and rear brakes.
- Check parking brake adjustment.
- Inspect tie rod ends, steering gear box and boots.
- Inspect suspension components.
- Inspect driveshaft boots.
- Inspect brake hoses and lines (including ABS).
- Check all fluid levels, condition of fluids, and check for leaks.
- Inspect exhaust system.
- Inspect fuel lines and connections.
30,000 mil/48,000 km/2 yrs
- Rotate tires.
- Inspect and adjust drive belts.
- Replace air conditioning filter.
- Replace air cleaner element every 30,000 mil/48,000 km (independent of time).
40,000 mil/64,000 km/2 yrs
- Rotate tires.
50,000 mil/80,000 km/3 yrs
- Rotate tires.
- Replace brake fluid every 3 years (independent of mileage).
60,000 mil/96,000 km/3 yrs
- Rotate tires.
- CVT Transmissions: Replace transmission fluid every 60,000 mil/96,000 km/3 yrs, then every 40,000 mil/64,000 km/2 yrs.
70,000 mil/112,000 km/4 yrs
- Rotate tires.
80,000 mil/128,000 km/4 yrs
- Rotate tires.
90,000 mil/144,000 km/5 yrs
- Rotate tires.
100,000 mil/160,000 km/5 yrs
- Rotate tires.
Every 110,000 mi/176,000 km
- Inspect valve clearance.
- Replace spark plugs.
- Replace timing belt.
- Inspect water pump.
- Inspect idle speed.
110,000 mil/176,000 km/6 yrs
- Rotate tires.
120,000 mil/192,000 km/6 yrs
- Rotate tires.
- MT/AT Transmissions: Replace transmission fluid every 120,000 mil/192,000 km/6 yrs, then every 90,000 mil/144,000 km/5 yrs.
Every 120,000 mil/192,000 km/6 yrs
- Replace engine coolant, thereafter every 60,000 mil/96,000 km/5 yrs.
Old 09-16-2008, 10:23 PM
Sanji
toyomatt84's Avatar
Severe Conditions
5,000 mil/8,000 km/6 mos
- Rotate tires.
- Lubricate all hinges, locks, and latches with multipurpose grease.
15,000 mil/24,000 km/1-1/2 yrs
- Replace air cleaner element every 15,000 mil/24,000 km (independent of time).
- Rotate tires.
- Inspect cooling system hoses and connections.
- Check all lights.
- Inspect the underbody.
25,000 mil/40,000 km/2 yrs
- Rotate tires.
35,000 mil/56,000 km/2-1/2 yrs
- Rotate tires.
- Check all lights.
45,000 mil/72,000 km/3 yrs
- Rotate tires.
55,000 mil/88,000 km/3-1/2 yrs
- Rotate tires.
- Check all lights.
- MT/AT: Replace transmission fluid.
- CVT: Replace transmission fluid, thereafter every 40,000 mil/64,000 km/3 yrs.
65,000 mil/104,000 km/4 yrs
- Rotate tires.
75,000 mil/120,000 km/4-1/2 yrs
- Rotate tires.
- Check all lights.
85,000 mil/136,000 km/5 yrs
- Rotate tires.
- AT: Replace transmission fluid.
Old 09-17-2008, 05:07 AM
Sanji
toyomatt84's Avatar
For those wondering about the two lists...
According to the Owner's Manual:
Normal Conditions - US Residents
Severe Conditions - Canadian Residents
Any interval not listed on the Severe Conditions, is to be considered a normal condition wear item.
Example: Coolant replacement intervals stay the same for both conditions.
Old 09-17-2008, 05:24 AM
daddy's Avatar
Default Re: (toyomatt84)
good info matt!
Old 09-17-2008, 09:42 PM
Sanji
toyomatt84's Avatar
Default Re: (daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy &raquo;</TD></TR><TR><TD CLASS="quote">good info matt!</TD></TR></TABLE>
I finally got around to writing it all up, per the request in the FAQ thread.
Old 07-31-2009, 04:20 PM
Pztñz's Avatar
Default Re: FAQ: Maintenance Schedules
I had already seen this FAQ but my question was, what products, parts or brands, are the BEST stuff for our cars? Products and parts relating to the full service tune up. (for example, the best oil, filters, spark plugs, coolants, belts, best autoparts store, napa, autozone, kragen, etc.) I'm only looking for BEST QUALITY autoparts, I want to keep my engine running good and saving gas. What experiences have you guys had with certain brands?
Old 07-31-2009, 08:47 PM
Sanji
toyomatt84's Avatar
Honda's OEM parts listings are the obvious choice. Start with the OEM parts distributors listed in the FAQ's, and get liquids/common replaceables (coolant/oil filter) through a local dealership.
KrazyDawg
03-18-2008 04:39 PM
rushbuster70
15
08-06-2007 07:17 PM
jayturboef
Honda Civic (2006 - 2015)
04-15-2007 02:49 PM
yazac
08-16-2003 12:55 AM
joemama
07-18-2001 04:24 AM
Quick Reply: FAQ: Maintenance Schedules
