DIY Grounding kit help "voltage stabilizer"....?
Old 07-01-2008, 02:20 PM
mist sITR's Avatar
Default DIY Grounding kit help "voltage stabilizer"....?
Alight here's my predicament... i got bored today and started reading a little on DIY grounding kits. I've decided to try to make one. the only problem is all the "how to" threads are so old that the pictures are down. I also don't believe there is anything about this subject in the ITR FAQ. So I'm reaching out for help from you guys.....does anyone wanna show me a picture or diagram of exactly where any/all the Grounding points are to properly ground your engine bay....
I'm sitting with wire and soldering iron in hand......
Old 07-01-2008, 02:36 PM
coolhandluke's Avatar
Default Re: DIY Grounding kit help "voltage stabilizer"....? (mist sITR)
Here is a thread I came across on TI:
http://www.team-integra.net/fo...16605
Old 07-01-2008, 03:31 PM
AltimaXX's Avatar
I ran mine to the alternator, the head, the tranny, the starter, a 2nd ground for the battery itself, a supplement to one of the factory grounds for the headlights, the intake manifold...I can't remember where else. I'll be happy to take pictures for you if you'd like.
Old 07-01-2008, 03:34 PM
mist sITR's Avatar
Default Re: (AltimaXX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AltimaXX &raquo;</TD></TR><TR><TD CLASS="quote">I ran mine to the alternator, the head, the tranny, the starter, a 2nd ground for the battery itself, a supplement to one of the factory grounds for the headlights, the intake manifold...I can't remember where else. I'll be happy to take pictures for you if you'd like.</TD></TR></TABLE>
that's would be helpful
Old 07-01-2008, 04:19 PM
Default Re: (mist sITR)
Please do, this is a project I have wanted to do for quite some time. Lazyness owns me though.
Old 07-01-2008, 04:56 PM
SuckMyDOHC's Avatar
I did almost the same thing. Made some new grounds and re-did the OEM grounds. Used 4 gauge wiring, some nice ring terminals, and heat shrink tubing to make it look pretty.
Old 07-02-2008, 09:06 AM
AltimaXX's Avatar
Mine are a little tacky...they're red cables from an ebay set I had laying around from a couple of years ago. IMO they do the job though. I'll try to get pics after work tonight.
Old 07-04-2008, 07:38 PM
AltimaXX's Avatar
Mmmkay...pics finally uploaded.
A 2nd ground for the battery
The headlight ground
The distributor
Replaced factory valve cover ground
Valve cover to alternator
Intake Manifold
Added to factory tranny ground
Any questions feel free to ask...
Old 10-02-2009, 06:49 PM
SLURS's Avatar
good ****
Old 10-09-2009, 01:27 PM
dc4teg95's Avatar
Do grounding kits make a difference or benefit any?
Old 10-10-2009, 09:16 PM
jamaicantourist's Avatar
they sure do, i have been doing them as a hobby for years, done over 30 different cars, heres a kit in my (now sold) type r
(ignore the arrow i was showing the kink in the fuel pressure regulator hose)
Old 10-12-2009, 04:11 AM
OH_1fstgsr's Avatar
VTEC Solenoid
Intake Manifold, IAT Sensor
TB, MAP Sensor and TB Sensor
These three are a must. I charted the sensor voltage with my Hondata S300 before and after. There is a huge difference in the voltage variation.
Replace the stock ground lines on these or use in addition;
Transmission
Valve Cover
Body Ground
Thatssojdm
11-19-2008 04:58 PM
ctstylez
05-25-2007 10:14 AM
vietdragontekx
03-05-2006 12:16 AM
kay_animation
16
02-02-2003 06:32 AM
Erik_Pb_Foot
03-08-2002 04:59 PM
Quick Reply: DIY Grounding kit help "voltage stabilizer"....?
