DIY: DC5 Cluster Conversion
#27
#29
#30
#32
#36
Re: DIY: DC5 Cluster Conversion
how did you guys "trim" your bezels ?...i tried fitting my bezel over the cluster, and it looks like im going to have to do a lot more than just a trim.
#37
we used a dremmel on the sides of the bezzel, you have to remove about 1-1 1/2" from the top and eye ball the sides, you will also have to trim the two bumps on the back of the actual cluster other wise it doesnt sit flush and you will have to deal with having an open space on the bottom of cluster
#41
#42
Take your time about it or looks like ****. It took about an hour to do well. When everything is installed, you will have a space at the bottom. The only way to solve this problem is fiberglass telescope to cover the deficit.
#43
to reset your SRS light
http://www.civicforums.com/forums/11...srs-light.html
that cluster is from a type-r, would the type-s work the same way?
even if the immobilizer light does not come on does it still work?
#44
how did you guys mount down the cluster?
im using the 2002 rsx type-s cluster
the same one as sppon.ek
because the 2002 em2 cluster has two front screws n 1 top screw
rsx type s has two rear screws
im stuck there
all wires are striped n ready to solder
plz help
im stuck there
plz help
#45
just centre it, put bezel in and put screws in, should hold it in place as is.
#46
so no bolts to hold the cluster down? O_o
only bezel holds it down?
n how exactly did u trim the bezel?
i dont hav a dremel, but can get one, can i measure n then cut?
or is it all by eye?
sorry for all the questions just dont wanna mess this up
#48
Function>Fashion
#49
these are PDF files for Rsx connector n EM2 connector
1st is rsx
2nd is em2
hope this helps
RS0206202196A.pdf
CI0105202229A.pdf
1st is rsx
2nd is em2
hope this helps
RS0206202196A.pdf
CI0105202229A.pdf
#50
o .O
mk thanks
im still stuck as to how the bezel gets trimmed lol
when u cut the rear mounts off did you cut them flush off?
like the cluster was completely flat??
ny1 hav pics of bezel trimed n fitted???
plz i needz help
mk thanks
plz i needz help
