| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Dealer Listings | Garage | Vendor Directory |
#1 | |||||
99' Hatch (first and only car since 03) 86' 250 rebel (sold) daymn it was a blast.... i miss it 06' Ninja 500R (sold) guys bro crashed it the next day.... don't miss it that much 93' CBR900RR w/ 98' 900RR repsol farings (current) Lovin it! |
#2 |
Location: ....................................................................................................
not bad very nice write up ^^^ but myself personally would just stick to the original hood latch so i don't have to mess around with to get the fender off and what not
#3 |
i never took the fender off...
just slipped the mount under it and bolted it down.
#4 |
#5 |
Kool... and nice write up. I think youre being tricky though cuz that looks an awful lot like a d16y7 more than it does a k20 haha.
2000 Honda Civic Ex EJ8 Squad Member #448 Want a CUSTOM valve cover for CHEAP? PM me. |
#6 |
Wash the engine bay too while you are at it... Yikes.
[b]95 <FONT COLOR="green">Civic</FONT><FONT COLOR="gray"> LX</FONT> Ferio EG Squad #39 |
#7 | |
#8 | |
VERY GOOD DIY i paid 110 for my tiens dampers. but very nice none the less. I always told my friends that this could be done with rear eg shocks...but most of us were to lazy. props
DAP - 15g Greddy kit 257hp/227tq http://www.wvmotorsports.com UltraRare 96-00 ashtray http://www.hondamarketplace.com/showthread.phpt=2542732 |
#9 |
thanks for the replies guys.. yes i know. im a dirty wh*re.
just too lazy to clean it. but it's ok, i always run mobil1 full synthetic and Honda MTF. It's clean on the inside and thay's all that matters thanks for lookin
#10 |
Nice write up, but you should really block your VIN #
#11 |
why not try to match the MADE FOR hood mounts?
i bought my tein hood dampeners and its a much cleaner instal and the mounts are solid. urs wouldnt look to bad if you used heavier steel and grinded the edges smooth and painted them. just get some good size angle iron once you have the right locations figured out for the struts travel length.
sold all my civics
#12 |
nice lol will this also work for the egs
94 EG2 in the making ///// My Voches are in my Bio |
#13 |
"MADE FOR" mounts that come on the already made kits are difficult to make. if you compare them to the eg dampers, the ends of the eg dampers are bolts which you put a nut on to tighten. the ready made dampers have a cup at the ends, which secure to a ball mount. That kind of stuff cant be ghetto rigged.
#14 |
good DIY but man simple green is all I can say.
"Tap Snap or Nap" You pick! |
#15 |
If u do some paint on the shock, like tein's green color it will be a very good looking!
good DIY, love it! |
#16 | |
i like your style. trick look with budget in mind.
#17 |
Location: I like tea and cake for tea and cake time, Moore/OKC OK, usa
Nice idea. Cleaner cuts would make it look a lot better. $20 could have been invested in cleaning the motor thouroughly, having lunch, and a movie. But, good write up nonetheless.
WTB:99-00 VSM Driver's side fender WTB:02 RSX-S hood(ABP)/hood bra I ♥ Summer Briann and
#18 |
just did this on a 98 awd manual crv. I couldnt find the 92-95 hatch shocks, so I used 95 Acura Legend hood dampeners instead. This was great, and saved me from having to make a bracket for the hood, so I only had to make 1 Bracket for each side!
#19 |
So instead of buying those $100+ Tien hood dampeners, and after waiting for a set in a trade for a few weeks, I got tired, and went and got some hood dampeners of a 1995 acura legend and fabed them on the crv. I was looking for 92-95 civic hatch glass struts, but couldn't find any.
So the legend struts made it so I only had to make one bracket for each side. The dampeners were $8 for the set, and some grade 8 bolts, nuts and washers were about $2, so a total of $10 and some change for hood dampeners! I also needed a metal bar of some sort. I had a piece of steel lying around at work that a co-worker had used to make a lock set up for his tool box, so i used about 6 inches of that. They bolt to the hood bracket as any normal set would, and right up front on the fender itself. The bracket is on the fender lip (under really) between the two front fender bolts right next to the vin sticker. The bracket goes straight out, and the shock connects there. I painted the bracket black and did have to drill a hole for the bolt, but it looks fine. I was planning on only drilling a hole under the fender line, so it could never be seen, but that specific area is unreachable to put a nut in, because its behind more metal, and I didn't want to make an access hole. So now the bracket is just samwitched around the fender lip. Thats why the grade 8 bolt. So I could tighten it enough, and not brake the head off the nut, which I did, right before I went and got the grade 8! I obviously had to provide the nuts for the "bolt" (round top that the dampener clips over) the dampener connects to on the bracket as well, because that is actually screwed into the vehicle it came off of. I think I used an exaust/cat bolt. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Modified by shaggyeg6si at 8:23 AM 9/25/2008 Modified by shaggyeg6si at 8:26 AM 9/25/2008 Modified by shaggyeg6si at 12:31 PM 9/27/2008 |
#20 |
Another set to use are from a del sol.I have them on my 96 hatchback and my buddy has them on his 01 integra type r.Weve put them on a bunch of integras and civics.
#21 |
nice write up...had some rear window dampers laying around...now i know what to do with them
#22 |
Both setups look nice...Nice write Up too
#23 |
if i were you and i was bored i would have cleaned my engine bay first. but good diy. the second one is way cleaner.
#24 |
So will these actually push the hood up, or do they just hold it up after you have already pushed it up?
Civic and Integ parts for sale. http://www.hondamarketplace.com/show...5#post39565005 |
#25 |
nice, me and my brother tried it on his ef9 but no success ;( but this thread is giving me more hope. i will try again. any in put for ef9 dampers??
| Bookmarks |
| Tags |
| 9900, bolt, car, civic, d16y7, damper, dampers, diy, engine, hatch, homemade, honda, hood, parts, rear |
