> Honda Civic (2001- 2005)
Old 09-16-2008, 11:46 AM   #1
jamescardenas07
jamescardenas07's Avatar
Default DIY: DC5 Cluster Conversion
Items Needed:
-DC5 Cluster w/ Pigtails
1. Disconnect the negative terminal on the battery
2. Remove the cluster bezel
3. Remove the cluster
4. Cut off the 2 plugs that goes to the cluster
5. Strip the wires where you just cut off the plugs and on the DC5 cluster pigtails.
6. Solder each wire by color. The 01-02's will only have one ground wire (blk), so what you gotta do is connect the 2 ground wires from the dc5 cluster pigtails to the one ground wire on the dash harness. The 03-05's have 2 grounds. The DC5 ITR cluster does not have Cruise Control or Immobilizer so those 2 wires will not be connected if you choose to use this cluster. After soldering, heatshrink the exposed wire.
(so i don't confuse anyone, the pink wire had to be lengthened along with 2-3 other wires. i didn't have any pink wire so i used another color.)
7. Plug in the harness to the cluster & reconnect the negative terminal on the battery. Test drive the car to see if everything is working.
8. Re-fit the cluster bezel. It won't fit correctly, so what you gotta do is look where it hits the cluster and dremel that part off little by little. Take your time on this or else it will look like crap. It took me about an hour to get it nice. When everything is fitted you will have a gap at the bottom. The only way to fix this is to fiberglass the bezel to cover the gap.
9. Finished conversion:
Modified by jamescardenas07 at 7:23 PM 10/23/2008
'04 EM2 - Weekend
'93 EH2 - Daily
Vouches: NBPej1
jamescardenas07 is offline Report Post   Reply With Quote
Old 09-16-2008, 04:38 PM   #2
Harlowe
Function>Fashion
Harlowe's Avatar
Send a message via AIM to Harlowe
Verry naicee
2001 Honda Civic LX - meow
1991 Honda Civic Si OBD1 D16z6T (unfinished project) - Sold
Harlowe is offline Report Post   Reply With Quote
Old 12-15-2008, 04:28 PM   #3
supafil25
supafil25's Avatar
im doing this swap and i have some wires left over.
i color matched most of the wires.
i have 1 wire left over from the dc5 pig tails (black yellow)
and 3 wires on the car harness (red black)(blue black)(white)
supafil25 is offline Report Post   Reply With Quote
Old 04-13-2009, 11:50 AM   #4
ApexRR
2003 Honda Civic
ApexRR's Avatar
Send a message via Skype™ to ApexRR
Default Re: DIY: DC5 Cluster Conversion
nice DIY!
what if you want to swap an EP3 cluster into EM2?same wiring?
ApexRR is offline Report Post   Reply With Quote
Old 06-29-2009, 03:04 AM   #5
bigdawgky
bigdawgky's Avatar
Send a message via AIM to bigdawgky
How to get the temp gauge working?
Modifry.com?
Vouches: a97b18b, Jusdm, boosted76, kamanian, jaedm
bigdawgky is offline Report Post   Reply With Quote
Old 07-04-2009, 04:45 PM   #6
jerzzehook
Any adjusting required so th eguages work properly
jerzzehook is offline Report Post   Reply With Quote
Old 07-13-2009, 05:43 PM   #7
j_moreno
j_moreno's Avatar
Send a message via AIM to j_moreno
I believe that you have to swap the temp sensor for a dc5 one to get the temp guage to work. Snice when you do a K-swap for have to use the civic's temp sensor for the guage to work with the civic's cluster.
j_moreno is offline Report Post   Reply With Quote
Old 07-14-2009, 01:33 AM   #8
jamescardenas07
the stock d17 sensor works fine using the rsx cluster
'04 EM2 - Weekend
'93 EH2 - Daily
Vouches: NBPej1
Old 07-14-2009, 12:16 PM   #9
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
Are you sure about that? The sensor had to be replaced when I went from D17 to K24.
*free hugs*
IA '09: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 07-14-2009, 03:55 PM   #10
jamescardenas07
well i was using the rsx cluster when i still had my d17.
'04 EM2 - Weekend
'93 EH2 - Daily
Vouches: NBPej1
Old 07-14-2009, 04:02 PM   #11
Jdm92accordex
1992 Honda Accord
Jdm92accordex's Avatar
Send a message via MSN to Jdm92accordex
is there anything special you have to do to go from mph to km/ph?
1992 Honda Accord Ex - Gone
Civic in the making.
Jdm92accordex is offline Report Post   Reply With Quote
Old 07-14-2009, 04:08 PM   #12
toyomatt84
Sanji
toyomatt84's Avatar
Umm... not all DC5 clusters are metric-based. Every DC5 manufactured for the US market, is imperial measurement-based.
*free hugs*
Old 07-14-2009, 05:19 PM   #13
Harlowe
Function>Fashion
Harlowe's Avatar
I've had an RSX cluster in my D17 powered em2 for about a year, no problems and no sensor changes.
Old 08-25-2009, 11:43 AM   #14
eghatch4sale
eghatch4sale's Avatar
Send a message via AIM to eghatch4sale
any pics of it installed ???????
eghatch4sale is offline Report Post   Reply With Quote
Old 10-01-2009, 01:45 PM   #15
civic_ceze
civic_ceze's Avatar
i have those colors left over too from the car harness as well, thats where i'm stuck and need help
civic_ceze is offline Report Post   Reply With Quote
Bookmarks
acura, civic, cluser, cluster, conversion, convert, dash, dc5, diy, em2, ep3, honda, rsx, s2000, wiring
