> All Motor
Old 07-02-2008, 11:32 AM   #1
k20coupe
k20coupe's Avatar
Default Made up my mind Im rebuilding my ls vtec 270 ftmfw
so heres the build
Block
B18a1 86mm rs sleeved still 1.8 stroke
86mm custom wiseco piston gas ported and 13.7 cr
rpm rods
new oil pump
new water pump
all honda bearings
polished balanced crank
balanced the whole rotating assembly pistons, rods,crank,ctr crank pulley
pressure plate and fly wheel
cometic 86mm headgasket
Head
b16 head milled for cr purposes
P&P flows 295 sending it to blueprint they say they can make it flow 320cfms
buddy club spec V cams, cam gears ,retainers,springs and valves
blox IM ported by blueprint
match ported BDL 70mm TB
hondata gasket
AEM CAI hybrid intake
arp headstuds
new hytech replica header
2.5 piping with an es oval exhaust
Fuel
550cc inj
255hp pump
AEM fuel rail
AEM fuel pressure regulator
Stock fuel filter
Steel braided fuel line
Ignition
Msd 6a box
Msd blaster
Msd coil
Ngk spark plug wires
Trans
b16 ys1
all b16 gears with 4.7 final drive
Quaife Lsd
7lbs kaiten flywheel
Clucth specialties 6puck unsprung dual diafram clutch
All was tuned on crome pro this motor made 250 and over 170ft lbs on a dynojet with
a 100 oct
The only changes Im making is a better flowing head and a better header and bigger inj
I know Im smoking crack thinking Im going to pick up 20hp just by switching those parts but u never know
Modified by k20coupe at 11:40 AM 7/2/2008
Modified by k20coupe at 11:41 AM 7/2/2008
Modified by k20coupe at 11:42 AM 7/2/2008
1995 civic coupe k24/k20 306hp 220tq all motor
k20coupe is offline Report Post   Reply With Quote
Old 07-02-2008, 11:39 AM   #2
k20coupe
k20coupe's Avatar
A couple of motor pics
Old 07-02-2008, 11:43 AM   #3
k20coupe
k20coupe's Avatar
so what u guys think?
Old 07-02-2008, 11:56 AM   #4
k20coupe
k20coupe's Avatar
Default Re: (k20coupe)
any suggestions
Old 07-02-2008, 11:57 AM   #5
all-mtr-teg
all-mtr-teg's Avatar
Nice parts list. Did you consider a 92mm stoke? Or is this a DD?
Vouches: AnthraxVX, Alchemist, SiREK4, airbag, redgsrguy, bambam, mtber, dfoxengr, kteller8, Mad Money, kelviiv, .xcalibur. , 98Luder, BandOi, B19Coupe, numberone, ferio_boy, Master of the Universe, r'truckin, project_dc2
all-mtr-teg is offline Report Post   Reply With Quote
Old 07-02-2008, 11:58 AM   #6
k20coupe
k20coupe's Avatar
no I guess it runs on 100oct
Old 07-02-2008, 12:26 PM   #7
alterdcreations
alterdcreations's Avatar
must run like a bat out of hell
Home to Swiss Army Knives and Watches!!! "she'll love it"...and you might also get a nice suprise www.secrethiddentreasures.com
Need motor work H-B-D series....Pm me
alterdcreations is offline Report Post   Reply With Quote
Old 07-02-2008, 01:50 PM   #8
k20coupe
k20coupe's Avatar
Default Re: (alterdcreations)
it is fast it feels crazy in my crx everything shakes
Old 07-02-2008, 03:10 PM   #9
k20coupe
k20coupe's Avatar
where the all motor gurus at?
Old 07-02-2008, 03:44 PM   #10
2fastGSR
King of the One Liners
2fastGSR's Avatar
Sounds like a decent build.
I would ditch the crome , but thats just me . I'm sure it will still work fine.
Who will be tuning ?
AllenBuilt/RSTech Tuned All Motor F2K Coupe: 10.97 - 126.8
http://www.rstech-racing.com
2fastGSR is offline Report Post   Reply With Quote
Old 07-02-2008, 04:07 PM   #11
4g hatch
Default Re: (2fastGSR)
if you want a real 320cfm head i would think about brad at rlz. i think b19 coupe had a head done by blueprint[or import builders at the time] and he said he sent it to portflow and tom improved upon there work
"whatever you do today,you have to sleep with tonight". quote: arron tippen
"If you do not trust your builder, do not use him. If you do trust him, do not second guess him with internet opinions". quote: don f
VOUCHES IN BIO
4g hatch is offline Report Post   Reply With Quote
Old 07-02-2008, 05:22 PM   #12
k20coupe
k20coupe's Avatar
Default Re: (4g hatch)
I spoke with portflow they say that they dont take ported heads
Old 07-02-2008, 05:23 PM   #13
k20coupe
k20coupe's Avatar
crome works fine just for what its needed for
tuner will be david from import auto pros
Old 07-02-2008, 08:38 PM   #14
k20coupe
k20coupe's Avatar
so u guys think Ill reach my goal
Old 07-03-2008, 07:20 AM   #15
2fastGSR
2fastGSR's Avatar
Sounds like you want a pat on the back. . .
With the wide variety of established parts for the B series ( ie: intake manifolds, headers, cams, etc ) 270 is not a crazy number anymore. While it definitely takes some research to obtain the correct parts it sounds like you are in the right direction.
My only advice to you would be to get ready to try a few different things on the motor.
You may slap it together and make 270. If you do, great job. If not, then just start trying things one at a time and then going to the dyno or track.
Now stop asking for some reassurance and get out there and build the damn thing . . .
Old 07-09-2008, 11:56 PM   #16
mannyman
El Veterano de Sur Califas
yeah get those other parts done.. u never know u might lose power...
forsale
http://www.hondamarketplace.com/zerothread/2376155
TRDE ?,EF TRCTION BAR, ,DAMPENED RACE CRNK PULEY,
mannyman is offline Report Post   Reply With Quote
Old 07-10-2008, 12:40 PM   #17
k20coupe
k20coupe's Avatar
Default Re: (mannyman)
what is ur new build?
Old 07-10-2008, 07:07 PM   #18
goforbroke
Send a message via AIM to goforbroke
Default Re: Made up my mind Im rebuilding my ls vtec 270 ftmfw (k20coupe)
a 100 oct
What does it run in the 1/4?
<U>Destroy everything,obliterate what makes us weak</U>
Give them nothing, but take everything.
goforbroke is offline Report Post   Reply With Quote
Old 07-10-2008, 08:34 PM   #19
k20coupe
k20coupe's Avatar
it ran a mid 12 missed second gear cause of the clutch cable [freak]ing autozone clutch cable 112 or 110 mph I cant remember
Old 07-10-2008, 08:47 PM   #20
98vtec
98vtec's Avatar
tech?
no dyno graph....no good track slips....?
98vtec is offline Report Post   Reply With Quote
Old 07-10-2008, 08:51 PM   #21
k20coupe
k20coupe's Avatar
Default Re: (98vtec)
I have the dyno sheet somewhere but I lost my track slip
Old 07-10-2008, 08:52 PM   #22
k20coupe
k20coupe's Avatar
David from import auto pros
Bookmarks
