engine cranks but won't start after airbag deployment
I was involved in an accident. My airbags deployed after being hit on front left side bumper. No mechanical damage is present under the hood. When I go to try and start the engine all it does is crank but It will not turn over. I drive a 96" civic dx. Any help? Please.
H-T White Ops
Re: engine cranks but won't start after airbag deployment (jf19)
From a search it sounds like it could be a ground or an inertia switch / SRS has to be rest. I know USDM 6th gens have the SRS unit within the cabin, which contains the switch.
https://honda-tech.com/zerothread?id=2099671
https://honda-tech.com/zerothread?id=2063513
https://honda-tech.com/zerothread?id=2062502
https://honda-tech.com/zerothread?id=849546
https://honda-tech.com/zerothread?id=117397
Re: engine cranks but won't start after airbag deployment (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">From a search it sounds like it could be a ground or an inertia switch / SRS has to be rest. I know USDM 6th gens have the SRS unit within the cabin, which contains the switch.
https://honda-tech.com/zerothread?id=117397</TD></TR></TABLE>
x2
x2
