Yonaka full coilovers
So I just got my Yonaka coilovers after a 2 month wait but am glad i got them. I ordered them from Stat Racing which is one of our sponsors for if you can believe it $499. This is the best price on coilovers i have found now they aren't valve adjustable but ride height is also they are for a EG/DC but i have forks so no prob. Under first inspection they seem well made and of good quality here is what they look like
So i got them in I did have to do a little modification but i kinda expected that since there For EG/DC. The only gripe i have right know is the front is all the way down. I took out all the preload and lowered the perches almost all the way down to get my car where i wanted. The back could go down alot more but dont need to. I also went for a test drive and loved them it felt firm but still smooth and pretty comfortable. You can feel the road but its not like really harsh it feel nice I havent really thrown it through some corners yet but what i have felt very good. The spring rates and valving are matched perfect i was a little wierded out when i read that they were 12k front and 6k rear. But like i said they felt well balanced
Re: (aznkr4zyboi)
i had to clearance the fork so they dont rub on my axles and make the fork bolt hold the brake line you can check out all the work i did here
now for the install
old and new
had to grind clearence for the axles so they dont rub and it worked great no rubbing at all
Also no brak line brakets so i drille this out to mount it on the fork bolt
took off this one dont need it anymore
back is in
this is how far the back goes down now when its in the air
and all done with this side on to the other one
now for the install
old and new
back is in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">12k = 672 lb/in... sounds EXTREMELY high for street use. </TD></TR></TABLE>
hmmm....whats the pro's and con's of that? really curious...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kuppa »</TD></TR><TR><TD CLASS="quote">i thought so too but it feel good i like them</TD></TR></TABLE>
how much smoother does it ride after your previous setup?
i want somebody who's had experience with mid range - high end suspension setups post a review. None the less the yonaka full coilovers should out perform your hold ebay/stock shock combo.
Any warranty for these coilovers?
Modified by bmoua at 3:59 PM 9/20/2008
Re: (Kuppa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kuppa »</TD></TR><TR><TD CLASS="quote">i had to clearance the fork so they dont rub on my axles and make the fork bolt hold the brake line you can check out all the work i did here
now for the install
old and new
I'm not following this. The axles should not be touching the forks at all. Also, the shock fork on each side should be a mirror image of each other. In that pic above, those are 2 forks from the left side of the car (although they look slightly different). You're not using both of those on the front of your car are you? If so, that's why the axle was rubbing, and you really need to get the correct fork on there ASAP.
now for the install
old and new
well first off i drive a DA these coilovers are for a DC. Next the fork on the left is stock and right is DC notice how much more the one on the left has more arch or curve. The reason for that is to clear the axle so to use the dc forks and my coilovers i made a small clearencs area to clear my axle. Now i dont really have any problems and many people have done a DC to DA suspension swap. that is why there wuld have been rubbing but i have fixed it before it started
Re: (Kuppa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kuppa »</TD></TR><TR><TD CLASS="quote">well first off i drive a DA these coilovers are for a DC. Next the fork on the left is stock and right is DC notice how much more the one on the left has more arch or curve. The reason for that is to clear the axle so to use the dc forks and my coilovers i made a small clearencs area to clear my axle. Now i dont really have any problems and many people have done a DC to DA suspension swap. that is why there wuld have been rubbing but i have fixed it before it started</TD></TR></TABLE>
Why didn't you just use the DA forks, and attach them to your new coilovers?
That looks dangerous.
Re: (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 »</TD></TR><TR><TD CLASS="quote">
That looks dangerous. </TD></TR></TABLE>
The DA shocks are smaller than the the Dc ones .... he has to use the DC forks.
The little shaving that was done will not affect the car's suspension
Re: (wildcat98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildcat98 »</TD></TR><TR><TD CLASS="quote">
The little shaving that was done will not affect the car's suspension</TD></TR></TABLE>
Wasn't aware of this, I thought they were the same.
I've never owned a DA, only DC's.
