MFactory Forged Gears - THE SPORTSMAN RACER'S CHOICE IN PERFORMANCE GEARS!
Hello Honda-Tech,
Close Ratio Gears
Achieve the ultimate in acceleration with the MFactory Close Ratio Gears. Diamond Cut to exacting tolerances from fully Carburized Forged Nickel-Chromoly Steel and put through our own proprietary heat treatment process, you will not find a stronger, more reliable product on the market. Our special treatment process makes our gears several times stronger & tougher than OEM Gears and are specifically designed to endure the demanding requirements of high-power track/drag cars.
- Made from 100% Pure Australian Steel, NOT cheap Chinese Steel
- Advanced gear geometry designed using industry-leading software puts more power to the ground
- As used on several Championship-Winning Race Cars
After installing our gears, you will experience a phenomenal increase in acceleration despite a lower top speed. Click here to see how much power you could gain!
Fitments:
Honda B16A/16B/18C:
1st - 3.070
2nd - Re-use OEM 2nd Gear
3rd - 1.625 or 1.695
4th - 1.296 or 1.384 (Slight modification required to transmission casing when installing 1.384)
5th - 1.000 or 1.130 or 1.210
RECOMMENDED SYNCHROS: When ordering your MFactory Close Ratio Gears, we highly recommend that you order our Carbon-Moly Synchros at the same time. By utilizing a carbon/molybdenum coating technology, which acts as braking material during gear engagement, this allows for quicker and more precise shifting. This also prolongs the life of your new synchronous gearset. Available for Honda B16A2/16B/18C, D15/16 & H22A in 3rd, 4th & 5th Gears. CLICK HERE for more information.
Final Drive Gears
Just like our close ratio gears, the MFactory final drive gears are also cut from the same high quality fully Carburized Forged Nickel-Chromoly Steel while also benefiting from our proprietary heat treatment process. As a result, we are proud to offer enthusiasts the best final drive gears on the market today.
By changing your final gear ratios, you can experience a dramatic increase in acceleration, giving you on average, a 10-15% increase in torque throughout the entire rev-range over the OEM Final Drive. CLICK HERE to see how much power you could gain!
Honda B16A2 Fitments: Will not fit models equipped with Factory LSD
Honda B16A2 4.923: Offering a revised design over our previous generation 4.928 Final Drive Gears. Forged from stronger steel with a 50% larger tooth profile yet almost 1kg lighter!
Honda Cable Fitments: Will not fit models equipped with Factory LSD. 92-93 YS1 transmissions should use B16A2 fitments
Honda '98 Spec Fitments: Designed for the '98 Spec Integra Type-R with Factory 4.785 Final Drive
Take your performance to the next level with the MFactory PRO Series Gears. Recognizing the demand for transmission components that can withstand the extreme shock loads produced during Drag Racing, MFactory Competition Products are proud to offer our range of top-tier competition level gears.
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel and put through our own proprietary heat treatment process, the MFactory PRO Series Gears are the pinnacle of off-the-shelf performance gears for today's Sport Compact.
Through the use of leading-edge Solidworks 3D CAD & Cosmos FEA software, our advanced gear geometry helps to increase tooth strength, reduce friction and, most importantly, minimize parasitic drivetrain losses. Transmissions built with MFactory PRO Series Gears transfer, on average, 1-2% more power to the ground over our competitors!
- Designed to withstand the extreme shock loads of competition-level Drag Racing
- As used on Project Utah, our 9sec SFWD Drag Car
PRO Dog Gear Sets
Our premier transmission upgrade, the MFactory PRO Series Dog Gear Sets includes our newly redesigned Straight-Cut Shafts & Gears, increasing drivetrain efficiency and virtually eliminating Axial Shock Loads. Please note that Dog Engagement is not recommended for use on the Street.
As requested by our large number of drag racing customers, we are proud to offer our PRO Series Gear Set for the B-Series transmission, designed to withstand high-horsepower boosted applications! A highly recommended upgrade for those running 500hp+.
By keeping our gears synchronous engagement, our gears are a direct swap for your oem gears with no further parts required for installation and, unlike a dog transmission, are suitable for a daily driver.
Whether used standalone or alongside our PRO Series Gear Sets, our redesigned PRO Series Final Drive Gears increase drivetrain efficiency and are the final link to fine-tuning your race transmission.
By changing your final gear ratios, you can experience a dramatic increase in acceleration throughout the rev-range, giving you on average, a 15% increase in torque at any given speed over the OEM Final Drive. Infact, on a USDM Integra Type-R with stock 4.4 Final Drive, when driving along at 57mph, you will have an extra 38whp on tap with our 4.928 Final Drive!
<---------- IMPORTANT NOTICE ---------->
We have recently become aware of cheap and inferior "copies" of our Final Drives & Close Ratio Gear Sets, including our own custom ratios, being made available on the market. These DO NOT go through the same forging and heat treatment processes and will compromise your safety if installed on your vehicle. STAY SAFE and only purchase your Final Drives & Close Ratio Gears Sets from an Authorized MFactory Dealer
We would also like to take this opportunity to mention our Race Transmissions Service
Be it for a rebuild or a brand new assembly, once we receive your work order, we will disassemble your transmission, take our initial measurements and prepare your selected MFactory components for installation. All work to your transmission is performed by our 12 year Honda/Acura Factory Certified Master Technician. Guillaume "G-Man" Marceau's meticulous work style and racing oriented background allow for him to assemble your transmission with your specific application in mind. All work is done in our dedicated cleanroom allowing for optimal longevity and performance. During assembly, our special methods and procedures are utilized that help our own Team MFactory cars perform above all of the competition.
Dedicated Cleanroom
Tricks-of-the-trade!!
Assembled B-Series Transmission with MFactory PRO Series Gear Set
For further information on how we can help you to optimize your race transmission setup, please feel free to call our workshop on (360) 738-8021 and ask for G-Man
The car hasn't been performing well so I have been just taking a break to regroup. I will have the car out for the next CMI next month, hopefully running correctly. Lisa the last I talked to her she has the flu and is just trying rest up. How have yo been since vegas? What have you been up to?
9.96@149mph SFWD
MidnightPerformance
3282 LuYung Dr.
Rancho Cordova, Ca. 95742
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaMarketPlace.com content, comments, or advertising. HondaMarketPlace.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaMarketPlace.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
